Hi guys! New member here. I registered because I was hoping someone on the forum might know of a way to fix this.
This is probably kind of a stupid predicament to be in, but anyway: a while back, my Blu-ray writer seemed to be acting a bit unstable when I was ripping some CDs to my laptop. In retrospect, I'm thinking the problem might have been that the USB cable was getting worn down and needed to be changed. Right now, however, that's irrelevant because of this bigger problem...
Looking for solutions online, I came across a website with different "fixes", where one of the suggestions was to uninstall and reinstall the drive for the BD writer, to see if that might improve performance. In theory (at least according to the site), the drive should re-install itself once I plugged the Blu-ray writer back in. Here's the problem, though: the drive DIDN'T re-install itself afterwards, and now I have no idea how to get it re-installed and get the BD writer working again. It still gets power whenever I plug it into the laptop, but it no longer shows up under 'Devices and drivers'. And needless to say, it doesn't play any discs when I insert them.
The Blu-ray writer is an ASUS Blu-Ray Writer SBW-06D2X-U. My laptop is an ASUS ZenBook Pro UX550VE 15.6".
Anybody have any ideas? I feel like there should be a simple solution to this, but I haven't found it anywhere. It shouldn't be THAT difficult to get the drive for a piece of hardware back after you uninstall it for whatever reason.
Results 1 to 21 of 21
Look in the control panel/device manager and see if there is an error there.If there is then delete the error and see if it works that way.Last thing you can do is a system restore the day before it happened.
Did you manually install a driver when you first installed this blu-ray writer?
Unplug the device.
Open an Admin command prompt and enter these two commands
When the device manager opens, select View/show hidden devicesCode:set devmgr_show_nonpresent_devices=1 start Devmgmt.msc
Expand DVD/CDROM drives, Portable devices, Universal serial bus controllers, in each case delete any occurrences
corresponding to the device -
I can't remember whether I manually installed a driver back when I first installed the BD writer. It was over four years ago. All I recall is that it went quickly and easily.
I tried following your instructions here. But I'm wondering... how do I know which occurrences in the device manager are corresponding to the BD writer? For instance, here is all the stuff listed under "Universal Serial Bus controllers":
I'm also wondering what the deletion of the occurrences is meant to accomplish. Is the idea that it will "reset" everything so the writer can afterwards be re-installed from scratch? -
Yes that was the idea. I don't see any candidates there,
Mass storage device might be usb sticks you inserted before.
Did you try zing269's suggestion to see if you have initio device class? -
I did look at zing269's suggestion as posted here...
...but I must admit I'm a bit uneasy about uninstalling the "Initio Default Controller" under Initio Combo Device Class, which is what that guide suggests. (Yes, I do have that in my Device Manager.) It sounds kind of important. And uninstalling something that I thought would re-install by itself is what got me into this mess to begin with. -
How did you uninstall it ? Delete it from device manager?
Proper way would have been to go through windows settings.
Is the initio device greyed out as the mass storage devices are above?
That means it's not in use at the moment.
Somebody had similar issue here
https://answers.microsoft.com/en-us/windows/forum/all/initio-combo-device-driver-where...9-d3c045037416 -
What i would do is delete all the unknown usb devices since they all fail.
Yeah, I'm 99% sure I uninstalled it through Device Manager. If I recall, I used the method "Reinstall Your Blu-ray drivers" in this guide: https://www.driversupport.com/knowledge-article/your-blu-ray-player-is-not-recognizing...iscs-now-what/
The website made it sound very straightforward... yet it wasn't, when I tried to get it working again.Reinstall Your Blu-ray drivers
If updated drivers are not doing the trick, try reinstalling your drivers. A fresh driver install could help repair corrupted Blu-ray drivers. Here’s how:
1. Go to the Start menu and Search for Device Manager
2. Expand the DVD/CD-ROM drivers tab
3. Right-click your Blu-ray and select Uninstall Once you restart, Windows should install the driver automatically.
What would be the "proper way" to uninstall a BD writer through Windows settings?
Yup, it's greyed out. -
Try the following:
download this
https://www.uwe-sieber.de/files/DeviceCleanup.zip
Unzip to any location.
Start the windows device manager and delete all DVD-Player/BR-Player Drives listed.
Don't reboot.
Right-click Devicecleanup.exe (select the correct version for your operating system), start as administrator.
All unused devices are displayed.
Delete all entries except those from unconnected printers that you still want to use.
Restart your computer.
Plug in your external USB BR drive. It should now be automatically detected and correctly installed. -
I uninstalled the Initio Default Controller (with the BD writer plugged in), but it didn't help any. The only difference is that now, the BD writer is showing up under Universal Serial Bus controllers as "USB Mass Storage Device". And it has an error code, as can be seen here:
Uninstall it and restart your laptop.
Try the burner on another computer to rule out that it's faulty.
I don't have another computer to try it on. But I'm 99% sure the problem is that the writer doesn't want to re-install. Under Events (in USB Mass Storage Device Properties), it also says that the device requires further installation.
try selecting update driver and see if that solves your writer issue - https://appuals.com/how-to-fix-device-requires-further-installation-on-windows-10/
The same thing happened to me 2 months ago. On my computer, there are Nvidia drivers for all USB ports.
For some reason, the USB ports stopped working as they should.
So I contacted Nvidia support and they said to reinstall GeForce Experience, then it worked. Don't know how it is with your USB ports but as I said mine started working after that. -
This has happened to me 2x in the past couple of months. Here is what got me up and running. I had to edit the registry.
https://support.microsoft.com/en-us/topic/your-cd-or-dvd-drive-is-not-recognized-by-wi...8-cf9cc38ca53e
4K UHD Blu Ray Remux to Blu Ray (regular) for burning
By Damirko1981 in forum Authoring (Blu-ray)Replies: 9Last Post: 9th Apr 2025, 20:04 -
Visio Blu Ray player vbr120 unable to read Blu ray discs
By juntjoo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Sep 2020, 13:02 -
LG blu ray writer and verbatim BD-R
By mickmars in forum DVD & Blu-ray WritersReplies: 12Last Post: 9th May 2020, 21:45 -
Blu Ray blank disc issue - disc or writer?
By Damirko1981 in forum MediaReplies: 1Last Post: 10th Oct 2019, 14:44 -
Can a Blu-ray player play Blu-ray video burned on a DVD?
By digicube in forum Blu-ray RippingReplies: 2Last Post: 16th Jan 2019, 02:11
