I need a program that will convert from Nero to my harddrive..this is actually what I have I have the starwars trilogy in nero format the file size is 4,208,753 mb in a NRG format. what Im trying to do is cause I dont have a dvd burner I want to get this outta nrg format and convert to svcd is there any way this can be done..
any yes I downloaded the file called CDMAGE.EXE but I get the following error
Invalid format of file: E:\Download\Star.Wars.Episode.IV.A.New.Hope.DVDR-THF.nrg
any help is appreciated.
ScOOt3r
Try using Daemon tools to create a Virtualdrive on your computer and then (if you have the room) try copying the file from the virtualcdrom drive to your hard drive. Or try opening it in Nero and copying it from there.
Hope this helps!... -
Try a program called ISObuster that reads the contents of CD Image files. You can extract whats inside.
Myabe that can provide some help to your situation -
.....or try WinISO v5.3 which does the same thing. I often use this to open up .nrg files and open up fully to my drive, so I can re-encode or whatever.
Cheers,
Ego
Convert program shuts off computer
By Crescere in forum Video ConversionReplies: 7Last Post: 12th Aug 2011, 15:54 -
Free program to convert my cd's to mp3's?
By scustalow in forum AudioReplies: 15Last Post: 18th May 2011, 08:26 -
Best program to convert VOBs
By technicolornightmare in forum Newbie / General discussionsReplies: 5Last Post: 13th Sep 2010, 09:16 -
easy program to convert 16:9 DV to 16:9 flash
By bernt in forum Video ConversionReplies: 4Last Post: 25th May 2009, 15:56 -
Using VirtualDub or other program to mass convert?
By RedPenguin in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2007, 18:18
