    Feb 2006
    England
    Hello
    I don't know if this is the right forum. I apologise if not.
    I have taken 1000s of images off my iPhone and want to see their aspect ratios. I can sort them in windows by dimension etc, but not aspect ratio. Most of them are 4:3, which is the ratio I want. I want to be able to see which ones aren't 4:3 so I can edit them. Is there a quick way of doing this and seeing aspect ratios without having to do the math for each and every one?
    Ani
    Jagabo, please do not reply to this post. Thank you.
  2. You can use Python,
    you define:
    path to mediainfo
    name of directory
    searched aspect ratio
    extension for those files
    then one subdirectory will be created with media files (and those extensions) that have desired aspect ratio and other directory with rest of those files of the same extension
    from subprocess import Popen, PIPE
    import json
    from pathlib import Path
    import shutil
    #https://mediaarea.net/en/MediaInfo/Download/Windows
    MEDIAINFO = r"F:\tools\MediaInfo_CLI_22.09_Windows_x64\MediaInfo.exe"
    DIRECTORY = r"F:\testing aspet ratio for images\images"
    EXTENSION = "PNG"
    SEARCHED_ASPECT_RATIO = 16/9
    generator_of_paths = Path(DIRECTORY).glob(f'*.{EXTENSION}')   #generator is a better choise as oppose to using list
    dir_searched_ar = Path(DIRECTORY) / 'searched_ar_files'
    dir_searched_ar.mkdir(parents=True, exist_ok=True) #creates that subdirectory if it does not exist
    dir_rest = Path(DIRECTORY) / 'rest_of_files'
    dir_rest.mkdir(parents=True, exist_ok=True)
    for path in generator_of_paths:
        cmd  = f'"{MEDIAINFO}" --Output=JSON  "{path}"'
        p = Popen(cmd, stderr=PIPE, stdout=PIPE)
        stdout, stderr = p.communicate()
        data = json.loads(stdout)  #conversion from stdout(it is json format), to python's dictionary object
    ##    print(json.dumps(data, indent=2)) #use this, it prints pretty, formatted, to orient yourself in that dictionary
        width =  data['media']['track'][1]['Width']  #[0] means general section, [1] is for file properties if image or video
        height = data['media']['track'][1]['Height']
        ar = int(width)/int(height)
        if SEARCHED_ASPECT_RATIO-0.1 < ar < SEARCHED_ASPECT_RATIO+0.1:
            shutil.copy2(path, dir_searched_ar)
        else:
            shutil.copy2(path, dir_rest)
    [Attachment 68274 - Click to enlarge]
  3. Put this in a batch file in a folder full of jpg images and it will create a list of all those with exactly 4:3 AR:
    @echo off
    del 4x3.txt
    for %%F in (*.jpg) do (call :CHECK_AR "%%~nxF")
    goto :END
    :CHECK_AR
    "G:\Program Files\MediaInfoCLI\MediaInfo.exe" --inform=Image;%%Width%% "%~dpnx1" > "test.txt"
    set /p width= < "test.txt"
    "G:\Program Files\MediaInfoCLI\MediaInfo.exe" --inform=Image;%%Height%% "%~dpnx1" > "test.txt"
    set /p height= < "test.txt"
    set /a arw=%width%*3
    set /a arh=%height*4
    if %arw% EQU %arh% echo "%~nx1" %width%x%height% >>4x3.txt
    EXIT /B
    :END
    del "test.txt"
    The output will be in a file called 4x3.txt:
    "DSCN0059.JPG" 2048x1536
    "P1010035.JPG" 2304x1728
    Other files in the same folder were not 4:3.
    You will need to change the path to the CLI version of MediaInfo.
  4. if just needing a list, as jagabo gets, using python, you can just use:
    EXTENSION = "JPG"
    SEARCHED_ASPECT_RATIO = 4/3
        w, _ = Popen(f'"{MEDIAINFO}" --inform=Image;%Width%  "{path}"', stdout=PIPE).communicate()
        h, _ = Popen(f'"{MEDIAINFO}" --inform=Image;%Height%  "{path}"', stdout=PIPE).communicate()
        w = int(w.decode())          #stdout is in bytes, needs to be decoded to string first
        h = int(h.decode())
        if SEARCHED_ASPECT_RATIO-0.1 < w/h < SEARCHED_ASPECT_RATIO+0.1:
            print(f'{w}x{h}, {path.name}')
  5. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    XnViewMP you can check and sort by ratio
    Feb 2006
    England
    Thank you guys so much! Merry Christmas!
