Hi everyone,
I installed a FireWire card into my Dell XPS, followed instructions from the manufacture (Syba) and used the Studio 1 Productions website.
I've not tried the "Legacy" drivers as it's said they are not used for Windows 11. The PCI card appears under "IEEE 1394 host controllers" as "Texas Instruments 1394 OHCI Compliant Host Controller" so this leads me to believe all is working ok.
I have a Panasonic NV-DS27 MiniDV camcorder which has an iLink DV out port which I'm attempting to use for capture. When plugged in and switched on the camcorder appears under "Imaging Devices" as "Panasonic DV Camcorder" and "Panasonic Vendor Unique Subunit".
I've attempted to capture via WinDV-1.2.3 but nothing appears on screen, WinDV does detect the camera though.
Adobe Premiere Pro also detects the camera but gives me audio with no video.
I've tried many different settings and have not been successful. I did at one stage in WinDV wiggle the DV cable a little and I got a brief frame of the video appear and then disappear which lead me to believe it could be the cable. I tried another cable and still no luck.
The fear is the DV port on the camera is shot and I have no other DV devices to test it. What do you guys think?
Any help is apprecitated.
Thanks,
Chris
If wiggling the cable displayed a few video frames, it's probably not a driver nor permissions issue. I would try the "wiggle" test a few more times, to see if you can narrow down the issue. Changing the cable didn't help, so the cable is probably fine - my guess at this point is that it's an issue with the port on the camera. Try wiggling gently while capturing where the cable attaches to the camera, and see if you can get it "just right" so that it makes a connection and allows your capture to complete.
I disagree. Given that DV audio and video data are interleaved together, if the audio bytes reaching the computer aren't dropping out, the video bytes shouldn't either.
If the issue is the Windows privacy setting, possibly the wiggling caused a reconnection event and a frame was briefly displayed "by mistake".My YouTube channel with little clips: vhs-decode, comparing TBC, etc. -
Windows privacy seem to be the only logical explanation, To be able to strip video only from the firewire stream it has to be decoded first, So WinDV is decoding the stream and Windows privacy setting is blocking the video.
Thanks everyone, I will check the Windows privacy settings.
I did more research and I believe it's to do with my Nvidia Graphics card / drivers. Really strange but I'm running two identical monitors and when I move the WinDV window around and place it inbetween the monitors I can see the preview while holding the mouse 1 button down keeping the "window drag" active.
I'm on latest drivers have an RTX 3080.
Best setup for MiniDV capture via Firewire?
By Rockdog in forum Capturing and VCRReplies: 2Last Post: 30th Dec 2021, 19:02 -
MiniDV to PC via firewire audio problem
By borntalent in forum Capturing and VCRReplies: 37Last Post: 3rd Apr 2020, 05:07 -
[SOLVED] Strange problem with capturing MiniDV via firewire - missing audio
By The Big Cheese in forum Capturing and VCRReplies: 18Last Post: 20th Mar 2019, 10:28 -
Suggested hardware specs when capturing MiniDV footage through Firewire?
By guy24s in forum Capturing and VCRReplies: 9Last Post: 26th Jan 2019, 04:16 -
Best free software to capture from a MiniDV camcorder WITH Firewire?
By kelemvor in forum Capturing and VCRReplies: 1Last Post: 6th May 2018, 21:48
