  1. Member Jorge Junior's Avatar
    Dec 2022
    Rio de Janeiro - Brazil
    Hi!
    I've always used my GeForce GTX1060 to capture my gameplays, but for some reason the video quality is bad now.
    Can you help me?
    This is my PC:
    Windows 11 Pro x64 | i7-8700 (3.20GHz) | 32GB RAM
    Asus ROG Strix Z370-G Gaming | GeForce GTX 1060 6GB
    This is my recording settings. I've always used it this way:
    That's a small video I recorded a while ago. There's nothing wrong with it:
    https://youtu.be/CCa91ZzX6kQ
    And that's what's happening now:
    https://youtu.be/ciq9-NTic-c
    What could be causing this?
    The first game is Nioh. The other is God of War. Both require a GTX 1060
  2. try using OBS and see if the problem remains
  3. That's not "poor quality" encoding. It's gross errors. Make sure your computer and graphics card aren't overheating.
  4. These only occur on the screen recording if I got it correctly. Maybe a different screen recorder can help. As well as PC cleaning
  5. Member Jorge Junior's Avatar
    Dec 2022
    With OBS it's OK.
    I wanted to be able to record my gameplays with the NVidia app again. ��
    I asked for help there, but nobody replied.
    I'm not an expert. How can I check if it's overheating?
    I ran some tests (in 4K and HD). Apparently it's happening only with God of War, whose system requirements are the same as the other games I recorded before.
    The recording was perfect with Nioh and Nioh 2. Even Steelrising, that recommends an RTX 2070 SUPER, was OK.
