Results 1 to 13 of 13
    Jun 2012
    New Zealand
    Porting some stuff over from old XP to win 10. One of these is Cool Edit Pro v1.5 which I record with in XP selecting 'What U Hear" in the Recording Mixer.
    Win 10 is completely different and I can't find the equivalent Recording Mixer. Looking at record settings in Cool Edit (XP) you see the Record mixer but the same step in Win 10 brings up error "Can not find mixer Program sndvol32 /r". Then is says an alternate mixer applet may be specified in the registry.
    This is beyond me to figure out, can anyone help? I have gone to Sound - Recording in Win 10 and set "Stereo mix" as the recording device - and can see some indication of a signal, but Cool Edit cannot.
  2. Member Cornucopia's Avatar
    "What U Hear" was an XP era driver. There are probably some equivalents out there, but that particular driver may not work in Win10.
    If you are trying to get sounds recorded that are coming from other apps, I would suggest you go the route of Audacity, or maybe even better for this task: VoiceMeeter (one from that family- basic, Banana, Potato...). With it, I know you can easily route any running app and mix it, along with mics, wav files, etc, into it's built in recorder (looks like a tape deck in the corner).
  3. I'm a Super Moderator johns0's Avatar
    canada
    I'm on windows 11 and i have "What U Hear"in my recording tab in the sound in control panel.
    Jun 2012
    New Zealand
    Hi Scott, I did install Audacity but ran into the same problem. I'm playing a CD (in the internal CDROM) in Winamp. In Volume Mixer I see the levels as expected but not in Sound-Recording. (Whether propeties are "listen to this device" or not).
    I suspect if I could liven the Sound VU i may get audio into Audition (or Audacity). I'd prefer Audition as I'm used to it.
    Do you know if that is possible?
    The recording properties for AA, gives the error below but I think that is another issue to sort after the above. It is pre-Win10, but i wa shoping to work it our or find someone who'd done it.
    John I haven't Win11 but good that's back. I wondered if it were a 'feature' of the audio used by the OS.
    I will give Voice meeter a try if its known to record from audio from the CDROM.
  5. Install the audio driver from the manufacturer of your audio device. The drivers Windows installs only support basic features.
  6. Member Cornucopia's Avatar
    @johns0, that driver is available on certain hardware, but it isn't universal. Glad to hear (pardon the pun) that it works with Win11, though.
    Btw, VB-audio (the folks giving us voicemeeter) have a couple of very helpful tools there, including virtual patchcables. Which work with many setups.
    canada
    I have a sound blaster audigy rx5 and lot of the sound blasters have the "what you hear" option.
    Jun 2012
    New Zealand
    If I install SOUND BLASTER AUDIGYFX (cheap soundcard) would that have 'What you Hear ?
    canada
    Probability not,it's for higher ranked sound blaster cards,just look into the details to see if it's their.
    Jun 2012
    New Zealand
    Thanks I won't go down that route, the specs don't mention if 'What u Hear' is supported or not. I will try Scotts suggestion of VoiceMeeter if I can get info from them about recording. It looks a bit complicated, and it's not clear to me what to download. But will have a go...
  11. Member Cornucopia's Avatar
    Check the tutorials for setting up VoiceMeeter, on Youtube, they are very helpful.
    Jun 2012
    New Zealand
    Will do, thanks.
    Jun 2012
    New Zealand
    Pretty steep learning curve to begin with. Appears to do so much more than I need. Tried logging into their forum but never got the confirmation email.
    Can you tell me which would be best for recording CDDA from internal CDROM, like Banana or Potato etc...
    And a download link would be be great too. Is the 'tape deck' for recording the cassette image ?
