  1. Hi,
    I have tryed to learn to use FFMPEG but I have difficult with the program to use...
    I don't want type command line, so I have downloaded FFQueue.
    I haven't understud where and how to insert commands, can you help me to begin, please?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Just use Handbrake to convert/encode video.
  3. I don't need to convert video, for this I use ShanaEncoder.
    My goal is to learn coding with FFMPEG to write a queue demuxer/muxer for SE, and I have problems because the code line is splitted in many fields in the paramenters window...
    If I 'm not able to do this, I want release the same job in FFQueue.
    I have found this tutorial:
    https://lukas.zapletalovi.com/posts/2021/demux-mux-and-cut-mp4-in-ffmpeg/
  4. Originally Posted by Antonio1989 View Post
    Hi,
    AND
    Is too me contradictory...
    Not sure how to help you as ffmpeg is command line type program...
    Perhaps this can be more helpful https://trac.ffmpeg.org/wiki/WikiStart
    Anyway you should be more familiar with ffmpeg documentation located at https://ffmpeg.org/documentation.html
  5. I know what you mean...
    I don't want use anymore the old ms-dos windows (it's too slow).
    The perfect program for me is one where, in a gui, I have to insert only the command and all the other functions are visual.
  6. Originally Posted by Antonio1989 View Post
    Since Windows NT there is no MSDOS in Windows, alternatively to CMD you may use PowerShell and in fact both environments are faster than GUI.
    So there is plenty of GUI's for ffmpeg, and technically i never use command line to run ffmpeg, instead using batch (script) with many commands inside - this work as single command and you can even drag & drop so in fact no commands required.
    This is most convenient way of working with ffmpeg IMHO. I can't imagine to put all stuff like bellow in command line without batch:
    ffmpeg -re -y -hide_banner -loglevel 8 -stats -f lavfi -i "color=c=gray:s=hd1080:r=50:d=-1,drawtext='fontsize=136:fontcolor=black@0.8:box=1:boxcolor=white@0.5:boxborderw=16:fontfile=blah.ttf:text=%{localtime\\: %d\\\\\\/%m\\\\\\/%y %H\\\\\\:%M\\\\\\:%S }:x=(w-tw)/2:y=2*th+(h-th)/2',drawtext='fontsize=136:fontcolor=white@0.8:box=1:boxcolor=black@0.5:boxborderw=16:fontfile=blah.ttf:timecode=''00\\:00\\:00\\:00'':r=50:x=(w-tw)/2:y=(h-th)/2',drawtext='fontsize=136-64:fontcolor=white@0.8:box=1:boxcolor=black@0.75:boxborderw=16:fontfile=blah.ttf:text='blahblah':x=(w-tw)/2:y=th',scale='720:576:sws_flags=bilinear:sws_dither=0:in_range=1:out_range=1',setdar=dar=16/9,tinterlace=mode=interleave_top,format=pix_fmts=yuv420p,setpts=PTS-STARTPTS" -c:v mpeg2video -profile:v 4 -level:v 8 -mpv_flags +skip_rd+strict_gop -q:v 4 -maxrate:v 14999K -bufsize:v 1835k -flags:v +ilme+ildct+cgop+low_delay+qscale -slices 4 -thread_type +slice+frame -dc 10 -intra -g 1 -bf 0 -top 1 -non_linear_quant 0 -alternate_scan 1 -seq_disp_ext 1 -sc_threshold 2G -me_method 0 -motion_est 0 -subq 0 -mbd 0 -precmp zero -skipcmp zero -ps 1316 -color_primaries 5 -color_trc 5 -colorspace 5 -color_range 2 -an -dn -sn -f mpegts -start_at_zero -muxrate 44000588.0 -mpegts_original_network_id 3 -mpegts_transport_stream_id 3 -mpegts_service_id 3 -mpegts_pmt_start_pid 32 -mpegts_start_pid 64 -streamid 0:512 -metadata "service_provider=blahblah" -metadata "service_name=blahblah" -tables_version 0 -mpegts_service_type 0x01 -y "udp://232.0.35.1:1000?pkt_size=1316"
    Mar 2011
    Nova Scotia, Canada
    +1. Beginners have a hard enough time learning encoding with handbrake anyway, video encoding is complex.
  8. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    +1. No GUI for me, command line preferred; if command line is too complex, write a batch script
