i already extracted the file and put it to platform-folder and run command and this shows up
[Attachment 79825 - Click to enlarge]
[Attachment 79826 - Click to enlarge]
Results 631 to 660 of 849
i got this error
[Attachment 79830 - Click to enlarge]
UPDATE! it worked i use ARM32(arm) architechture
[Attachment 79831 - Click to enlarge]Last edited by polkzhyzia; 12th Jun 2024 at 08:21.
Error is pretty self-explanatory, it's saying the frida server is not running on your device. Sometimes frida will cause your device to reboot or cause other unwanted effects. Just make sure frida is still running, and also use a more up-to-date CDM dumper like KeyDive.
i thought it is already rooted when you are in super user,? any help?
[Attachment 79844 - Click to enlarge] -
I've followed everything exactly as intended but I'm stuck at the part when we speak to the phone
C:\Users\logsf\AppData\Local\Android\Sdk\platform-tools>adb.exe shell
generic_x86_arm:/ $ su
/system/bin/sh: su: not found
127|generic_x86_arm:/ $
I download the file 'frida-server-16.3.3-android-x86' and inserted this in the platform-tools folder -
Thanks white_snake. I was using a Pixel 9 which had Google Play. Changed the device to a Pixel 6 as per the instructions and that worked. Now I've copied the device_client_id_blob and device_private_key files over to replace the originals, what should I do now. Can I close both of the terminals I had open and the android phone? I want to download videos from STV which need a CDM installed
keydive to resolve this?
[Attachment 79984 - Click to enlarge] -
I'm already running as root
[Attachment 79989 - Click to enlarge]
[Attachment 79990 - Click to enlarge] -
[C:\Users\HP\AppData\Local\Android\Sdk\platform-tools>adb.exe shell
127|generic_x86_arm:/ $]
can anyone help ?? why su is not found why is the Virtual phone not rooted i crated the device as said in the post
Noob Starter Pack. Just download any Widevine media! Over 22,000 downloads for V6!.
https://files.videohelp.com/u/301890/hellyes6.zip -
OOh so i need to create a new one ?? right
The Pixel 6Pro one ?? is what u are saying to select right ?
[Attachment 80178 - Click to enlarge] -
I got my device rooted but i have a doubt as to which version to download ?? of frida from https://github.com/frida/frida/releases
can any one tell which frida to download for virtual android setup ??
also the Process indicates a single file on extraction however now there are 3 files in there so do i need to paste the whole folder .... or only some of the files!!
[QUOTE=Shadee;2740756]I got my device rooted but i have a doubt as to which version to download ?? of frida from https://github.com/frida/frida/releases
SOLVED -
[Attachment 80186 - Click to enlarge]
Everything is setup nicely but the ... Dumper dosent work when i navigate to the drm site given https://bitmovin.com/demos/drm
u can see that in the terminal !! why is it so ?? did i do anything wrong to setup ??
Use keydive. The entire process from root avd onwards gets automated and is a lot easier and gets completed in a few steps.
Note: Make sure the frida you download & push and the frida you install via pip are the same version. Newbies make this mistake too often(I did too
I think the avd architecture and frida needs to be the same. I created an 86_64 arch(google api) and downloaded the same frida version. Check yours. Do NOT select google play under any circumstance, or any other.Last edited by Karn; 25th Jun 2024 at 20:15.
Thanks for the Reply:
My frida version is 16.3.3
[Attachment 80194 - Click to enlarge]
my Virtual Android Properties are:
avd.ini.displayname Pixel 6 Pro API 28
avd.ini.encoding UTF-8
AvdId Pixel_6_Pro_API_28
disk.dataPartition.size 6442450944
fastboot.chosenSnapshotFile
fastboot.forceChosenSnapshotBoot no
fastboot.forceColdBoot no
fastboot.forceFastBoot yes
hw.accelerometer yes
hw.arc false
hw.audioInput yes
hw.battery yes
hw.camera.back virtualscene
hw.camera.front emulated
hw.cpu.ncore 4
hw.device.hash2 MD5:a8abfd3536f3d35e4ba2041a7b99f40e
hw.device.manufacturer Google
hw.device.name pixel_6_pro
hw.dPad no
hw.gps yes
hw.gpu.enabled yes
hw.gpu.mode auto
hw.initialOrientation portrait
hw.keyboard yes
hw.lcd.density 560
hw.lcd.height 3120
hw.lcd.width 1440
hw.mainKeys no
hw.ramSize 2048
hw.sdCard yes
hw.sensors.orientation yes
hw.sensors.proximity yes
hw.trackBall no
image.androidVersion.api 28
image.sysdir.1 system-images\android-28\google_apis\x86\
PlayStore.enabled false
runtime.network.latency none
runtime.network.speed full
showDeviceFrame yes
skin.dynamic yes
tag.display Google APIs
tag.displaynames Google APIs
tag.id google_apis
tag.ids google_apis
vm.heapSize 384
[Attachment 80195 - Click to enlarge]
As far as i know its x86 version of Frida server that i need to download right ??
[Attachment 80196 - Click to enlarge] this is the one i downloaded
Still the case remains the same ... on playing the drm video my dumper terminal has no response !!
So do i nee to implement the x86_64 arch ??
Also i dont have a clue about keydive can u suggest a sticky thread / forum thread using keydive for CDM
Dumping L3 from Android 10, 11 and 12
By Diazole in forum Video Streaming DownloadingReplies: 45Last Post: 9th Jan 2023, 08:13 -
Can you set up a working CDM from an Android device running a custom ROM?
By scryclwn in forum Video Streaming DownloadingReplies: 2Last Post: 27th Nov 2022, 13:46 -
Error getting the keys with dumper, cdm L3 android 9
By Brift_Bv in forum Video Streaming DownloadingReplies: 15Last Post: 23rd Sep 2022, 03:33 -
How To Dump L3 CDM From Android Device's (ONLY Talk About Dumping L3 CDMS)
By Dannyboi in forum Video Streaming DownloadingReplies: 226Last Post: 1st Mar 2022, 04:34 -
How To Dump L1 CDM From Android Device's (ONLY Talk About Dumping L1 CDMS)
By mintolik in forum Video Streaming DownloadingReplies: 13Last Post: 20th Feb 2022, 15:33
