the terminal gives you the answer...
[Attachment 71543 - Click to enlarge]
Results 181 to 210 of 848
what version Android did you use?
did you get the frida server running? -
the tutorial speaks of Android 9 Pie. I can confirm that it works perfect on 9, as I have dumped hundres of CDM from Android Studio using this method.
Create an AVD using Android 9
Download the x86 frida server
rename the file to frida
adb push frida /sdcard/
adb shell
su
cp /sdcard/frida /data/local/tmp
chmod +x /data/local/tmp/frida
run dumper.py
open bitmovin in chrome -
Anonymous9875434Guest
I don't know where are these problems come
[Attachment 71551 - Click to enlarge] -
Anonymous9875434GuestWhat After this step ?!Originally Posted by
Let's have a look in dumper-main directory.
You will find a directory (private-keys) containing the 2 files
[ATTACH
After I get The 2 files -
Alright, first of all, you need to calm your tits.. This is not a paid service and you are not entitles to demand support, people are helping you in their own time and spamming a thread won't get you results. be respectful and have patience.
second: you end up with two files. That's your CDM. The fact that you don't understand this yourself, tells me you need to do a lot more research before you are able to start getting keys and decrypting videos. Read the forum, ask questions when needed and read some more while you WAIT FOR ANSWERS -
So you have many Problems :
First you are a spammer opening many threads...and you expect a quick answer like a hotline...
Second I think you are a scammer who try to rob videos (to resell them after) from people who work hard to make their lessons on your Egyptian site.
Third... stop PM and Learn Python by yourself because you need special script to steal videos... -
Hello everyone, I am new to this forum. I just wanted to thank cedric8528 for his comprehensive guide
Your contribution and A_n_g_e_l_a's has really helped me in my journey to obtaining my own keys
Today, I can successfully report that I have decrypted my very first media file that was obtained from VDOCipher
So, cedric8528's method actually works even with that website!
I wish to also thank cedric8528 for this handy guide. When cdrm-project.com went down recently, I finally got the boot up the backside I so sorely needed to dump my own CDM key. My workflow is now back up and running thanks to this guide.
I haven't read through the whole thread, so apologies if I'm covering old ground, but I thought I'd add some of my notes here in case anyone gets stuck or encounters similar issues as I did.
- First, in order to get a rooted AVD (phone), I had to select an image without the Google Play or Google API option -- not sure if this has been pointed out already
- Also, on my Ubuntu system, I had to install some additional Python modules to get the dumper working correctly, summarised in this one-liner:
Code:pip install frida frida-tools pycryptodome protobuf==3.19 xmltodict
- Last but not least, in Linux, the CRLF end-of-line characters in some of the downloaded Python scripts may need to be converted to LF
All in all, fairly minor glitches in my case, which were overcome easily. Thanks again for all the hard work and a very clear guide.
[Attachment 72339 - Click to enlarge]
Why is it giving an error in the last command? Is there anyone who can help? -
[Attachment 72340 - Click to enlarge]
this time i am getting this error -
[Attachment 72347 - Click to enlarge]
how can i fix "unable to connect to remote frida-server: closed" -
You need to have the frida server running in a separate command window in the background as per the instructions in the guide -- do not close this window once you execute the last command in the sequence shown (click to follow the link).
[Attachment 68356 - Click to enlarge] -
[Attachment 72349 - Click to enlarge]
i finally solved the problem
https://github.com/ViRb3/magisk-frida
Download frida servers from this site and follow the stepsLast edited by engomingo; 9th Jul 2023 at 13:17. Reason: i solved the problem
adb.exe shell
su
mv /sdcard/frida-server-16.1.1-android-x86_64 /data/local/tmp
chmod +x /data/local/tmp/frida-server-16.1.1-android-x86_64
/data/local/tmp/frida-server-16.1.1-android-x86_64 -
Hi guys!
I'm wondering about this code: adb.exe push frida-server-16.1.1-android-x86 /sdcard
Just to be sure, do you have to have a SDcard inserted or does 'sdcard' stand for something different?
After running this code (without having a SDcard inserted):
adb.exe shell
su
mv /sdcard/ frida-server-16.1.1-android-x86/data/local/tmp
chmod +x /data/local/tmp/ frida-server-16.1.1-android-x86
I was shown this error:
C:\Users\tobia\AppData\Local\Android\Sdk\platform-tools>adb.exe shell
generic_x86_arm:/ $ su
frida-server-16.1.1-android-x86/data/local/generic_x86_arm:/ # mv /sdcard/ sdcard/ frida-server-16.1.1-android-x86/data/local/tmp <
/data/local/tmp/frida-server-16.1.1-andromv: bad '/sdcard/': No such file or directory
id-x86
mod +x /data/local/tmp/ frida-server-16.1.1-android-x86 <
chmod: frida-server-16.1.1-android-x86: No such file or directory
1|generic_x86_arm:/ # /data/local/tmp/frida-server-16.1.1-android-x86
/system/bin/sh: /data/local/tmp/frida-server-16.1.1-android-x86: not found
127|generic_x86_arm:/ #
Does anyone might know what exactly the problem is? Any help is appreciated.
Regards, Tobby
Dumping L3 from Android 10, 11 and 12
By Diazole in forum Video Streaming DownloadingReplies: 45Last Post: 9th Jan 2023, 08:13 -
Can you set up a working CDM from an Android device running a custom ROM?
By scryclwn in forum Video Streaming DownloadingReplies: 2Last Post: 27th Nov 2022, 13:46 -
Error getting the keys with dumper, cdm L3 android 9
By Brift_Bv in forum Video Streaming DownloadingReplies: 15Last Post: 23rd Sep 2022, 03:33 -
How To Dump L3 CDM From Android Device's (ONLY Talk About Dumping L3 CDMS)
By Dannyboi in forum Video Streaming DownloadingReplies: 226Last Post: 1st Mar 2022, 04:34 -
How To Dump L1 CDM From Android Device's (ONLY Talk About Dumping L1 CDMS)
By mintolik in forum Video Streaming DownloadingReplies: 13Last Post: 20th Feb 2022, 15:33
