Page 9 of 14
FirstFirst ... 7 8 9 10 11 ... LastLast
Results 241 to 270 of 406
  1. Originally Posted by [ss]vegeta View Post
    Originally Posted by Ruben02 View Post
    It's really like reading Chinese symbols.
    Hey Ruben. Let's try to make those Chinese symbols a little bit clearer.
    Download these 3 files and put them in a folder on your desktop, or somewhere else of your choosing.
    https://we.tl/t-wv6kI36E7r
    Now, take a look at this code cedric posted above
    N_m3u8DL-RE --key e6c83af4f48b850ae3b8eced3ea32ba3:aa986877706b5955b131a80cd91b346d "https://remix.vrtcdn.be/content/vod/pl-c8bb635e-191d-4c9d-bcea-11400b8cc8fc/pl-c8bb635e-191d-4c9d-bcea-11400b8cc8fc_drm_29022c14-beb4-4072-845a-32e88726d5ce.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29" -M format=mp4
    This is a code that you put in cmd or command prompt. When you are inside the folder where the 3 tools you downloaded are, just go to the address bar above and type cmd and press enter. It will open the command prompt.
    Now here, you will paste that code.
    This code will automatically download and decrypt the video and audio and also merge them so you can have your final content (be aware though, the link in double quotes might have expired and you will have to get a fresh one... that's explained later in this post).
    Now, for each episode, you will have to change two parts of this code.
    The first is the KID:KEY. The KID:KEY in the code above is this
    so you will change this, to the next one of the list cedric posted.
    Now you will have to change the second thing, that's the MPD url.
    The MPD is the file that contains all the segments of the video/audio for the specific episode.
    You will have to find the MPD manually.
    You can find the MPD if you open Chrome, right click -> inspect. Go to the network tab. Type MPD in the filter box above and start playing your episode (it's important to have the network tab open BEFORE playing the video). A link should show up. Right click it, copy -> copy link address. This will give you the MPD link for that episode so just change it in the code.
    Hope there's nothing Chinese in what I wrote. Good luck!
    Hi, Could you or someone else maybe send me the 3 files that were in the wetransfer? I cannot find these anymore. Thank you so much.
  2. Originally Posted by Ruben02 View Post
    They were probably these ones
    https://www.transfernow.net/dl/20240327jDL7U987
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  3. Hi,
    could somebody generate the keys for the following as they are only avalable for 4 more days.
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a40-cartoon-bear/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a41-xxl-bear/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a42-neve...-by-its-cover/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a43-bear-glasses/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a44-bear...se-protection/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a45-zero-visibility/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a46-intensive-care/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a47-lemming-gum/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a48-lemming-juice/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a49-zen-bear/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a50-ctrl-alt-bear/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a51-lemming-bowling/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a52-mushroom-hunt/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a53-flying-bear/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a54-big-top-bear/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a55-elec...anger-lemming/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a56-bear-repellent/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a57-bear...ind-the-wheel/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a58-rolling-cabin/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a59-lemmings-plant/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a60-target-bear/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a61-northern-lights/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a62-tick-tock-bear/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a63-dreams-on-command/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a64-elem...tary-lemmings/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a65-bear-sitter/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a66-rainbow-moose/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a67-radar-bear/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a68-zorbing-lemmings/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a69-air-trafficking/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a70-a-le...gs-fairy-tale/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a71-slam...dunk-lemmings/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a72-uncouth-bear/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a73-pass...through-walls/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a74-eagle-spirit/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a75-rock-n-lemmings/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a76-hulking-lemmings/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a77-ancestral-bear/
    https://www.vrt.be/vrtmax/a-z/grizzy---the-lemmings/2/grizzy---the-lemmings-s2a78-hocu...cus-lemmingus/
    I've been trying to get them myself but can't seem to get the call to https://widevine-proxy.drm.technology/proxy to work. I get a 400 Bad Request back.
    I have a .wvd file created following the steps in https://forum.videohelp.com/threads/408031-Dumping-Your-own-L3-CDM-with-Android-Studio and I am using it with the script posted in https://forum.videohelp.com/threads/407962-download-from-VRT-MAX/page6#post2707935. The pssh that I use when calling this script is generated by the script posted in https://forum.videohelp.com/threads/407962-download-from-VRT-MAX/page2#post2675956
    but i have some questions about the scripts.
    On the first script:
    should there be specific headers set when doing the post?
    For the token in to body, for testing purposes I just took the value from the call the website is doing and didn't generate it myself. Does that matter?
    On the pssh script:
    that info is 2 years old. Is it still valid?
    In the script a global WV_SYSTEM_ID is used. What should that value be? And how to add it to the byte array? Now I used a generic Goolge value from https://github.com/Cronick/WV-System-ID-Overview/blob/main/Overview.csv and added it like this:
    pssh_box += b'7284'
    Thanks in advance
  4. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Well that was to be expected after basically a year
  5. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Originally Posted by Darsh View Post
    Hi,
    Thanks in advance
        "items": [
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 40 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E40 Cartoon Bear",
                "Keys": "511af8b72819321b8352880711664115:3bbce632876e8f3dcd29096fa8c12c03 ",
                "Metadata": "Grizzy & the Lemmings;serie;2",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-d31cfa5d-359c-4aa4-8a2a-71df8f9df1b8/pl-d31cfa5d-359c-4aa4-8a2a-71df8f9df1b8_drm_283b1278-20ab-4bba-9eb8-1b59618c4926.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/c18b74cc-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-d31cfa5d-359c-4aa4-8a2a-71df8f9df1b8/pl-d31cfa5d-359c-4aa4-8a2a-71df8f9df1b8_drm_283b1278-20ab-4bba-9eb8-1b59618c4926.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 41 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E41 XXL Bear",
                "Keys": "505bebb17d604388dda58becba0835f2:43fffd5e7148c48972a811bf588040cb ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-b3f15b2b-143e-4814-8081-bd23c4c1e48d/pl-b3f15b2b-143e-4814-8081-bd23c4c1e48d_drm_408d2f9b-58db-4b12-801d-44a06e72c782.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/c15326bb-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-b3f15b2b-143e-4814-8081-bd23c4c1e48d/pl-b3f15b2b-143e-4814-8081-bd23c4c1e48d_drm_408d2f9b-58db-4b12-801d-44a06e72c782.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 42 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E42 Never Judge a Bear by its Cover",
                "Keys": "f6707d5060184825e83d2f47f7f3f8d3:cf0b6105b3b3a89d715486091175340a ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-a23997b3-7ffc-4027-b7d6-b8e2e1ca7d9c/pl-a23997b3-7ffc-4027-b7d6-b8e2e1ca7d9c_drm_0857b644-a4c7-452e-bee3-0095bb7f2718.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/c137d68a-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-a23997b3-7ffc-4027-b7d6-b8e2e1ca7d9c/pl-a23997b3-7ffc-4027-b7d6-b8e2e1ca7d9c_drm_0857b644-a4c7-452e-bee3-0095bb7f2718.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 43 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E43 Bear Glasses",
                "Keys": "324b6510d69b9ee8b653dc864eb80f8d:2af618938d1dc1f8f92a92d1a7323bcd ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-454d4570-f151-4f9a-80b8-4cf5d5d780e2/pl-454d4570-f151-4f9a-80b8-4cf5d5d780e2_drm_782c76fb-07fd-4acb-9243-789b65ef2dfa.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/c104dfa9-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-454d4570-f151-4f9a-80b8-4cf5d5d780e2/pl-454d4570-f151-4f9a-80b8-4cf5d5d780e2_drm_782c76fb-07fd-4acb-9243-789b65ef2dfa.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 44 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E44 Bear under close Protection",
                "Keys": "ef9206418eb20fb73a50530710d406ae:b3d1eb5e762b56b89db900e273930dad ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-fe1b52e1-b29a-43e3-a166-83052b68ed17/pl-fe1b52e1-b29a-43e3-a166-83052b68ed17_drm_d4e49dc3-3d0e-4e24-84d1-2db23b3c8371.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/c0d989e8-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-fe1b52e1-b29a-43e3-a166-83052b68ed17/pl-fe1b52e1-b29a-43e3-a166-83052b68ed17_drm_d4e49dc3-3d0e-4e24-84d1-2db23b3c8371.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 45 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E45 Zero Visibility",
                "Keys": "63e96298e3015a6a16545c352e252190:111495b913270000d85d06b091233b42 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-a709c301-b93e-4ecc-b9a9-c03ece6ddc33/pl-a709c301-b93e-4ecc-b9a9-c03ece6ddc33_drm_74739d75-4e5a-42cc-9430-4b6ffae7fa6b.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/c0961847-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-a709c301-b93e-4ecc-b9a9-c03ece6ddc33/pl-a709c301-b93e-4ecc-b9a9-c03ece6ddc33_drm_74739d75-4e5a-42cc-9430-4b6ffae7fa6b.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 46 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E46 Intensive Care",
                "Keys": "e2269d3dc21813ac019cb780aecda68f:42898616a69342dd6ad7eb0e7757e6f1 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-451f0cd6-e8c2-4b3f-bd11-f9a929c8731f/pl-451f0cd6-e8c2-4b3f-bd11-f9a929c8731f_drm_79522e38-f6d0-4daf-bd04-9f6b276611f4.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/c070dd06-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-451f0cd6-e8c2-4b3f-bd11-f9a929c8731f/pl-451f0cd6-e8c2-4b3f-bd11-f9a929c8731f_drm_79522e38-f6d0-4daf-bd04-9f6b276611f4.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 47 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E47 Lemming Gum",
                "Keys": "341783e2d1e1d0b034b73e703456c666:af09bbb509ed0cde31460f8c1928ff6f ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-0b03d365-6a29-4522-994e-167998615932/pl-0b03d365-6a29-4522-994e-167998615932_drm_319f43e3-31c0-4185-80f6-1a3f5a6aa82b.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/c02ef205-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-0b03d365-6a29-4522-994e-167998615932/pl-0b03d365-6a29-4522-994e-167998615932_drm_319f43e3-31c0-4185-80f6-1a3f5a6aa82b.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 48 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E48 Lemming Juice",
                "Keys": "5a45291b66b5e6c86d121c69f4c960eb:42f0e437be5f8bf2627afefe2e880f9b ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-8a7766c7-83ba-45f6-b0c4-0d3dfa7bff6b/pl-8a7766c7-83ba-45f6-b0c4-0d3dfa7bff6b_drm_075ff559-2b74-4fd0-863d-cd3e8ff5811b.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bff4f644-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-8a7766c7-83ba-45f6-b0c4-0d3dfa7bff6b/pl-8a7766c7-83ba-45f6-b0c4-0d3dfa7bff6b_drm_075ff559-2b74-4fd0-863d-cd3e8ff5811b.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 49 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E49 Zen Bear",
                "Keys": "c403a1ce008440e98130ed4ae74deabe:6f28b46ad82e4b703176b25b89fc02af ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-3650e56c-a6fa-4626-b6ed-13be4d3b0204/pl-3650e56c-a6fa-4626-b6ed-13be4d3b0204_drm_af52f522-f615-4cc6-aff2-99b62bed87b4.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bfdab783-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-3650e56c-a6fa-4626-b6ed-13be4d3b0204/pl-3650e56c-a6fa-4626-b6ed-13be4d3b0204_drm_af52f522-f615-4cc6-aff2-99b62bed87b4.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 50 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E50 Ctrl+Alt+Bear",
                "Keys": "ee2154a4f8da77559e4dad04e3aca9d6:eee43b8c79273c25a22da25a370f37b9 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-356317b4-804d-488a-8ef6-db308ba06dd7/pl-356317b4-804d-488a-8ef6-db308ba06dd7_drm_1aa40838-28ff-4410-8c13-9d0c4bd7c908.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2024/02/09/571ffd49-c71c-11ee-b483-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-356317b4-804d-488a-8ef6-db308ba06dd7/pl-356317b4-804d-488a-8ef6-db308ba06dd7_drm_1aa40838-28ff-4410-8c13-9d0c4bd7c908.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 51 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E51 Lemming Bowling",
                "Keys": "5f28ed43087bcdf508f288aeb13c334c:229329aa30520fadb9dd4ad20675154f ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-6f582e92-e519-4d56-a88a-bbcaf02be7ff/pl-6f582e92-e519-4d56-a88a-bbcaf02be7ff_drm_3ec087a2-6925-4513-b5ca-750e772bba8e.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bf96d0b2-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-6f582e92-e519-4d56-a88a-bbcaf02be7ff/pl-6f582e92-e519-4d56-a88a-bbcaf02be7ff_drm_3ec087a2-6925-4513-b5ca-750e772bba8e.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 52 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E52 Mushroom Hunt",
                "Keys": "a30612ba7abe1355fc565f74b613b0d5:ca0b063d6bff4701427964f970147c2a ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-cb6ecd4e-5cb5-4958-8b7c-b88a852c16da/pl-cb6ecd4e-5cb5-4958-8b7c-b88a852c16da_drm_2339789e-4fe9-4d6e-a7da-34cc49ba4147.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bf6f4b81-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-cb6ecd4e-5cb5-4958-8b7c-b88a852c16da/pl-cb6ecd4e-5cb5-4958-8b7c-b88a852c16da_drm_2339789e-4fe9-4d6e-a7da-34cc49ba4147.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 53 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E53 Flying Bear",
                "Keys": "de8e17b6176f54a82e2befcba31fbf64:df644765af7bf6b0d9656ea847ddaed7 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-61b50157-0281-4cb2-bc50-b800a305facd/pl-61b50157-0281-4cb2-bc50-b800a305facd_drm_eb2db2e6-dc50-4f0f-af9f-e5a26bdc5377.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bf4184c0-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-61b50157-0281-4cb2-bc50-b800a305facd/pl-61b50157-0281-4cb2-bc50-b800a305facd_drm_eb2db2e6-dc50-4f0f-af9f-e5a26bdc5377.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 54 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E54 Big Top Bear",
                "Keys": "bde60eaacaaead55c4939009bdb81d44:20b1eca75053b7eeebeff5ca1a768a3b ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-c08d3757-0911-42fd-86fc-8538a3c1602f/pl-c08d3757-0911-42fd-86fc-8538a3c1602f_drm_376a8992-554d-47a4-8899-9e09cc3ca6e1.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bf1803bf-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-c08d3757-0911-42fd-86fc-8538a3c1602f/pl-c08d3757-0911-42fd-86fc-8538a3c1602f_drm_376a8992-554d-47a4-8899-9e09cc3ca6e1.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 55 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E55 Electro Ranger Lemming",
                "Keys": "a2491caa8f7316cd23c523784dd27533:7cc926e6c182d4311f7ae9ead98b3147 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-8948fb06-e6f1-4d02-ae07-208cb8ebd159/pl-8948fb06-e6f1-4d02-ae07-208cb8ebd159_drm_a09bde57-6186-4dde-b6ac-7168cdc16085.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bee078fe-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-8948fb06-e6f1-4d02-ae07-208cb8ebd159/pl-8948fb06-e6f1-4d02-ae07-208cb8ebd159_drm_a09bde57-6186-4dde-b6ac-7168cdc16085.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 56 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E56 Bear Repellent",
                "Keys": "42f233e655994105e597f50ae286f464:370a848ca5f3e368ec06eca93a76c6dc ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-f4844f1f-1417-4818-867c-178da9a65b01/pl-f4844f1f-1417-4818-867c-178da9a65b01_drm_31094ee1-87f6-468e-b1a3-a7f12a5228e1.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/be98737d-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-f4844f1f-1417-4818-867c-178da9a65b01/pl-f4844f1f-1417-4818-867c-178da9a65b01_drm_31094ee1-87f6-468e-b1a3-a7f12a5228e1.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 57 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E57 Bear Behind The Wheel",
                "Keys": "83eb9c2c586639a15337748b26096ede:eff6d3d1a4441c073bed8edb76433d87 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-771ff237-7d1f-4e68-8123-340683e2634c/pl-771ff237-7d1f-4e68-8123-340683e2634c_drm_688606e5-acc5-4f97-aa6a-a7e68466058e.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/be641d0c-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-771ff237-7d1f-4e68-8123-340683e2634c/pl-771ff237-7d1f-4e68-8123-340683e2634c_drm_688606e5-acc5-4f97-aa6a-a7e68466058e.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 58 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E58 Rolling Cabin",
                "Keys": "25692869e7f5b88132248132bc988194:37276bbfac019c3a875d7d425edc4c08 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-9e93d6da-0a08-4238-8136-b42a09b79f9d/pl-9e93d6da-0a08-4238-8136-b42a09b79f9d_drm_1cdeb174-1fb6-4195-b3cf-fd9c4add2164.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/be3767bb-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-9e93d6da-0a08-4238-8136-b42a09b79f9d/pl-9e93d6da-0a08-4238-8136-b42a09b79f9d_drm_1cdeb174-1fb6-4195-b3cf-fd9c4add2164.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 59 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E59 Lemmings Plant",
                "Keys": "39b0d9d2fbd30adcd589b834291f2d8d:437507692129b1db727ded2db8d86240 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-e8bffac1-a7b8-488d-8139-8a738e7a90ca/pl-e8bffac1-a7b8-488d-8139-8a738e7a90ca_drm_16392463-d2d7-4fee-855b-cd229f0e2d4b.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/be10f3fa-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-e8bffac1-a7b8-488d-8139-8a738e7a90ca/pl-e8bffac1-a7b8-488d-8139-8a738e7a90ca_drm_16392463-d2d7-4fee-855b-cd229f0e2d4b.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 60 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E60 Target Bear",
                "Keys": "9e15ff748bddc78e2eccb23b77673d16:5b75010c6806906da77db2a22039b486 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-227659f1-776a-48bb-95a9-de36ae7ec0b5/pl-227659f1-776a-48bb-95a9-de36ae7ec0b5_drm_fd831eb9-6e8d-4a5f-b866-3d95a0db3dc9.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bdd104c9-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-227659f1-776a-48bb-95a9-de36ae7ec0b5/pl-227659f1-776a-48bb-95a9-de36ae7ec0b5_drm_fd831eb9-6e8d-4a5f-b866-3d95a0db3dc9.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 61 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E61 Northern Lights",
                "Keys": "b6656a0cfab37a8729e105624ea2d0fd:49579e64b9ce03f2fbff5f27728fd879 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-539d0a2c-f477-426e-982d-bac5d3b9737c/pl-539d0a2c-f477-426e-982d-bac5d3b9737c_drm_41c06a87-a0cd-48bd-99db-8c4e10725008.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bdb23228-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-539d0a2c-f477-426e-982d-bac5d3b9737c/pl-539d0a2c-f477-426e-982d-bac5d3b9737c_drm_41c06a87-a0cd-48bd-99db-8c4e10725008.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 62 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E62 Tick Tock Bear",
                "Keys": "8bb954b3820a82bba2cc0960944ec31e:d8c08c181d65c56805413e3122423823 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-7079594f-bd1c-4f22-a888-08de651d76c3/pl-7079594f-bd1c-4f22-a888-08de651d76c3_drm_becd091e-1d66-48d0-818f-88a3c50b767e.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bd7920c7-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-7079594f-bd1c-4f22-a888-08de651d76c3/pl-7079594f-bd1c-4f22-a888-08de651d76c3_drm_becd091e-1d66-48d0-818f-88a3c50b767e.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 63 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E63 Dreams On Command",
                "Keys": "19e69fe931dbc26064ae1d190ba0e940:676c62ce416ea2bffcdcf151987a6ce9 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-f1f69526-56fa-49fe-b9fa-b1b13e8257f0/pl-f1f69526-56fa-49fe-b9fa-b1b13e8257f0_drm_fe5825a5-9ae2-4ab0-a957-cdeefa095ccc.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bd52d416-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-f1f69526-56fa-49fe-b9fa-b1b13e8257f0/pl-f1f69526-56fa-49fe-b9fa-b1b13e8257f0_drm_fe5825a5-9ae2-4ab0-a957-cdeefa095ccc.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 64 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E64 Elementary Lemmings",
                "Keys": "824f9612de963b8aa2f4d7ce69e70ae5:cc47d81e2d86b3f0b696db6eea550aa1 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-b55420c9-e66b-47fc-852d-91f7cea39fa8/pl-b55420c9-e66b-47fc-852d-91f7cea39fa8_drm_480d6e28-9f40-442f-ab08-fb0c6ad79c8b.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bd270925-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-b55420c9-e66b-47fc-852d-91f7cea39fa8/pl-b55420c9-e66b-47fc-852d-91f7cea39fa8_drm_480d6e28-9f40-442f-ab08-fb0c6ad79c8b.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 65 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E65 Bear Sitter",
                "Keys": "7655b6d18a0322b2fb511142afa88907:068e060cd75c50816f8168cf1805f61b ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-14bde3cc-1e13-4710-a94f-2822ccea2d48/pl-14bde3cc-1e13-4710-a94f-2822ccea2d48_drm_657abddd-f1e1-4124-8cdf-9166edac3669.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bcfc0184-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-14bde3cc-1e13-4710-a94f-2822ccea2d48/pl-14bde3cc-1e13-4710-a94f-2822ccea2d48_drm_657abddd-f1e1-4124-8cdf-9166edac3669.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 66 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E66 Rainbow Moose",
                "Keys": "1e09371e227ea9b67c62ebc3ce7ad973:d5baa40860b813b77fa1766161d65223 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-b34b4161-2774-4ee4-94cb-2ca60140c09f/pl-b34b4161-2774-4ee4-94cb-2ca60140c09f_drm_5fc32e07-9782-4416-ba73-ac8674ef5c05.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bcbcfcb3-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-b34b4161-2774-4ee4-94cb-2ca60140c09f/pl-b34b4161-2774-4ee4-94cb-2ca60140c09f_drm_5fc32e07-9782-4416-ba73-ac8674ef5c05.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 67 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E67 Radar Bear",
                "Keys": "cb3879b3e67b7b1d86b1a5e1fa7cf46e:edc3f572b10b310b58f751e0bd1d5020 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-58b970a3-a50f-4ff6-bee2-9dec71b4039c/pl-58b970a3-a50f-4ff6-bee2-9dec71b4039c_drm_5efbd829-902f-42f2-9916-9b89814c40aa.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/bca2e502-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-58b970a3-a50f-4ff6-bee2-9dec71b4039c/pl-58b970a3-a50f-4ff6-bee2-9dec71b4039c_drm_5efbd829-902f-42f2-9916-9b89814c40aa.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 68 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E68 Zorbing Lemmings",
                "Keys": "03c6c38d35566286b69589115ec85151:d532e29a7b8aa9fceecd358f16d17f25 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-cffdea90-0a1c-4594-b48e-ce6cc0edf8c7/pl-cffdea90-0a1c-4594-b48e-ce6cc0edf8c7_drm_2a64f156-2280-4e38-901b-6928e90120f2.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/b511a381-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-cffdea90-0a1c-4594-b48e-ce6cc0edf8c7/pl-cffdea90-0a1c-4594-b48e-ce6cc0edf8c7_drm_2a64f156-2280-4e38-901b-6928e90120f2.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 69 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E69 Air Trafficking",
                "Keys": "7161c1cac721cd851d2ba95ac8d469d6:148672c7ac4219b9606ea582fab925ca ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-589dbe93-45fa-44e6-9097-4b4b39efc2b2/pl-589dbe93-45fa-44e6-9097-4b4b39efc2b2_drm_db4b4f44-90b3-4a5b-a2ef-e265b00fae84.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/b4dab500-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-589dbe93-45fa-44e6-9097-4b4b39efc2b2/pl-589dbe93-45fa-44e6-9097-4b4b39efc2b2_drm_db4b4f44-90b3-4a5b-a2ef-e265b00fae84.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 70 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E70 A Lemmings Fairy Tale",
                "Keys": "30a4f821f93367751836e41c6287fa29:d8ae41d6a1bf1095b4395527c2ddfaad ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-7b00d03b-9ad5-48c9-bc21-e2f4bb3f84d9/pl-7b00d03b-9ad5-48c9-bc21-e2f4bb3f84d9_drm_15077c08-2b14-46af-b0b0-fc3967b50f7a.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/b4af864f-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-7b00d03b-9ad5-48c9-bc21-e2f4bb3f84d9/pl-7b00d03b-9ad5-48c9-bc21-e2f4bb3f84d9_drm_15077c08-2b14-46af-b0b0-fc3967b50f7a.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 71 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E71 Slam Dunk Lemmings",
                "Keys": "e5c23bb8ca70f6253e8db0c677e5bdee:4d6280ca0945dddbc8f5c07d1a3f5a7b ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-061662b9-0104-41b8-9b01-d55095a03cad/pl-061662b9-0104-41b8-9b01-d55095a03cad_drm_ea2a57b3-aa78-4250-9823-8eb3fe73cd0c.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/b47a1e6e-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-061662b9-0104-41b8-9b01-d55095a03cad/pl-061662b9-0104-41b8-9b01-d55095a03cad_drm_ea2a57b3-aa78-4250-9823-8eb3fe73cd0c.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 72 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E72 Uncouth Bear",
                "Keys": "281fb29b9528935afb12091268312e6d:e9b6e41c41081e75eb369b279b1a1bf2 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-bce344f5-0d9e-4a72-8a73-40ea39186439/pl-bce344f5-0d9e-4a72-8a73-40ea39186439_drm_e9028004-ca30-4d70-8203-8f02ba78ac1b.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/b452993d-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-bce344f5-0d9e-4a72-8a73-40ea39186439/pl-bce344f5-0d9e-4a72-8a73-40ea39186439_drm_e9028004-ca30-4d70-8203-8f02ba78ac1b.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 73 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E73 Passing Through Walls",
                "Keys": "5819a84f667c669dc019ad1537f8363a:c1388647b9233d3f26795fc0a81685a3 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-124b8c3f-658b-4600-bf61-cdcfccc7aa65/pl-124b8c3f-658b-4600-bf61-cdcfccc7aa65_drm_2fbf4b39-4bf2-44cb-8aae-9940ceb36508.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/b3f4e8dc-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-124b8c3f-658b-4600-bf61-cdcfccc7aa65/pl-124b8c3f-658b-4600-bf61-cdcfccc7aa65_drm_2fbf4b39-4bf2-44cb-8aae-9940ceb36508.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 74 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E74 Eagle Spirit",
                "Keys": "03db7718dbc95e8f9a912ed8f74e4237:3725182c8a3aacf1800c356fe5241370 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-69cd27f6-6449-490f-a36a-367f6dabbfae/pl-69cd27f6-6449-490f-a36a-367f6dabbfae_drm_753ca426-2455-4bc6-b799-f9dff7649496.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/b3c5746b-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-69cd27f6-6449-490f-a36a-367f6dabbfae/pl-69cd27f6-6449-490f-a36a-367f6dabbfae_drm_753ca426-2455-4bc6-b799-f9dff7649496.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 75 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E75 RocknLemmings",
                "Keys": "adcab6276c51de4db1cfc652cbc8d489:8bad48ba3a7043b122c43deb15ca4766 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-8071eeff-291f-45b5-8c87-dc0b2de67eff/pl-8071eeff-291f-45b5-8c87-dc0b2de67eff_drm_709eae4c-55a4-4783-bbc0-7d7a8eb64078.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/b37c0f5a-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-8071eeff-291f-45b5-8c87-dc0b2de67eff/pl-8071eeff-291f-45b5-8c87-dc0b2de67eff_drm_709eae4c-55a4-4783-bbc0-7d7a8eb64078.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 76 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E76 Hulking Lemmings",
                "Keys": "78eb935ba954bb6baf0fd62a05a9e1dc:f2fed29a2de3283adbbc01dae60d5f4a ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-986a7b5f-2e08-497d-8b34-2cc4cc02a7ab/pl-986a7b5f-2e08-497d-8b34-2cc4cc02a7ab_drm_b7008f3a-1bc2-41ab-b0ba-160ea80c5510.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/b3648fb9-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-986a7b5f-2e08-497d-8b34-2cc4cc02a7ab/pl-986a7b5f-2e08-497d-8b34-2cc4cc02a7ab_drm_b7008f3a-1bc2-41ab-b0ba-160ea80c5510.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 77 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E77 Ancestral Bear",
                "Keys": "0891af4858660d0dfbfade47b2a7c60e:28b1b1295e5125345401b90c75c9a62a ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-3af87f14-9cfa-44be-9d92-234bc50a9efc/pl-3af87f14-9cfa-44be-9d92-234bc50a9efc_drm_fd2ad330-e25e-45c0-96d5-a6c4081daf1f.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/b31e37e8-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-3af87f14-9cfa-44be-9d92-234bc50a9efc/pl-3af87f14-9cfa-44be-9d92-234bc50a9efc_drm_fd2ad330-e25e-45c0-96d5-a6c4081daf1f.ism/textstream_dut=1000.vtt"
                "Description": "Grappige animatiereeks over de beer Grizzy, wiens rustige leven in een Canadees natuurpark grondig verstoord wordt door een groep vervelende lemmings. Bekijk aflevering 78 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Grizzy & the Lemmings S02E78 Hocus Pocus Lemmingus",
                "Keys": "0caa4af56c045bb783982d5198588414:658970469e85576540b0b5818005913c ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-d7f1d175-6821-45fb-87fb-768a3960ebe7/pl-d7f1d175-6821-45fb-87fb-768a3960ebe7_drm_924474f8-d8c1-46bf-8781-1a4837396d96.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/11/30/b3049567-70ca-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-d7f1d175-6821-45fb-87fb-768a3960ebe7/pl-d7f1d175-6821-45fb-87fb-768a3960ebe7_drm_924474f8-d8c1-46bf-8781-1a4837396d96.ism/textstream_dut=1000.vtt"
  6. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Hi,
    I don't think it needs special headers, it's been a while since I've looked at VRT code so not 100% sure.
    I started out with using the token from the original request payload. It expires pretty quick though, so hurry when using that.
    On the pssh script:
    pssh_box += b'7284'
    Thanks in advance
    For VRT I always get the PSSH from the init.mp4 file instead of generating/calculating it. It works in 99% of cases, but I've had a couple weird ones where the PSSH did not match the one from EME Logger. init.mp4 PSSH is always correct.
  7. Originally Posted by iamghost View Post
    there is script for this, you will need your WVD to get it work
    cmd would be like
    VRTMAX-DL.py --wvd "C:/wvd.wvd "vrt video url"
    https://files.videohelp.com/u/301156/vrt.zip
    used firefox browser only
    Thanks for that iamghost!
    Question: does such a script exist for npo as well? That requests the keys with my own L3 CDM, decrypts and packages the content?
  8. Originally Posted by iamghost View Post
    cmd would be like
    Question: does such a script exists for npo as well? That requests the keys with my own CDM, downloads, decrypts and packages the content?
  9. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    cmd would be like
    There used to be a couple floating around but that was before they revamped their website.
    Check the Kodi plugins, they usually have valuable information on how to login and fetch information
  10. Originally Posted by [ss]vegeta View Post
    Thanks a lot!
    I tried to download, but I didn't succeed to manually find the MPD-url. This is what my screen looks like:
    [Attachment 78055 - Click to enlarge]
    I wanted to download these videos:
    https://www.vrt.be/vrtmax/a-z/frozen-planet/2/frozen-planet-s2a1/
    https://www.vrt.be/vrtmax/a-z/frozen-planet/2/frozen-planet-s2a2/
    https://www.vrt.be/vrtmax/a-z/frozen-planet/2/frozen-planet-s2a3/
    https://www.vrt.be/vrtmax/a-z/frozen-planet/2/frozen-planet-s2a4/
  11. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Thanks a lot!
        "items": [
                "Description": "David Attenborough gaat op ontdekking in ijskoude gebieden. Beginnen doet hij in Antarctica, waar keizerspinguïnkuikens aan het begin van de lente achtergelaten worden door hun ouders en hun weg moeten vinden door het gevaarlijke zee-ijs naar de verraderlijke wateren van de Zuidelijke Oceaan.  In de Himalaya gaat de meest donzige kat ter wereld jagen op gerbils en woelmuizen, terwijl in de noordelijke bossen van Noord-Amerika, Europa en Azië een Siberische tijger op zoek is naar zwarte beren. Bekijk aflevering 1 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Frozen planet S02E01 Frozen worlds",
                "Keys": "8c91ea9e6b975f3267d881d13c440e1b:f87431e1d4d9953249d1f2875d01d6a0 ",
                "Metadata": "Frozen planet;serie;2",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-60925ddc-fdb4-430e-b5ba-bd39bb1ed8b8/pl-60925ddc-fdb4-430e-b5ba-bd39bb1ed8b8_drm_ece7e8dd-a362-49ce-a8d5-ca06073ec83d.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/09/16/7e394c96-35aa-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-60925ddc-fdb4-430e-b5ba-bd39bb1ed8b8/pl-60925ddc-fdb4-430e-b5ba-bd39bb1ed8b8_drm_ece7e8dd-a362-49ce-a8d5-ca06073ec83d.ism/textstream_dut=1000.vtt"
                "Description": "Na vier maanden duisternis ontwaakt de Noordelijke IJszee samen met haar bewoners. Dieren als de ijsberen hebben hier hun habitat, maar voor andere soorten zoals de beloegawalvis kan de bevroren zee een dodelijke valstrik worden.  Bij Groenland leven verschillende diersoorten op het drijvende pakijs, maar de opwarming van het klimaat betekent ook voor hen bijkomend gevaar. In de zomer is het 24 uur per dag licht in het noordpoolgebied en komen vele (vogel)soorten er huizen. Door de recordhitte is het seizoen er ook warmer dan ooit. Een zegen voor de een, dramatisch voor de ander. Bekijk aflevering 2 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Frozen planet S02E02 Frozen ocean",
                "Keys": "b957a8ad98d1a6ba5254395bc402248f:907dc0d77235dcb2240490468b2a032c ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-cad62bdf-5353-4e5c-b9a1-60ffb2d3fb0e/pl-cad62bdf-5353-4e5c-b9a1-60ffb2d3fb0e_drm_2689a14a-609d-4945-b15d-07e3812f1223.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/09/23/f1c60b6c-3b25-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-cad62bdf-5353-4e5c-b9a1-60ffb2d3fb0e/pl-cad62bdf-5353-4e5c-b9a1-60ffb2d3fb0e_drm_2689a14a-609d-4945-b15d-07e3812f1223.ism/textstream_dut=1000.vtt"
                "Description": "Waar hoge bergtoppen zijn, vind je bevroren habitats, soms ook het hele jaar door: in Oost-Afrika, de Europese Alpen, het Japanse hooggebergte, Nieuw-Zeeland, de Andes...  Vele soorten leven het liefst op deze grote hoogtes, maar ze zijn vaak niet aangepast aan het leven in de vrieskou. Ze moeten zich dan snel uit de voeten maken en warmere oorden opzoeken om het niet met hun leven te bekopen.  Door de klimaatverandering ondergaan deze bevroren bergtoppen een snelle evolutie, en ook daar moeten diersoorten zich aan weten aan te passen, zo ook de reuzenpanda. Bekijk aflevering 3 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Frozen planet S02E03 Frozen peaks",
                "Keys": "9a795fe9eee79f46f78dc9e530817137:6be95e2df93db22271f650b8e8987810 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-21aaaf6d-9d05-4d3e-ba35-f4ae253e02ad/pl-21aaaf6d-9d05-4d3e-ba35-f4ae253e02ad_drm_4cc17a75-2daa-451f-9cc1-cfe5732b16a9.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/10/02/c1dd822d-4236-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-21aaaf6d-9d05-4d3e-ba35-f4ae253e02ad/pl-21aaaf6d-9d05-4d3e-ba35-f4ae253e02ad_drm_4cc17a75-2daa-451f-9cc1-cfe5732b16a9.ism/textstream_dut=1000.vtt"
                "Description": "Antarctica is een van de meest onherbergzame bevroren werelden op aarde, maar toch leven hier o.a. albatrossen en pinguïns en hun grote vijand, het zeeluipaard. De Zuidelijke Oceaan is dan weer de habitat van de blauwe vinvis, het grootste dier op aarde.  In het voorjaar is de sneeuw op Antarctica verdwenen en wordt duidelijk dat het continent een van de meest vulkanische gebieden van de planeet is.  Maar de grootste verrassing die Antarctica verborgen houdt, zijn wellicht de gigantische stromatolieten, fossielen die voortkomen uit de meest primitieve levensvormen. Bekijk aflevering 4 van seizoen 2 met VRT MAX via de site of app.",
                "Filename": "Frozen planet S02E04 Frozen South",
                "Keys": "b780b19bb5f777b0100894cdd2e4be56:93f4c0c7fcad76c8b5b12d7824d4e728 ",
                "MPD": "https://remix.vrtcdn.be/content/vod/pl-6e78345a-9131-4c57-af41-191f852e8adf/pl-6e78345a-9131-4c57-af41-191f852e8adf_drm_235bff16-f9ce-49c3-8689-9f9287bc4f98.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29",
                "Poster": "https://images.vrt.be/orig/2022/10/10/16d6d26b-48d3-11ed-b07d-02b7b76bf47f.jpg",
                "Subtitles": "https://remix.vrtcdn.be/content/vod/pl-6e78345a-9131-4c57-af41-191f852e8adf/pl-6e78345a-9131-4c57-af41-191f852e8adf_drm_235bff16-f9ce-49c3-8689-9f9287bc4f98.ism/textstream_dut=1000.vtt"
  12. Thanks so much! I succeeded to download, but there is no audio...
  13. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    did you merge audio and video?
    it should download an MP4 and M4A (I think) and you need to merge those
  14. Originally Posted by Karoolus View Post
    I've got the MP4-files in my folder, but I cannot find M4A-files. Do I have to merge them in the cmd or how should I do it?
  15. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    This will do it all for you:
    N_m3u8DL-RE.exe MPDURL --save-name VIDEONAME --auto-select --mp4-real-time-decryption --mux-after-done format=mkv:muxer=mkvmerge -ds all --binary-merge --check-segments-count false --key KEY
    You need
    N_m3u8DL-RE
    ffmpeg
    mkvmerge
    mp4decrypt
    in the folder you're running the command in
  16. Originally Posted by Karoolus View Post
    You need
    N_m3u8DL-RE
    ffmpeg
    mkvmerge
    mp4decrypt
    Now I see I do not have the mkvmerge in my folder. Where should I download this file?
  17. Originally Posted by Ruben02 View Post
    You need
    N_m3u8DL-RE
    ffmpeg
    mkvmerge
    mp4decrypt
    My goodness! Ruben02, you are allowed to engage your brain and make tiny efforts before asking the internet for help.
    In the message you quoted, mkvmerge is a link. Follow that link and engage brain. Alternatively, use your favorite search engine.
  18. Originally Posted by pteque View Post
    You need
    N_m3u8DL-RE
    ffmpeg
    mkvmerge
    mp4decrypt
    I could only click on the the mkvmerge-link after quoted, not in the original post. I've downloaded the mkvtoolnix, but I cannot find the mkvmerge anyware...? Image
    [Attachment 78087 - Click to enlarge]
  19. Originally Posted by Ruben02 View Post
    It's right there in your screenshot, third to last file.
  20. Sorry to ask again. Probably I'm still doing it wrong. These files are not just the single mkverge file?
    I've put the screenshots of what I'm doing.Image
    [Attachment 78088 - Click to enlarge]
    [Attachment 78089 - Click to enlarge]
  21. there is a space between key and mpd url
  22. It still doesn't work. The problem is linked to the mkvmerge file, because before (with only 3 files) it worked, but there was no audio. I think I must not put all 5 folders, but only the mkvmerge file. The problem is I cannot find it.
  23. I don't know what you're doing...
    anyway...
    download this version
    https://www.videohelp.com/download/mkvtoolnix-64-bit-83.0.7z
    Extract the archive and you will find mkvmerge inside it.
    So put the file in the same folder as N_m3u8DL-RE
    [Attachment 78091 - Click to enlarge]
  24. Thank you for helping. Now I've found the mkvmerge (which I didn't find before).
    It still doesn't work: Image
    [Attachment 78092 - Click to enlarge]
    The space after key, doesn't make any difference.
    I think I still miss the file: package-win-x64.exe
  25. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    you don't listen, do you?
    you need spaces between your arguments, don't glue them together. This is CLI 101 man, you should be able to do this
    N_m3u8DL-RE MPDURL --key KEY -M format=mp4
    have a good look at the spaces between different words/values
  26. I thought Cedri8528 said there was a space where it shouldn't instead of the opposite.
    So now the download works, but there is still no audio.
    Thanks to everyone for helping anyway.
  27. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    What command did you use?
  28. I've tried
    N_m3u8DL-RE "https://remix.vrtcdn.be/content/vod/pl-60925ddc-fdb4-430e-b5ba-bd39bb1ed8b8/pl-60925ddc-fdb4-430e-b5ba-bd39bb1ed8b8_drm_ece7e8dd-a362-49ce-a8d5-ca06073ec83d.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26Fo urCC%21%3D%22AACL%22%29%29" --key 8c91ea9e6b975f3267d881d13c440e1b:f87431e1d4d995324 9d1f2875d01d6a0 -M format=mp4
    and
    N_m3u8DL-RE --key 8c91ea9e6b975f3267d881d13c440e1b:f87431e1d4d995324 9d1f2875d01d6a0 "https://remix.vrtcdn.be/content/vod/pl-60925ddc-fdb4-430e-b5ba-bd39bb1ed8b8/pl-60925ddc-fdb4-430e-b5ba-bd39bb1ed8b8_drm_ece7e8dd-a362-49ce-a8d5-ca06073ec83d.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26Fo urCC%21%3D%22AACL%22%29%29" -M format=mp4
    [Attachment 78098 - Click to enlarge]
  29. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Why did you need mkvmerge when you're downloading as MP4?
    Just tried running this command and I have audio
    >N_m3u8DL-RE "https://remix.vrtcdn.be/content/vod/pl-60925ddc-fdb4-430e-b5ba-bd39bb1ed8b8/pl-60925ddc-fdb4-430e-b5ba-bd39bb1ed8b8_drm_ece7e8dd-a362-49ce-a8d5-ca06073ec83d.ism/.mpd?filter=%28%21%28type%3D%3D%22audio%22%26%26FourCC%21%3D%22AACL%22%29%29" --key 8c91ea9e6b975f3267d881d13c440e1b:f87431e1d4d9953249d1f2875d
