  1. Hi,
    I'd like to know if it's possible to create a blurred with a text on it with ASSA ovverid tags.
    For example, here is the original video: Image
    [Attachment 68165 - Click to enlarge]
    And I'd like to be this way: Image
    [Attachment 68166 - Click to enlarge]
    Is it possible?
    Apr 2007
    Australia
    Hi.
    For me the trick to the whole process you want is to FIRST create and position the blurring to wipe the original text.
    THEN add the subtitles.
ID:	68175 [Click for larger image]
    2 sets of coordinates mentioned here:
    - crop=1000:100:120:400 : This denotes a 1000x100 pixel box located 120 pixels to the right and 400 pixels down from the top left corner.
    - overlay=120:400 : Use the same as the last two coordinates mentioned in the crop to ensure the blurred effect is applied on the pixels that are located where the box is.
    - boxblur=20 indicates the power of the blurring effect that I used. 10-20 is a good range.
    ffmpeg -i "NotMyVideo.mp4" -filter_complex "[0:v]crop=1000:100:120:400,boxblur=10[fg]; [0:v][fg]overlay=120:400[v]" -map "[v]" -map 0:1 -c:a copy -y "blurredVideo.mp4"
    I would then use a standard .ass subtitles file to insert the text you want.
    Use .ass subs and NOT .srt.
    .ass allows better control of the positioning of the text, if necessary.
    I don't use .ass subs often. I've never done what you are trying to do.
    If needed, best to start a thread here in the subtitles section, asking for help on positioning of .ass subs.
    Cheers.
  3. I tried with only ASS tags, but I didn't succeed.
    I may try your method even though it will take a lot of time ! thanks!
