I have a video I'm trying to de-interlace a TV series using VirtualDub2/AviSynth+ with QTGMC installed, and do a final upscale with Handbrake to H265 1080p 59.94FPS.
The source is from a DVD video - mpeg2 720x480 interlaced 29.97FPS NTSC YUV 4:2:0
This is the avs script I'm running:
SetFilterMTMode ("QTGMC", 2)
FFMPEGSource2("Episode 480i.mkv")
AssumeTFF()
QTGMC(preset="Slower", SourceMatch=3, Lossless=2, EdiThreads=4)
Crop(0,0,0,-2)
LanczosResize(720,540)
Prefetch(14)
I'm exporting the episodes to Lagarith YV12 (720x540@59.94fps) mkv and then upscaling them to H265 1080p using Handbrake.
However, I noticed an episode seems to have encoding errors from using QTGMC. At 2 random points in the video, approximately 1-4 seconds have a few frames between that are corrupted and seem to jump back and forth as if they were encoded out of order.
To check, I ran a regular de-interlace in VirtualDub2 using Yadif DFR TFF, Crop (Bottom 2), and Resize (720x540,Lanczos) and it doesn't happen when de-interlacing that way. It's almost as if QTGMC isn't handling the frames' order correctly. I'm not sure why the Yadif would be fine but QTGMC wouldn't.
I've spliced together the corrupted frames in the QTGMC video with the YADIF frames for now but it's definitely noticeable, is there a way to check the source for corrupted frames?
What could I do to fix this from happening? I'm just worried that other episodes will have problems and I won't notice until I watch them, and I've already finished a decent amount of episodes.
Edit: Fixed! I downloaded a new copy of the episode that was having issues and it seemed to have solved the problem. Must've been some file corruption or something.
AviSynth QTGMC to fix interlacing artifacts on progressive video.
By Sandfly in forum RestorationReplies: 22Last Post: 9th May 2023, 20:40 -
I-frame cutting sometimes results with video start at previous I-frame.
By TempUser_ in forum EditingReplies: 3Last Post: 25th Oct 2021, 01:40 -
Any Faster Way for De-interlacing Using QTGMC?
By dellsam34 in forum Video ConversionReplies: 93Last Post: 23rd Dec 2020, 20:05 -
Stuttered video with 50fps. It seems that every second frame. QTGMC.
By blink182 in forum Video ConversionReplies: 8Last Post: 10th Feb 2020, 13:28 -
struggling to encode DVD rips with QTGMC, frame rate problems?
By Statick777 in forum RestorationReplies: 11Last Post: 11th Jun 2018, 12:27
