Page 17 of 29
FirstFirst ... 7 15 16 17 18 19 27 ... LastLast
Results 481 to 510 of 849
  1. Hi guys, I make all jobs, but Google chrome show only white screen. Internet is ok. I use Virtualbox 7.0 two guests Elementary os and Android 9.0 x86.
    Sep 2022
    Germany
    The Emulator Pie (Android 9) works fine, but Chrome show a blank page if I type in https://plus.rtl.de
    All other websites are working fine. I can't update any apps.
    I hope, someone can help. Thank you.
  3. Originally Posted by Karoolus View Post
    Originally Posted by PSXman_uk View Post
    Do you use the same Vm for each set of keys or new vm each time
    with VM you mean Android AVD?
    Yes same AVD Device or do you create multiple devices
    Sep 2022
    Germany
    I have a similar problem, but only with the page https://plus.rtl.de
    It's blank. I exactly followed the instructions of building a cdm. It works fine, but I need the page to be displayed.
    [Attachment 76606 - Click to enlarge]
  5. Originally Posted by banaguitar View Post
    if youve already got the cdm files extracted why do you need the rtl page to load?
  6. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    New AVD for every CDM you want to dump
    Sep 2022
    Germany
    I don't have them, only set up the AVD with the dumper which works fine.
  8. Originally Posted by banaguitar View Post
    im confused, do you have these files:
    device_client_id_blob
    device_private_key
    Sep 2022
    Germany
    Yeah, I got them on https://bitmovin.com/demos/drm
    What is the next step?
  10. Originally Posted by banaguitar View Post
    so you have the cdm files, what are you trying to get now?
    Sep 2022
    Germany
    I want to download from RTL+. I even have the mpd file and already downloaded the video, now I need the key to decrypt the video:
    mp4decrypt --key XXXXXXXXXX input.mp4 output.mp4
    What do I have to do now? Thanks for help.
  12. Originally Posted by banaguitar View Post
    You dont need the emulator now, you can just use your browser on your pc.
    these threads should help with the next steps:
    setting up the scripts
    https://forum.videohelp.com/threads/404994-Decryption-and-the-Temple-of-Doom - Decryption section
    and more specific help for RTL
    https://forum.videohelp.com/threads/412143-Can-someone-help-me-to-download-a-video-from-plus-rtl-de
    https://forum.videohelp.com/threads/411044-Downloading-videos-from-RTL
    Sep 2022
    Germany
    Thank you for sharing the links. But I need the emulator to generate the two files and then make my own with wkskeys. Is this correct?
  14. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    You need the CDM files that you can dump using this guide. Then you use that CDM in combination with pywidevine/wks-keys/... to perform a request to the license server and get your keys that way. This is not the place for those questions, check the other sticky threads to find more information.
    Sep 2022
    Germany
    Yes, that's what I mean
    1. pip install pywidevine
    2. Create new folder wvd in same folder as dumped files
    3. pywidevine create-device -k private_key.pem -c client_id.bin -t "ANDROID" -l 3 -o wvd
    4. load file with l3.py script
    # load device
    device = Device.load(r"path_to_wvd")
  16. Hi! I made all guide, but, then i run video in emulator google chrome, script does nothing working.
  17. Originally Posted by Cryosim View Post
    Pmed you
  18. Wow! i got keys, just install android 9.0 pie x86, i don't know, why not working on Android 14 x64_86.
  19. So, I get keys client_id.bin
    private_key.pem
    What are my next steps?
  20. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    private_key.pem
    Read the other sticky threads
  21. Originally Posted by Cryosim View Post
    There are no key dumpers that claim they can dump keys from Android 14. Highest supported version is 13.
    private_key.pem
    This guide is about dumping your CDM and you did just that, there's nothing else do to except renaming the two files. After this you're ready to use them in your scripts or create a .wvd file.
  22. Hey all, sorry for my question I'm a pure newbie. I just started downloading MPD's yesterday following Angela's tuto, but I only downloaded from site I already know the keys and that don't have DRM apparently. I don't know how to get the keys for Arte.tv or Auvio.be, do I need to use this android method?
    Thank you.
  23. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Arte.tv has DRM protection? I checked and the videos can be downloaded directly using the m3u8 files. Does it have some specific videos with drm?
  24. Member
    Feb 2024
    Turkey
    I followed all the steps. I browsed the webpage on emulator: https://bitmovin.com/demos/drm. I got two files: 7283.bin and 7283.json. Instead of a .bin file and .pem file. Also, videos do not showing the visuals, just audio. Am I missing something? (btw I am macOS user and I am using a arm64 emulator)
  25. Originally Posted by Vakarm View Post
    Thank you.
    You don't need your own CDM, search the forums: https://forum.videohelp.com/threads/412576-trying-to-download-from-Auvio#post2720391
    Again, a simple forum search wouldn't hurt: https://forum.videohelp.com/threads/404219-How-To-Dump-L3-CDM-From-Android-Device-s-(O...e3#post2643969
  26. Member
    Feb 2024
    Turkey
    I believe that problem is not that related. frida can detect my device.
    Here are the logs:
    After I started the dump_keys.py
    2024-02-10 12:27:33 PM - root - 16 - INFO - Connected to Android Emulator 5554
    2024-02-10 12:27:33 PM - root - 17 - INFO - scanning all processes for the following libraries
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1, name="init", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1086, name="init", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1087, name="init", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1088, name="ueventd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1309, name="logd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1310, name="servicemanager", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1311, name="hwservicemanager", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1312, name="vndservicemanager", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1313, name="android.hardware.keymaster@3.0-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1314, name="vold", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1363, name="android.hidl.allocator@1.0-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1364, name="healthd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1365, name="android.hardware.audio@2.0-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1366, name="android.hardware.broadcastradio@1.1-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1367, name="android.hardware.camera.provider@2.4-service_64", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1368, name="android.hardware.configstore@1.1-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1369, name="android.hardware.drm@1.0-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1370, name="android.hardware.drm@1.1-service.clearkey", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1371, name="android.hardware.drm@1.1-service.widevine", parameters={})
    2024-02-10 12:27:33 PM - Helpers.Scanner - 82 - INFO - Running libwvhidl.so at 0x75e540a000
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1372, name="android.hardware.gatekeeper@1.0-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1373, name="android.hardware.gnss@1.0-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1374, name="android.hardware.graphics.allocator@2.0-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1376, name="android.hardware.health@2.0-service.goldfish", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1377, name="android.hardware.power@1.1-service.ranchu", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1378, name="android.hardware.sensors@1.0-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1379, name="android.hardware.wifi@1.0-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1380, name="hardware.google.media.c2@1.0-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1382, name="qemu-props", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1383, name="audioserver", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1384, name="lmkd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1386, name="thermalserviced", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1387, name="logcat", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1389, name="adbd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1390, name="traced", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1391, name="traced_probes", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1404, name="mdnsd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1532, name="surfaceflinger", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1533, name="zygote64", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1534, name="cameraserver", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1535, name="drmserver", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1536, name="incidentd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1537, name="installd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1538, name="keystore", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1539, name="mediadrmserver", parameters={})
    2024-02-10 12:27:33 PM - Helpers.Scanner - 82 - INFO - Running libmediadrm.so at 0x7bebd9b000
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1540, name="media.extractor", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1541, name="media.metrics", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1542, name="mediaserver", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1543, name="netd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1544, name="statsd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1545, name="storaged", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1546, name="wificond", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1547, name="media.codec", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1548, name="rild", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1550, name="gatekeeperd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1551, name="perfprofd", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1552, name="tombstoned", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1562, name="android.hardware.biometrics.fingerprint@2.1-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1570, name="android.hardware.graphics.composer@2.1-service", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1603, name="iptables-restore", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1604, name="ip6tables-restore", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1629, name="createns", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1643, name="netmgr", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1668, name="dhcpclient", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1681, name="ipv6proxy", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1684, name="hostapd_nohidl", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1686, name="dhcpserver", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1692, name="system_server", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1824, name="com.google.android.inputmethod.latin", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1835, name="com.android.systemui", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1856, name="webview_zygote", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1913, name="com.android.phone", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=1980, name="com.google.android.ext.services", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2061, name="wpa_supplicant", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2148, name="com.google.android.gms.persistent", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2192, name="Phone", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2337, name="com.google.android.gms", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2367, name="com.google.process.gservices", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2387, name="Google", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2421, name="com.android.se", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2485, name="com.android.smspush", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2501, name="com.android.launcher3", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2525, name="com.google.android.setupwizard", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2634, name="Photos", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2699, name="com.google.android.googlequicksearchbox:search", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2746, name="com.google.process.gapps", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=2933, name="com.android.providers.calendar", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=3024, name="Maps", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=3088, name="Messages", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=3118, name="com.google.android.gms:car", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=3241, name="Calendar", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=3325, name="Gmail", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=3394, name="com.google.android.ims", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=3610, name="com.google.android.gms.unstable", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=3949, name="com.android.cellbroadcastreceiver", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=4033, name="com.android.keychain", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=4068, name="android.process.acore", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=4203, name="sh", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=4205, name="sh", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=4213, name="frida-server-16.1.11-android-arm64", parameters={})
    2024-02-10 12:27:33 PM - root - 19 - DEBUG - Process(pid=4215, name="logcat", parameters={})
    2024-02-10 12:27:33 PM - root - 25 - INFO - Hooks completed
    After I browse the website: https://bitmovin.com/demos/drm
    2024-02-10 12:37:59 PM - Helpers.Scanner - 75 - DEBUG - {
        "from": "android.hardware.drm@1.1-service.widevine",
        "message": "OEMCrypto_GetProvisioningMethod",
        "payload": {
            "Method": "OEMCrypto_Keybox"
        "message": "OEMCrypto_GetKeyData",
        "payload": {
            "Status": "OEMCrypto_SUCCESS",
            "Size": 72,
            "Device_Token": "0000000200001c732429b28b8fa045c0cd5f28e2113f97fd5e8582ced15414e7749d8c68dfa91ea385df0c97f3773c910c328f3c22b31e8ee0ddf3bd988b6b8b8a5f4b9a480c036f"
    2024-02-10 12:37:59 PM - Helpers.Scanner - 63 - DEBUG - processing device token
    2024-02-10 12:37:59 PM - Helpers.Scanner - 174 - INFO - saving key box
    2024-02-10 12:37:59 PM - Helpers.Scanner - 177 - DEBUG - saving to key_dumps/Android Emulator 5554/key_boxes/7283
    2024-02-10 12:37:59 PM - Helpers.Scanner - 184 - INFO - saved keybox to key_dumps/Android Emulator 5554/key_boxes/7283
        "message": "OEMCryptoVersion",
        "payload": {
            "Version": 13
        "message": "OEMSecurityLevel",
        "payload": {
            "Level": "L3"
        "payload": {
            "Level": "L3"
    2024-02-10 12:38:00 PM - Helpers.Scanner - 75 - DEBUG - {
        "payload": {
        "payload": {
            "Size": 72,
    2024-02-10 12:38:00 PM - Helpers.Scanner - 63 - DEBUG - processing device token
    2024-02-10 12:38:00 PM - Helpers.Scanner - 174 - INFO - saving key box
    2024-02-10 12:38:00 PM - Helpers.Scanner - 177 - DEBUG - saving to key_dumps/Android Emulator 5554/key_boxes/7283
    2024-02-10 12:38:00 PM - Helpers.Scanner - 184 - INFO - saved keybox to key_dumps/Android Emulator 5554/key_boxes/7283
        "payload": {
            "Version": 13
        "payload": {
            "Level": "L3"
        "payload": {
            "Level": "L3"
  27. Member
    Feb 2024
    Turkey
    Here are the logs:
        "payload": {
        "payload": {
            "Size": 72,
        "payload": {
            "Version": 13
        "payload": {
            "Level": "L3"
        "payload": {
            "Level": "L3"
        "payload": {
        "payload": {
            "Size": 72,
        "payload": {
            "Version": 13
        "payload": {
            "Level": "L3"
        "payload": {
            "Level": "L3"
    Solved the problem. And get the private keys.
    Used the following 'dumper' repo: https://github.com/Diazole/dumper rather than proposed on the post(https://github.com/wvdumper/dumper
    ). BTW: I am a macOS user. Those who have difficulties(especially macOS users) can reach me out via DM. I will be trying to help.
  28. Hi there, folks! Anyone could potentially help me to get pair or two of those keys for a small donation? I dont have enough skills to get them, but i definitely need them.
  29. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    You can get them for free
    In case that wasn't clear enough: check my signature
