I've noticed with certain files I import into Handbrake, that in the dimensions tab it resizes the file for some reason. Example, when I imported an MPEG-2 file at 720x576 the dimension size in Handbrake is 700x576. I've had this happen with different file resolutions and in different file formats. Anyone know why does this? sometimes this happens and sometimes it doesn't. Is this just a bug in the version I have?.
It's cropping away black borders. Turn off Automatic Cropping if you don't want that.
Thanks for that, I tried custom cropping but it does nothing to correct it and it just says width: 720 and height: 556. Changing anamorphic from automatic to none does nothing either. It could be the capture software I was using to capture the video that's at fault, for this particular file I was using Corel Video Studio. I noticed that, despite the resolution being 720x576 (some were also captured at 320x240) with a video bitrate of 7000, that the audio bitrate seems very high at 1536kbps. Whenever I capture in Corel and trie to cut the video in Lossless Cut the outputted file has no audio.
Hi techmot! You can try to untick *Optimal size*, it still affecting when "off" above.
how to cut out adverts from video files automatically need software to do i
By elm in forum EditingReplies: 5Last Post: 29th Apr 2024, 02:08 -
handbrake automatically trimmed a video file
By cns00 in forum Video ConversionReplies: 1Last Post: 8th Feb 2022, 01:26 -
Cropping Batch Files in Handbrake
By buddyboy101 in forum Newbie / General discussionsReplies: 1Last Post: 9th Mar 2019, 19:54 -
Best way to compress large Video Files (HandBrake, MP4)?
By user115 in forum Video ConversionReplies: 21Last Post: 17th Dec 2018, 09:04 -
Not Sure What to set Handbrake at when converting MTS files
By Boracho in forum Video ConversionReplies: 6Last Post: 14th Jun 2018, 19:28
