I have tried to get this to work right but I just cant figure this out.
It can read my Blu-Ray .SUP file subs, and OCR them fine, but its making them .srt like. All of the formatting, positioning, and coloring is gone when I save as .ass subtitles. The OCR process is using .srt formatting, and even if I save as .ass, the formatting, positioning, and coloring is gone.
Whats up with this, and how I can keep it like the .SUP formatting?
Subtitle Edit does not support conversion of .sup to .ass with all bells & whistles. For editing "non-textual" properties, you can try the so-called SUP editor. No OCR is performed and both inputs and outputs are image-based. Go File --> Import --> Bluray (.sup) subtitle for edit.
There has got to be something that can convert .sup into .ass via OCR and keep the positions and font colors.
I usually use subextractor, and have used it with great results for years, but for some reason it will not work with this particular Blu-Ray. I do not know of any other program that can do this. -
Actually, you know what. That editing the .SUP file actually solved my problem. I just changed the background color of the SUP to black, and now the program I usually use can OCR it properly now.
I knew I could edit .sup, but I never even thought about trying to change the background and or font colors until just now with it.
Adjusting SUP subtitle positions in Subtitle Edit
By CWCprime in forum SubtitleReplies: 3Last Post: 31st Jul 2020, 02:51 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52 -
Saving as a VTT with # on Subtitle Edit
By dvelopment in forum SubtitleReplies: 1Last Post: 22nd Jul 2019, 02:36 -
Pixelated and laggy video on Subtitle Workshop and Subtitle Edit
By Valerc in forum SubtitleReplies: 5Last Post: 15th Jul 2018, 11:37 -
By Valerc in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2018, 14:15
