  1. So yesterday I solved the scaled subs problem by downgrading Subtitle Edit. However, I still have video converting problems. It still crashes if I don't add the PlayRes values. Is it possible that FFMPEG is at fault here, and that SE was the one it was bundled with? It wasn't like this on my Win7 machine just a month ago. I want to uninstall or downgrade FFMPEG.
    Windows 10, MPC-BE
  2. Hi !
    If you want to download old versions of Ffmpeg, you can find them here : https://www.videohelp.com/software/ffmpeg/old-versions
    Please have a nice day
    Best regards
  3. If Subtitle Edit comes bundled with ffmpeg, where do I put the old version into?
    Windows 10, MPC-BE
  4. Just renme it old-ffmpeg.exe
    Best regards
    canada
    Subtitle edit doesn't include ffmeg.You will have to look to where it was installed.
