Results 1 to 30 of 51
    Dec 2020
    Germany
    Hello,
    just for confirmation - if I understood right, they all do the same thing: transfer the DV stream from the cam and packing it into either a DV-AVI type 1 or DV-AVI type 2.
    But are there any big noticeable differences between files produced by the 3?
    Which one of the listed programs does the most basic job (with no extra stuff) and is easy to configure and best performing on an old PC (Pentium M 1,86GHz 800MHz, 1GB RAM, Win XP, Laptop)?
    DVIO has the least adjustable settings, ScLive the most - but which one to use? All the programs work with my JVC camera, but I've mostly used WinDV before.
    I plan to re-rip all my MiniDV tapes so I want to be sure before the camera dies (it already shows errors from time to time and the mech sounds really crippled when rewinding and ff-ing), but it still plays perfectly.
    May 2005
    Australia-PAL Land
    If they all work on your computer, and they all produce a 13gb DV codec AVI (assuming PAL), you should use the one that gives you the most control, although it only takes a few clicks to set up WinDV and Scenalyser. Scenalyser is the most capable, post-capture, but if that wasn't a consideration (say if you're taking your captured DV-AVIs into a separate editor) then WinDV would be my choice (not having used DVIO). Of course, if you want to manipulate your DV files after capture (eg rough trims, joins), you can always use Scenalyser.
    I suppose the question should be asked: why are you re-ripping them?
    Dec 2020
    Germany
    With WinDV I have always the feeling that it does not record from the first frame on the tape but starts too early and then I get dropped frames or a bit too late.
    Also, what are the reccomended settings?
    Yeah, I just want the raw DV streams from the tape.
    Lost some of the original files and I don't remember what settings + programs I used.
  4. Capturing Memories dellsam34's Avatar
    Jan 2016
    Just get familiar with Sclive, The best, you won't regret it.
    Dec 2020
    Germany
    What are the benefits to WinDV?
  6. Capturing Memories dellsam34's Avatar
    Jan 2016
    More stable streams, better options.
  7. Member Skiller's Avatar
    Oct 2013
    Germany
    My vote goes to Sclive as well, for the named reasons.
    This isn't the fault of WinDV, but a failing of the DV transfer method itself.
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    a 10 second roll-in and roll-out can help with any type of video recording.
  10. Member DB83's Avatar
    Jul 2007
    TBH
    Never heard before this thread of DVIO
    Never had an issue with WinDV
    IMHO ScLive simply complicates the issue of a 1:1 transfer of what is on a DV tape
    Of course both the latter (never used the former) can record either in Type 1 or Type 2 DV. But as LS states (and I will always not agree with him) that any transfer is a marriage between hardware ,software and OS. And in any marriage, 2 is company, 3 is a potential divorce
    Dec 2020
    Germany
    Okay, so basically WinDV is simpler and if I want more functionality I should use ScLive?
    What would be the best settings for WinDV?
  12. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    for WinDV
    1. Set Discontinuity Threshold to 0 for a non-stop file making
    2. For Max AVI set high as can (1000000)
    This will ensure that you get 1 big avi file.
    Hit the "Config" button to get these options.
    Choose a Type 1 AVI
    Store the interleaved data as one stream in the AVI file. This is known as a type-1 file.
    Split the interleaved data into separate audio and video streams. This is known as a type-2 file.
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
  13. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Same for me.
  14. Also fan of ScLive here,
    if you plan to edit those DV footage's, it is a must to capture into clips by scenes (as you recorded), and those clips have names as datestamp (do not remember if that is a default settings or you have to select it). This way you always know when each clip was recorded. If editing, selecting all in a directory and dropping it into videoeditors timeline, would perfectly work. Clips will be lined up in the same order as they were recorded. You simply delete unwanted clips (they always are, or make them shorter), then you can export DV avi again and all will be done without re-encoding, same quality as was captured (Dv avi is I-frames only).
    SClive also works unbelievably well when you look for a particular scene in Dv avi from your history. Because you just load it, navigate into a directory (make a habit to capture each tape to separate directory named by date stamp), then you can see videos and moving scroll bar down or up looking for particular color pattern and visual , you will know when you try it. You will find your clip in no time. At the same time scrolling a clip horizontally , viewer would update a frame, so no problem to find a scenes in longer or long clip as well.
  15. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    yes, very important when you need to recapture a segment because DV concealment errors or dropouts (tape indexing)
    Dec 2020
    Germany
    Okay, any special things worth noting when using ScLive?
  17. I am trying to transfer DVs, exploring all the options as of this morning… none are without their own issues but so far SClive seems to be the most configurable. It runs in windows 11 and the worst thing I can say about this is that it doesn’t seem to recognize my RAID array as a drive with usable space, so I have to capture to my C drive first. Also, the preview is a bit stuttery and annoying to watch.
    There is a utility called “DVgrab” for Linux that I think may be more robust but I’m not sure how to possibly run it in windows.
  18. Member
    Jan 2023
    Shanghai China
    all DV capturer is doing one job as a data backup machine.
    they just copy the tape data via 1394 data link.
    so, if no drop, all the quality should be same since the digital data on DV tape is same.
    a DV camcorder's logic is same as a DDS backup machine. I remember in early 21st century there is a software can adopt a DV camcorder to backup normal PC data via 1394 port.
  19. Originally Posted by ltfmaz View Post
    How I wish there were a DDS-style drive that could simply read out the data from a tape. none of this error-ridden real-time playback capture over firewire nonsense!
    Unfortunately given existing methods of transferring the data there is no way to know for sure it is done "correctly" - ie. no corruption of the data.
    I transferred one MiniDV tape yesterday (using scenalyzer), and only happened to notice a glitch in playback because I was babysitting the unit while the transfer was going. Once it was done, i rewound to that spot on the tape and of course, no glitch. and of course, the software didn't report any errors or dropped frames either.
    Everything's perfect! Everything's fine!
    I'd say it was an hour of my time wasted, but in reality it's 2 hours of my time wasted. Because now the tape will need to be transferred again.
  20. Capturing Memories dellsam34's Avatar
    Jan 2016
    If extracting DV from a tape is that simple it wouldn't have a whole project designated to it called DV rescue project.
  21. Originally Posted by dellsam34 View Post
    In all my research I haven’t found any suggestion or even a mention of DV rescue. Thank you for the heads up, I will be trying this software out immediately.
  22. Member
    Jan 2023
    Shanghai China
    correct, seems there is no DDS style machine for miniDV tape.
    but in your story, sometime when OS try to overlay graphic to VGA memory, there might be error occur due to system resource problem. have you ever replay the captured video file on your PC? it may ok though there was a realtime issue on screen then.
    and more, sometime the drum is not in perfect condition. one time error reading is not seldom. so we need clean the drum timely. according to the user manual of some professional DV recorder the drum should be cleaned weekly.
  23. Originally Posted by ltfmaz View Post
    Yes, the visual glitch is unfortunately in the transferred file as well, but I did notice it happening during playback on the actual unit’s LCD. During that one instance anyway.
    The head on this Sony SHOULD be new and have less than an hour on it. emphasis on the should. I don’t particularly trust the person who I had service this unit but that’s an entirely different issue altogether…
    I’m really interested in trying DVrescue after learning about it now - it seems to have very robust low level error detection, and the software documentation indicates that it can shuttle the tape back and retransfer portions of video where it detects issues - if I’m not misunderstanding it entirely? Seems like it can’t perform captures in Windows yet though.
  24. Member
    Jan 2023
    Shanghai China
    Yes, I am also looking forward to trying DV rescue in near future..... thanks for the information provider: @dellsam34
    and, just a suggestion, have you noticed that the output video color from S-VIDEO is much broader than DV port. especially with SONY cam. so my local buddies are preferring S-video analog capture.
  25. Member
    Oct 2023
    U.S.
    Help - I'm flummoxed! Been using Scenalyzer Live to convert mini-DV to avi, via firewire. Worked fine until the heads on both my mini-DV cameras (Canon, Samsung) started going bad and dropping/pixellating audio and video. But I have 2 DV VCR's that work well, both Panasonic, an AG-DV1000 and an AG-DV 2000. But Scenalyzer will not recognized the VCR's as input devices. Scenalyzer can start and stop the tape, but will not show the video/audio or capture anything. I tried everything - changing settings as suggested by the developer of Scenalyzer, and uninstalling and reinstalling. Nothing works. I know the firewire out of the VCR's is working because I tested.
    So I downloaded winDV, and same problem. It will recognize the mini-DV cameras but not the VCRs. I bought a mini-DV to mp4 conversion device from ClearClick but the quality is not as good as converting to avi with Scenalyzer via firewire. Anyone had this problem or have a solution?
  26. Capturing Memories dellsam34's Avatar
    Jan 2016
    Make sure to select the deck as a player via firewire, Go through the manual settings.
  27. Member
    Oct 2023
    U.S.
    I did that in Scenalyzer and it doesn't make any difference, it still doesn't recognize/display/capture the video. Even though the Panasonic VCR is set as the input device. In winDV, I don't see any way to change the default setting of "Microsoft DV Camera and VCR".
  28. Capturing Memories dellsam34's Avatar
    Jan 2016
    No, in the deck menu, not the DV software.
  29. Member
    May 2005
    Australia-PAL Land
    There's nothing in this manual that indicates there is a manual output-select function.
