I just reinstalled the current Subtitle Edit and it asks to install ffmpeg. The usual problem on my Windows 7 occurs where it hangs.
Ok for that, my good install on another PC shows ffmpeg at:
c:\users\my user name\appdata\roaming\subtitle edit\ffmpeg.
So if I unpack a new zip of ffmpeg to that location, does it solve the problem in subtitle Edit?
I ask this because I don't recall it being an issue in earlier editions of SE. The followup question is
which old version of SE installs ffmpeg?
This sounds a bit unclear. SE hanging is "the usual problem" on your Win7 pc? If so, do you know under what circumstances?
As a quick & dirty approach, you can try SE portable version and see if problems persist.
As for ffmpeg, you can put it anywhere. Just make sure SE has the correct path set. -
Thanks for your reply to one of my many questions.
Yes, my question was on the install path.
From recent experiences in finding the appdata roaming path for SE on Win7 and seeing that path on an install
that is 'stable' for it, I'm pretty sure I can point it correctly. I have to see the error again to find out.
Problem is, I use a number of HDs to back up and change things around.
I will look at adding the portable install which I have not done.
Adjusting SUP subtitle positions in Subtitle Edit
By CWCprime in forum SubtitleReplies: 3Last Post: 31st Jul 2020, 02:51 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52 -
This dummy can't sync subs with Subtitle Edit or Subtitle Workshop :-(
By inspector_plodder in forum SubtitleReplies: 6Last Post: 24th Aug 2018, 18:33 -
Pixelated and laggy video on Subtitle Workshop and Subtitle Edit
By Valerc in forum SubtitleReplies: 5Last Post: 15th Jul 2018, 11:37 -
By Valerc in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2018, 14:15
