  1. Hello all, I have a hopefully simple question for all the professionals here:
    (How) can you start Virtualdub right away with certain Processing settings?
    I tried it with a self-made batch file, but failed....
    Mar 2008
    From the file menu you can save/load settings.
    That's the closest you can get
    Apr 2007
    Australia
    Open VirtualDub
    Create your basic settings
    Save processing settings (Ctrl+S) Mine are called 'Basic.vdscript'
    Save it in the same folder as the exe program
    Create a shortcut (on the desktop??)
    Modify the shortcut Target: C:\VirtualDub\VirtualDub64.exe /s Basic.vdscript
    A doubleclick on the shortcut will automatically load your 'Basic.vdscript' settings
    Beware of using spaces in the paths. Double quotes around paths are needed if you do.
    I hate spaces and use the underscore instead.
  4. Wow, that works perfectly in the first shot!!! Many, many thanks to you!!
    Do you know what possibly other options beside "/s" are existing?
    Apr 2007
    Australia
    Start VirtualDub
    Help (F1)
    On the left:
    Advanced operation/Command-line operation
  6. Brilliant, you have helped me very very much! Thank you!
