Continue with "Decryption and the Temple of Doom", and thereafter "Decryption: The Dungeon of Despair", followed by "Decryption: The Last Crusade". If you've worked through these three threads - read at least the initial post - you know what to do with the files.
Results 571 to 600 of 849
Refer "Beyond WKS-KEYS" thread to know how to generate .wvd file from these two files -
C:\Users\hello\Downloads\dumper-main\dumper-main>python dump_keys.py
2024-05-08 08:36:23 PM - root - 16 - INFO - Connected to Android Emulator 5554
2024-05-08 08:36:23 PM - root - 17 - INFO - scanning all processes for the following libraries
File "C:\Users\hello\Downloads\dumper-main\dumper-main\dump_keys.py", line 18, in <module>
for process in device.enumerate_processes():
File "C:\Users\hello|AppData\Local\Programs\Python\Pyth on312\Lib\site-packages\frida\core.py", line 86, in wrapper
return f(*args, **kwargs)
File "C:\Users\hello\AppData\Local\Programs\Python\Pyth on312\Lib\site-packages\frida\core.py", line 887, in enumerate_processes
return self._impl.enumerate_processes(**kwargs) # type: ignore
frida.PermissionDeniedError: unable to access process with pid 606 due to system restrictions; try `sudo sysctl kernel.yama.ptrace_scope=0`, or run Frida as root
how to solve this issue? -
yeah i have got the files , actually i used a diff device model which was old ,i tried with pixel 6 as specified i have got the files.
You only need to do that if you're dumping from Android 14 (and only if you're dumping a 18.0.0+ version CDM, I believe). If that is the case, KeyDive's output will tell you the library file to pull from your device, for example:
Code:[I] Cdm: Library: android.hardware.drm-service.widevine (/apex/com.google.android.widevine/bin/hw/android.hardware.drm-service.widevine)
thx.
there I have one question, when I tried different times, why the received device privat key is always different ?Last edited by Kaba; 11th May 2024 at 09:28.
Hi
First of all, great guide!
I've managed to get it work. I'm getting a result like: (see pic)
that shows the message with a long key and a signature, but the folder private-keys not created for me, also tried to show hidden files and folders but nothing.
how do I get those 2 files?
P.S
I'm on Mac -
If I remember correctly, for me anyway (this was a while back), I couldn't get the MacOS Arm version of Android studio to correctly dump keys because it uses either Arm android, or arm emulated x86 virtual devices. I in the end had to do it on an x86 machine. Happy to shoot you over an emulated CDM though if you need.
Will try with intel Mac
after I get those keys, I use it as is with udemy downloader? -
I have added to Keydive the ability to automatically open a Bitmovin demo and generate a WVD.
I have currently sent a PR to the owner and am waiting for a response.
My changes can be found here.
https://github.com/hyugogirubato/KeyDive/pull/10/files
ExampleCode:-a, --auto Open Bitmovin’s demo automatically -w, --wvd Generate WVD
This automatically open Bitmovin's demo without user's interaction and generates wvd automaticallyCode:python keydive.py -aw
Don't be stupid.Use your brain and Google.
Read the rules and documentation before asking for support about my extension. -
hey i had a problem with the script unable to find widevine (i'll put the screenshot). i've been trying using different of system images from Pie to UpsideDownCake and the problem still present. i followed the instruction mentioned on the link provided but it didn't seem to mention any widevine unable stuff on the link. could you help me with this?
Thank you cedric8528 for sharing the wonderful guide.
I followed the instructions but for some reason the keys won't generate. Anyone know or have an idea about the probable cause?
I've Frida 16.2.5 and Frida-tools 12.4.2 installed. The DRM video https://bitmovin.com/demos/drm does play though.
Device Pixel 6 API 28. Both command windows are active and I see no errors there.
Edit: Looking at the debug of dump_keys.py, I see this message and not sure if this is the cause of the trouble.
The last line has this message "Hooks completed"2024-05-24 08:51:13 AM - Helpers.Scanner - 82 - INFO - Running libwvhidl.so at 0xeaac0000
2024-05-24 08:51:13 AM - Helpers.Scanner - 75 - DEBUG - {
"from": "Dynamic Function",
"message": "L3 RSA Key export function found: cwkfcplc"
ThanksLast edited by vidblue; 24th May 2024 at 11:37.
Thanks. Installed KeyDive and requirements but I still don't see the keys created.
PS C:\Users\cccccc\Downloads\KeyDive-main> python3.11.exe .\keydive.py
2024-05-24 20:42:14 [I] KeyDive: Version: 1.0.8
2024-05-24 20:42:15 [I] Cdm: Device: Android Emulator 5554 (emulator-5554)
2024-05-24 20:42:15 [I] Cdm: SDK API: 28
2024-05-24 20:42:15 [I] Cdm: ABI CPU: x86
2024-05-24 20:42:15 [I] Cdm: Script loaded successfully
2024-05-24 20:42:15 [D] Cdm: Analysing... (android.hardware.drm@1.1-service.widevine)
2024-05-24 20:42:15 [D] Cdm: Analysing... (mediadrmserver)
2024-05-24 20:42:16 [D] Cdm: Analysing... (mediadrmserver)
2024-05-24 20:42:16 [D] Cdm: Analysing... (mediaserver)
2024-05-24 20:42:17 [I] Vendor: CDM version: 14.0.0
2024-05-24 20:42:17 [I] Vendor: OEM Crypto API: 14
2024-05-24 20:42:17 [I] KeyDive: Process: 1645 (android.hardware.drm@1.1-service.widevine)
2024-05-24 20:42:17 [I] Cdm: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
2024-05-24 20:42:17 [D] Script: Hooked (0xeac0a480): _ZN5wvcdm10Properties14UsePrivacyModeERKNSt3__112b asic_stringIcNS1_11char_traitsIcEENS1_9allocatorIc EEEE
2024-05-24 20:42:17 [D] Script: Hooked (0xeab93350): _ZN5wvcdm10CdmLicense17PrepareKeyRequestERKNS_18In itializationDataENS_14CdmLicenseTypeERKNSt3__13map INS5_12basic_stringIcNS5_11char_traitsIcEENS5_9all ocatorIcEEEESC_NS5_4lessISC_EENSA_INS5_4pairIKSC_S C_EEEEEEPSC_SM_
2024-05-24 20:42:17 [D] Script: Hooked (0xeaccd020): cwkfcplc
2024-05-24 20:42:17 [I] KeyDive: Successfully hooked. To test, play a DRM-protected video: https://bitmovin.com/demos/drm
generic_x86_arm:/ # /data/local/tmp/frida-server-16.2.5-android-x86Last edited by vidblue; 24th May 2024 at 22:19.
Thanks. I deleted the emulator and created a new one. It worked. I think it worked this time because I did get the playing protected video "allow/block" warning which I didn't get earlier for some reason.
Now on the next project to learn how to make use of these keys
Hi
I'm having a spot of bother trying to Execute frida-server!
No such file or directory
As can be seen from bellow the frida-server is in the tmp directory and has read write executable permisions
Hoping someone adviseCode:C:\Users\XXXXXX\AppData\Local\Android\Sdk\platform-tools>adb.exe shell emu64xa:/ $ su emu64xa:/ # mv /sdcard/frida-server-16.2.5-android-x86 /data/local/tmp/ emu64xa:/ # chmod +x /data/local/tmp/frida-server-16.2.5-android-x86 emu64xa:/ # /data/local/tmp/frida-server-16.2.5-android-x86 /system/bin/sh: /data/local/tmp/frida-server-16.2.5-android-x86: No such file or directory 126|emu64xa:/ # ls -l /data/local/tmp/ total 55208 -rwxrwx--x 1 u0_a172 media_rw 56528216 2024-05-30 16:46 frida-server-16.2.5-android-x86 emu64xa:/ #
try with elevated privileges
emu64xa:/ $ su
emu64xa:/ # su -c /data/local/tmp/frida-server-16.2.5-android-x86 -
hello guys ..
why dumper suddenly not working ,
....phyton dump_keys.py
any idea ? -
You should stop using the old DUMPER .
Just use KEYDIVE.
and the make sure the requirements.txt , is in your "pip list" -
getting-error-while-using-su-commandCode:
emu64xa:/ # su -c /data/local/tmp/frida-server-16.2.5-android-x86 su: invalid uid/gid '-c'
suggsts su 0
Code:|emu64xa:/ # su 0 /data/local/tmp/frida-server-16.2.5-android-x86 su: failed to exec /data/local/tmp/frida-server-16.2.5-android-x86: No such file or directory
used this :
emu64xa:/ # su -c "sh /data/local/tmp/frida-server-16.2.5-android-x86
[Attachment 79474 - Click to enlarge]
Tested and work
Dumping L3 from Android 10, 11 and 12
By Diazole in forum Video Streaming DownloadingReplies: 45Last Post: 9th Jan 2023, 08:13 -
Can you set up a working CDM from an Android device running a custom ROM?
By scryclwn in forum Video Streaming DownloadingReplies: 2Last Post: 27th Nov 2022, 13:46 -
Error getting the keys with dumper, cdm L3 android 9
By Brift_Bv in forum Video Streaming DownloadingReplies: 15Last Post: 23rd Sep 2022, 03:33 -
How To Dump L3 CDM From Android Device's (ONLY Talk About Dumping L3 CDMS)
By Dannyboi in forum Video Streaming DownloadingReplies: 226Last Post: 1st Mar 2022, 04:34 -
How To Dump L1 CDM From Android Device's (ONLY Talk About Dumping L1 CDMS)
By mintolik in forum Video Streaming DownloadingReplies: 13Last Post: 20th Feb 2022, 15:33
