Page 16 of 29
FirstFirst ... 6 14 15 16 17 18 26 ... LastLast
Results 451 to 480 of 848
  1. Image
    [Attachment 76255 - Click to enlarge]
    Not sure what I did wrong here I'm lost
    Dec 2023
    England
    Looks like you need to downgrade the py module "protobuf"
    pip uninstall protobuf
    Y
    pip install protobuf==3.20.1
  3. Hi,
    Being new to this world, I've followed this guide and had fun learning a whole new language and a ton of fun stuff along the way, but haven't managed to get any keys generated.
    On both Windows 11 and a MacBook (Apple chip) I've got as far as having the emulator running, having Frida and the Frida server running, and talking to each other, but when I go to the sample video site or others (I tried BBC/ITVX) I don't get the two files being created. On the sample site, it does show as being Wildvine being used.
    The one thing I have had to do on both systems is to downgrade protobuf to 3.20.1 as documented here in this thread to get dumper working. Would that be the cause or is it something else I've missed? I saw another post here from A_n_g_e_l_a regarding getting protobuf working. I did try this on the Windows box, but got into trouble with some c++ compiler flags specific to Windows that I didn't want to tackle unless I had to (I haven't tried doing it on the Mac yet).
    Any sage words of wisdom, or should I carry on trying to get pywildvine, dumper and protobuf working happily together?
  4. Originally Posted by thundertwonk View Post
    Hi,
    Possibly a stupid question, but you did run "python dump_keys.py" before playing the video on bitmovin (or w/e), didn't you? Asking because I see no mention of it in your post.
    Protobuf 3.19.3 recently worked wonders for me. Also pywidevine has got nothing to do with dumping CDMs. You might also want to give a shot to this dumper.
  5. Possibly a stupid question, but you did run "python dump_keys.py" before playing the video on bitmovin (or w/e), didn't you? Asking because I see no mention of it in your post.
    I sure did, but good question.
    I tried that dumper and had no luck either.
    2024-01-23 04:40:01 PM - main - 32 - INFO - Connected to Android Emulator 5554
    2024-01-23 04:40:01 PM - main - 33 - INFO - Scanning all processes
    2024-01-23 04:40:01 PM - main - 39 - INFO - Functions hooked, now open the DRM stream test on Bitmovin from your Android device! https://bitmovin.com/demos/drm
    Nothing gets created after opening the demo URL and playing the video.
  6. Originally Posted by thundertwonk View Post
    What Android version are you trying to dump from? Is it possible that you're using a non-Google APIs image?
  7. Originally Posted by thundertwonk View Post
    Had that issue. Need to run Android Pie.
  8. What Android version are you trying to dump from? Is it possible that you're using a non-Google APIs image?
    I used a Pixel 6 from the Android Studio so I'd assume that was as Google as it gets? It used the default of Android 14.
    I can try with 9 / Pie and see if that makes a difference.
    Edit: Actually, I missed that part in the instructions. It does say to use Pie.
  9. Originally Posted by thundertwonk View Post
    And that worked. At least it generated the files. Now onto learning something else new... what to do with them
    Thanks for the support.
  10. once you have 2 files i m new at this drm thing
    how to convert to key or kid
    any help would be appreciated
    any next guide
  11. try the other sticky posts... they are pretty much guides to the whole process
  12. I think I followed the guide perfectly, but it doesn't seem to work for me. Both command prompts are open both of them are on this step
    When I go to https://bitmovin.com/demos/drm nothing happens. The video plays fine, but above it it says "Detected (chrome icon), using NO DRM. I don't know if that has anything to do with it or not.
  13. Originally Posted by fma15 View Post
    Yes, that's definitely a problem, it should be using WideVine. Are you by any chance running a non-Google APIs image?
  14. I don't think so. I'm using a Pixel 6.
    If I scroll down it says EME is not supported by your current browser.
  15. Originally Posted by fma15 View Post
    If I were you I would try different sites like: https://www.nuevodevel.com/nuevo/showcase/drm
    And/or another browser like Firefox.
  16. Originally Posted by white_snake View Post
    Thanks! The other site worked.
    Jan 2024
    Slovakia
    I'm asking for help
    I installed on my Win11 android 12 x86_64 pixel6
    But my installation always ends up with a picture
    Where is the problem?Image
    [Attachment 76564 - Click to enlarge]
  18. Originally Posted by ghost66 View Post
    I'm asking for help
    Do you have Python installed? https://www.python.org/downloads/windows/
    Jan 2024
    Slovakia
    I have python 13.12.1 _amd64
  20. Originally Posted by ghost66 View Post
    It doesn't look like you have pip installed though, which is weird. See here: https://pip.pypa.io/en/stable/installation/
    Jan 2024
    Slovakia
    Thank You... now it's okay
  22. Member
    Jan 2024
    Slovakia
    [Attachment 76590 - Click to enlarge]
    I stayed at this step
    Where do I make a mistake?
  23. Fixed had another adb.exe in path from another programme
  24. Originally Posted by ghost66 View Post
    It's the same thing as before, Windows can't find your python executable. You have to add its location to the PATH.
  25. Can I create multiple phones and create multiple keys I'm assuming you can unless its via ip ?
  26. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    I have dumped hundreds from Android Studio, all on the same PC. So yes, it works
  27. Do you use the same Vm for each set of keys or new vm each time
  28. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    with VM you mean Android AVD?
