    Aug 2017
    U.S. of A.
    I want to rip a video's audio (from VEMO-Youtube) to a lossless format. I'm under the impression YT and VEMO only produce mp3 and it's not possible to rip the audio to a lossless format.(?) Is there a way to get the audio from a video to actually rip/convert to a lossless format? Or maybe better said, can you convert an mp3 to a lossless format and truly get the "lossless" version? (the following I post for discussion/debate purposes)....https://www.videoconverterfactory.com/tips/youtube-to-flac.html
    Mar 2008
    you can certainly open an mp3 and export as Flac or Wav; you'll get the same quality as the original mp3
  3. Banned
    Nov 2022
    If you pour three liters of water into a ten-liter bucket will you get ten liters of water?
    May 2005
    PAL User
    VLC Player will rip audio to Flac (and other codecs) from a video:
    Open VLC
    Media>Convert/Save
    +Add
    On the Convert/Save dropdown, choose Convert
    In Profile, choose desired codec
    In Destination, enter details
    Start
  5. Not sure what is your goal but you can use for example ffmpeg
    @setlocal
    @set ff=C:\FF
    @set PATH=%FF%;%PATH%
    @SET file=%1
    @SET fname=%~n1
    @ffmpeg.exe -stats -y -hide_banner -i %file% -vn -dn -sn -c:a flac "%fname%_lossless.flac"
    @endlocal
