I have been using a device (VIDEO2DIGITAL) for quite some time now and it's worked very well. I just recently had a need again (I got handed a couple of tapes with a plea for help) and dragged it out again. It did not fail. I made a short video of my experience. Please take a look it might help. https://youtu.be/LSoHQ2jIJRU
Results 1 to 9 of 9
I watched your video. Is it storing the files as DVD-spec mpeg-2?
Can you post a small sample ? -
Thanks for watching and asking. I'll make a sample and notify you when it drops. As for the format, ClearClick saves it as a .avi file to the SD card. Then I toss it into VLC (macOS is my platform of choice) to view and convert. I go to .m4v with embedded 192k AAC audio. You might if you have a Google Drive account be able to use cloud convert from .avi to whatever, then walk away and get a coffee and download when converted. Clear click packs a copy of NCH Prism, but I have experienced issues with Prism and the latest version wants you to subscribe to the software service, which I won't do. VLC works like a champ.
Stay tuned. -
AVI is just a container. Does the box deinterlace, upscale and put 4:3 into a widescreen frame?
If you used a Digital 8 camcorder, you would get your video as DV. Digital 8 camcorders are not hard to come by, depending on stated condition and the phase of the Moon you can get one on eBay for between $50 and $150. The funky looking camcorder that you borrowed would be a more interesting topic than yet another capture box, but then the viewer would not have a reason to follow the affiliate link. -
You asked for a sample? Here's what I was able to come up with; https://youtu.be/-CVumH4t8Nc
from a stranded 20-year-old videotape sucked right off the ViewCam then uploaded directly to here.
It could be worse. 30p instead of 60p, which means losing temporal resolution and some spatial resolution as well, see stairstepping on diagonals and occasional ghosting, which the deinterlacer joined two fields together. The highlights are blown out, so either the box converts into "computer" levels, or the camcorder was too optimistic regarding levels, I suppose the first one. Mono PCM at 705.6 Kbps would not be my choice for the audio, OTOH I suppose it is just a half of a normal stereo PCM. Sure, old camcorders were mono. But I would not waste bandwidth for inferior audio.
Video8 to digital conversion issues
By Am1td in forum CapturingReplies: 5Last Post: 29th Jul 2021, 07:36 -
Hi8 camera doesn't play Hi8 well, only plays Video8 well.
By digicube in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 30th Jun 2020, 15:10 -
12voltvids wants to know Analog to Digital Conversion Which is better
By digicube in forum CapturingReplies: 4Last Post: 9th May 2020, 10:02 -
Converting Hi8 analog tapes to digital
By mrittman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 26th Aug 2018, 13:58 -
Hi8/Video8 to Digital/DVD
By Anon45 in forum Newbie / General discussionsReplies: 12Last Post: 12th Mar 2018, 17:50
