Page 2 of 2
FirstFirst 1 2
Results 31 to 33 of 33
    Dec 2020
    Croatia
    After fiddling around with http toolkit for some time I believe I've found a simpler way to get the mpd url without ads - find the mpd url WITH ads and replace http with https. Or find the widevine mpd url with "https:" while looping through sources in the json that the episode info URL returns after a request. It worked with Insoupconnable E01.
    This is the part of the script that deals with that:
    import requests
    import json
    import helpers
    from urllib.parse import unquote
    episode_url = "https://player.stv.tv/episode/4aa8/banijay1-insouponnable"
    stv_episode_info_url = "https://edge.api.brightcove.com/playback/v1/accounts/6204867266001/videos/EPISODE_ID?ad_config_id=7fb30a85-56ee-49f8-b645-900876e7c09c&config_id=edbc4bd0-6a34-46f2-8055-45d823d66886"
    stv_episode_info_headers = {
        "accept": "application/json;pk=BCpkADawqM1fQNUrQOvg-vTo4VGDTJ_lGjxp2zBSPcXJntYd5csQkjm7hBKviIVgfFoEJLW4_JPPsHUwXNEjZspbr3d1HqGDw2gUqGCBZ_9Y_BF7HJsh2n6PQcpL9b2kdbi103oXvmTNZWiQ"}
    def find_str(str, char):
        index = 0
        if char in str:
            c = char[0]
            for ch in str:
                if ch == c and str[index:index + len(char)] == char:
                    return index
                index += 1
        return -1
    def extract_json_from_html(html_string):
        json_begin = 'type="application/json">'  # +24 chars
        json_end = '}</script>'  # +1 char
        json_begin_pos = find_str(html_string, json_begin)
        temp = html_string[json_begin_pos+24:]
        json_end_pos = find_str(temp, json_end)
        json_string = temp[:json_end_pos+1]
        json_parsed = json.loads(json_string)
        return json_parsed
    def get_links(episode_url):
        res = requests.get(episode_url)
        json_res = helpers.extract_json_from_html(res.text)
        title = json_res['props']['pageProps']['title'].split(" | ")[1]
        temp_id = json_res['props']['pageProps']['episodeId']
        helper_prop = f'/episodes/{temp_id}'
        episode_id = json_res['props']['initialReduxState']['playerApiCache'][
            helper_prop]['results']['video']['id']
        link_info = stv_episode_info_url.replace(
            "EPISODE_ID", f'{episode_id}')
        res_info = requests.get(link_info, headers=stv_episode_info_headers)
        info_json = res_info.json()
        sources = info_json['sources']
        for source in sources:
            dict_keys = dict.keys(source['key_systems'])
            for key in dict_keys:
                if "widevine" in key:
                    widevine_source = source
                    break
        mpd_url = unquote(widevine_source['src'])
        mpd_url = mpd_url.split("&")[0]
        mpd_url = mpd_url.replace("http:", "https:")
        license_url = unquote(
            widevine_source['key_systems']['com.widevine.alpha']
            ['license_url'])
        return title, mpd_url, license_url
    Feb 2022
    Search the forum first!
    You've got to dig quite deep to get the 'stv_episode_info_url' and I assume also the 'stv_episode_info_header' before you can download. Whereas a vmap is far easier to grab, single video or group of them. So for Soupconnable go the series link, with The Stream Detector in your browser visit each page in the series so The Stream Detector captures the vmap. When finished click on 'copy all visible urls' in The Stream Detector and run stv.py. No need for HTTPTollkit out and intercepting each page.
    Updated stv.py with sanity checks. Does single or series videos - whatever vmap is in clipboard - ignores other stuff there...
    #!/usr/bin/env python3
    import  pyperclip as PC
    import xml.etree.ElementTree as ET
    import requests
    import os
    from pywidevine.L3.cdm import deviceconfig
    from base64 import b64encode
    from pywidevine.L3.decrypt.wvdecryptcustom import WvDecrypt
    import shutil
    For stv.tv  - a series downloader
    This program loads a short form of content.vmap which, during testing, provided an advert free stream from 'content_uri'
    Full headers. with origin and referrer defined, produces a full vmap - the 'content_uri' from which which serves adverts.
    Needs N_m3u8DL-RE and shaka-packager in $PATH
    The program reads the clipboard of urls saved from 'The Stream Detector' browser plugin.
    'pip install pyperclip shutil' may be needed before you start
    Use 'The Stream Detector' browser plugin (Chrome + Firefox)
    Find here: Firefox version - https://addons.mozilla.org/en-US/firefox/addon/hls-stream-detector/
    Chrome version: https://github.com/rowrawer/stream-detector/releases  choose  hls_stream_detector-2.1X.XX.crx
    and in chrome://extensions/  set Developer mode (top-right window) and drag and drop the crx file into the window to install
    Once installed configure with an additional filter set for 'vmap'.
    Under Options:
    'Detect additional file extensions:' 	set checkbox ticked and enter 'vmap' in box
    'Detect additional Content-Type headers:' tick checkbox and add 'application/xml' in box
    Now just visit any number of video pages at STV and the vmap urls will be listed by
    The Stream Detector. Copy the urls to the clipboard from 'The Stream Detector' window when finished selecting videos.
    This program ignores all the thumbnail (VTT) links - just leave them be.
    headers = {
        'Accept': '*/*',
        'Accept-Language': 'en-GB,en;q=0.7',
        'Connection': 'keep-alive',
    def WV_Function(pssh, lic_url, cert_b64=None):
        wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=cert_b64, device=deviceconfig.device_android_generic)
        widevine_license = requests.post(url=lic_url, data=wvdecrypt.get_challenge(), headers=None)
        license_b64 = b64encode(widevine_license.content)
        wvdecrypt.update_license(license_b64)
        Correct, keyswvdecrypt = wvdecrypt.start_process()
        if Correct:
            return keyswvdecrypt
    def divides(text):
        text = text
        l = len(text)
        count = int(shutil.get_terminal_size().columns) - 2
        if count <= 120:
            count = int(count)
        else:
            count = int(count/2)
        count = count - (l)
        line = ('-' * int(count/2))
        #line = (chr(9604) * int(count/2))
        print('\n'+ line + " " + text + " " + line)
    divides('STV Downloader from a vmap url')
    print("Ready to read from clipboard")
    input("Press Enter when ready... ")
    print('reading from the clipboard ...')
    mylines = PC.paste().split('\n')
    for line in mylines:
        vmap_url = line
        if 'thumbnail' in vmap_url:
            continue
        if 'mpd' in vmap_url:
            print('mpd found .. rejecting')
            continue
        if 'vmap' in vmap_url:
            videomap = requests.get(vmap_url, headers = headers).text
        else:
            print(f'No vmap found in link(s).')
            exit(0)
        # parse xml
        root = ET.fromstring(videomap)
        # get uri to m3u8 contained in vmap
        uri_dict =  root[0][0].attrib
        content_uri = uri_dict["contenturi"]
        #videoname = input('Name of the video? ')
        videoname = vmap_url.rsplit('&', 5)
        videoname = videoname[1].split('=')
        videoname = videoname[1].title()
        divides(videoname)
        if 'mpd' in content_uri:
            # encrypted stream
            divides('encrypted video')
            mpdmap = requests.get(content_uri, headers=headers).text
            root = ET.fromstring(mpdmap)
            mpd_dict = root[0][0][1].attrib
            lic_url = mpd_dict['{urn:brightcove:2015}licenseAcquisitionUrl']
            divides('license url')
            print(lic_url)
            pssh = root[0][0][1][0].text
            divides('pssh')
            print(pssh)
            keys =  WV_Function(pssh, lic_url)
            key = keys[0]
            divides('keys found')
            print(key)
            divides('downloading video')
            os.system(f"N_m3u8DL-RE '{content_uri}' --auto-select --save-name '{videoname}' --tmp-dir './cache/' --save-dir './' --use-shaka-packager --key '{key}'  -M 'format=mkv:muxer=mkvmerge'")
        else:
            divides('downloading an encryption free video')
            os.system(f"N_m3u8DL-RE '{content_uri}' --auto-select  --save-name '{videoname}' --tmp-dir './cache/' --save-dir './'  --use-shaka-packager   -M 'format=mkv:muxer=mkvmerge'")
    This is for linux. Windows will need a few .exe's added. Runs with your own CDM if the program is encrypted thus needs to be in WKS-KEYS folder. Will work for non encrypted STV stuff for those without their own CDM
  3. Originally Posted by A_n_g_e_l_a View Post
    Brilliant
