Since Vegas can't open Avs file types, I'm looking for help on frameserving into Vegas Movie Studio 17 or Vegas Pro 18(64bit, Windows 10) from Virtualdub2 or other app that can read Avs scripts. Want to apply De-interlacing and Noise reduction in Avisynth+ and frameserve into Vegas for further editing without having to create intermediate files.
Results 1 to 23 of 23
avfs
The older versions run using the windows context menu, and x86 only (x86 avisynth)
The newer versions are x64 and commandline only, and you can extract avfs.exe from the portable vapoursynth installer using 7-zip or similar -
Yes, in terms of lossy compression "losses". But a "losless" AVI can serve the same purpose, and can make it easier to edit in vegas (the script filters are "baked" into the AVI). A slow script can be hard to handle in vegas and make timeline performance sluggish
Not necessarily in terms of pixel format conversions -
All versions of Vegas work in RGB, and if source/script work in YUV, there will be some conversion, and that is a type of loss if the conversion is not done in float. In some versions of vegas, you might have to convert to RGB in the script for avfs to work in vegas (not that bad, because vegas will be converting anyways; at least you can control the type of conversion in the avs script)
Vapoursynth is slightly different. It has pixel format emulation such as "IYUV" for 8bit 4:2:0, "UYVY" for 8bit 4:2:2 and "v210" for 10bit 4:2:2 . Those are "magical" pixel formats for most windows NLE's including vegas, and those formats get passthrough treatment. In vegas <18 , those pixel would get "studio RGB" treatment automatically instead of "computer RGB" . Newer versions of vegas can be set to operate in studio or computer RGB -
I'm always working with a lossless .AVI rather something I've imported from my miniDV cam and applied QTGMC or captured a laserdisc and IVTC'ed, but have always wondered if there was a way Vegas Pro 16 could read the AVS script and save on that one step potential gen-loss.
Ahh Vegas and it's RGB. I remember seeing a YouTube video where a guy described how his rendered file looked different to the video on the Timeline; something to do with computer vs studio rgb. I'll have to dig that up. -
I was fighting this beast in the past, so I tested it again using AVFS.exe. Using a python/vapoursynth portable setup, all in one directory.
Videos used were NTSC DV avi, which are 4:1:1, that gets more complicated rather than PAL 4:2:0
Portable setup for Vapoursynth/Python:
-portable Vapoursynth R60 download link,
-python portable version 3.10.7, dumped in the same directory (not sure if Python 3.11 is already supported for vapoursynth)
-audio plugin BestAudioSource.dll , download link (I think, I just copied mine dll from some earlier portable directory of mine). put into that portable directory, into vapoursynth64\plugins directory
-ffms2.dll (not sure where I have it from, there is one here https://github.com/FFMS/ffms2/releases) and also put into vapoursynth64\plugins directory
-if using AviSource in vapoursynth script instead of ffms2, then dvsd codec is needed, like having Cedocida codec installed, but then AviSource would capture 4:1:1 NTSC DVavi as 4:2:0. That could be a good (no 4:2:0 conversion is needed in script) or bad thing (conversion cannot be controlled (but Cedocida should do a good job)
That shoud be enough just to make AVFS work and load created serve avi file into Magix Vegas (former Sony Vegas). VSVFW.dll is in that portable directory, if AVFS.exe does not work, not sure, it might have something to do to have that dll.
If QTGMC is needed, this needs to be downloaded as well,
QTGMC setup:
-make a directory named python_modules , inside portable directory. This is a good habit to have modules, helper python scripts inside a dedicated separate directory, not inside of that full portable directory and put all of those downloaded *.py scripts there. You can copy those *.py scripst into clipboard and then copy/paste it into a file , rename it as it suppose to be:
- havsfunc.py downloaded from here https://github.com/HomeOfVapourSynthEvolution/havsfunc
- adjust.py , https://github.com/dubhater/vapoursynth-adjust
- mvsfunc.py , https://github.com/HomeOfVapourSynthEvolution/mvsfunc/tree/master/
- nnedi3_resample.py , https://github.com/HomeOfVapourSynthEvolution/nnedi3_resample
- vsutil , not sure, if it is needed , https://github.com/Irrational-Encoding-Wizardry/vsutil
creating a vapoursynth script my_script.vpy located in that portable directory:
and using cmd line (use with proper paths), AVFS.exe is in that portable directory, it came with portable vapoursynth:Code:import vapoursynth as vs from vapoursynth import core import sys from pathlib import Path PATH = Path(__file__).parent sys.path.append(str(PATH / 'python_modules')) #loading dll's DLL_DIR = PATH / 'vapoursynth64' / 'plugins' for dll_name in ['ffms2.dll']: try: core.std.LoadPlugin(path=str(DLL_DIR / dll_name)) except vs.Error: pass #if dll is already loaded file = r'F:\testing_files\NTSC_DVavi.avi' clip=core.ffms2.Source(file) #captures 4:1:1 audio = core.bas.Source(file) clip=clip.std.SeparateFields() yuv=core.resize.Bicubic(clip, format=vs.YUV420P8, matrix_in_s="170m") yuv=yuv.std.DoubleWeave()[::2] print(yuv) print(audio) yuv.set_output(0) audio.set_output(1)
creates C:\Volumes directory where you find avi (Codec ID/Info : ATI YVU12 4:2:0 Planar) and wav file. Cmd print of those were:Code:"AVFS.exe" "my_script.vpy"
Using mpv player, video is ok, BUT, loading avi and wav into Vegas 19, grouped both video and audio (both selected and G). Vegas loaded that video with shifted chroma, not sure how to fix it. Again using mpv player, it is ok, video looks ok, but Vegas does not load it properly, not sure how to fix it:Code:VideoNode Format: YUV420P8 Width: 720 Height: 480 Num Frames: 208 FPS: 30000/1001 Audio Node Sample Type: INTEGER Bits Per Sample: 16 Channels: FRONT_LEFT, FRONT_RIGHT Sample Rate: 48000 Num Samples: 333132
[Attachment 68466 - Click to enlarge]
If using this script and converting to RGB, Vegas loaded video correctly:
Code:import vapoursynth as vs from vapoursynth import core import sys from pathlib import Path PATH = Path(__file__).parent sys.path.append(str(PATH / 'python_modules')) #loading dll's DLL_DIR = PATH / 'vapoursynth64' / 'plugins' for dll_name in ['ffms2.dll']: try: core.std.LoadPlugin(path=str(DLL_DIR / dll_name)) except vs.Error: pass #if dll is already loaded file = r'F:\testing_files\NTSC_DVavi.avi' clip=core.ffms2.Source(file) audio = core.bas.Source(file) clip=clip.std.SeparateFields() rgb=core.resize.Bicubic(clip, format=vs.RGB24, matrix_in_s="170m") rgb=rgb.std.DoubleWeave()[::2] print(rgb) print(audio) rgb.set_output(0) audio.set_output(1)so it is in RGB and Vegas does not convert it to RGB again.Code:VideoNode Format: RGB24 Width: 720 Height: 480 Num Frames: 208 FPS: 30000/1001 Audio Node Sample Type: INTEGER Bits Per Sample: 16 Channels: FRONT_LEFT, FRONT_RIGHT Sample Rate: 48000 Num Samples: 333132
Is thera a way to use avfs.exe and Vegas would treat original without compression if rendered again to DVavi, not change content? I guess not, but anyway. NTSC DV perhaps not at all because of that 4:1:1 vs. 4:2:0.Last edited by _Al_; 1st Jan 2023 at 20:01.
The "shifted chroma" is because vegas doesn't understand YV12 fourcc pixel format arrangement
If using vapoursynth R55+ you can use clip.set_output(alt_output=1) to enable fourcc "I420" emulation for YUV420P8 , and it will be imported correctly as YUV
avisynth doesn't have the emulation, so you usually have to convert to RGB
Same with other windows NLE's like Pinnacle stuidio, Premiere, Resolve . Those fourcc pixel types UYVY (for 8bit 422) and v210 (for 10bit 422) are "preferred" and get special treatment, such as passthrough, YUV treatment, and/or studio RGB treatment in vegas
alt_output=1 for YUV420P8 enables I420
alt_output=1 for YUV420P8 enables IYUV
alt_output=2 for YUV422P8 enables UYVY
alt_output=1 for YUV422P10 enables v210
Not in terms of compression, because it frameserves decoded (uncompressed) audio & videoLast edited by poisondeathray; 1st Jan 2023 at 19:03.
What's the difference from AVFS version 1.0.0.6 and the version extracted from the portable vapoursynth package? Any additional files needed to be extracted from the 7-zip vapoursynth installer. I tried extracting the AVFS from VapourSynth64-Portable-R61.7z, but could not get it to work. However, I tried version 1.0.0.6 and installed the referenced Pismo File Mount Audit Package build 192 and got it seeming working for a simple avs script. Is there a different Pismo File Mount Audit Package I need to install from the vapoursynth package or do I need to extract the entire package? I want to keep everything in 64 bit Avisynth+ and Vegas. Current version from the simple avs script shows Avisynth+ 3.7.0 (r3382, 3.7, i386).
i386 for version() indicates x86 avisynth is being called in that script. It would say x86_64 for the x64 version
The avfs 1.0.0.6 version will only work with avisynth x86 . That will still work in vegas x64 . But avisynth x86 is slower and has potential memory limitations
avfs from the VapourSynth64-Portable archive will work with avisynth x64, and vapoursynth x64. It's self contained, you don't need anything else from the archive (unless you want to play with vapoursynth) - the avfs.exe has an embedded version of pismo mount
To use it with an avisynth script
The "virtual" AVI will appear in c:\volumes\...Code:avfs script.avs
Thanks. That's what I realized. Version 1.0.0.6 only supports 32 bit and explains why it possibly ran out of memory when trying to run a larger script. I'm not sure why I can't get avfs from the VapourSynth64-Portable archive to work. If its has a embedded version of PFM, I'll try deleting PFM Audit Package build 192 and try again. The issue I'm having with the VapourSynth version is that I receive a message: "ERROR: Unable to open PFM interface. PFM probably not installed."
^The earlier error where the AVI did not appear , but you had pismo installed was because version() generates RGB24 not RGB32.
The new error - My understanding is that pismo was embedded, but that error message suggests that you need it. But looking at the archive, there is a pfm-192-vapoursynth-win.exe inside. So it might require you to run with that in the path (e.g. from the extracted folder) . I have an installed vapoursynth along with some portable versions, so I can't debug it easily without messing up my configuration"ERROR: Unable to open PFM interface. PFM probably not installed." -
My impression is that pfm-192-vapoursynth-win.exe isn't actually installed (otherwise it wouldn't be "portable") , rather it is called during runtime
So I think those 2 files are needed in the path; pfm-192-vapoursynth-win.exe, and vsedit.exe . If both are in the same directory I think it should work too -
thanks, that helped:
btw, for those who tries to load QTGMC to vapoursynth, bunch of dlls needs to be loaded as well using core.std.LoadPlugin, some using ctypes,Code:yuv.set_output(0, alt_output=1) #fourcc "I420"
but I do not want to further pollute this thread, op uses Avisynth -
I uninstalled the PFM Audit Package build 192 and tried running the VapourSynth PFM installer and the AVFS.exe file extracted from the VapourSynth64-Portable build. Still no AVI file in the volumes directory. I'm wondering if the PFM Audit Package build 192 wasn't completely removed or if there's another file needed. Didn't see a vsedit.exe file in the build package. The next step I can think of is installing Python and a Portable version of VapourSynth. Any other suggestions? The latest available are portable Vapoursynth R61.7 and python version 3.11.1.
Did you try extracting the entire folder? Run avfs.exe from that folder. Maybe it relies on one of the .dll's in that folder too, not sure. That's the next conservative step. I don't think you need python or to install anything
It works for me with the portable versions like that, but I have an installed version too... so I don' t know if avfs is using other files... I can run a separate version of avfs alone from a separate folder/path, butI don't know if it's only working because of other things installed or in the path.
vsedit is a separate download ; it's an editor analogous to avspmod, but for vapoursynth. You definitely don't need it for this -
Also tried extracting the entire folder. I'll try a few more ideas. Thanks for your help.
Maybe admin privileges ? Although it's a "virtual" file, sometimes windows gets "squirrely" about anything in the c: path
Is there an error.log file ? What does it say ? What does the console log say ? -
I don't get a avi file in the associated volumes folder. All I get is the script.avs and error log file. The error log is blank.
How to render to native 2.7k in Vegas Movie Studio 16 Platinum ?
By GoodEnough in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2021, 17:00 -
Vegas Movie Studio increases the audio volume
By Michael_Rybak in forum AudioReplies: 3Last Post: 26th Dec 2020, 21:59 -
Vegas Movie Studio and interlaced content
By smartel in forum Newbie / General discussionsReplies: 45Last Post: 8th May 2019, 21:09 -
1 day sale on vegas movie studio 15 for $19.99 - today 1/13/2019
By aedipuss in forum Latest Video NewsReplies: 0Last Post: 13th Jan 2019, 15:02 -
Converting AVI From Vegas Movie Studio to GIF
By pone44 in forum EditingReplies: 10Last Post: 18th Sep 2018, 09:55
