Can anyone help me with the input driver for Virtualdub2 on Windows XP? I used to a get a "requested frame not found" error on Virtualdub2 when I used the "Caching Input Driver" as my input driver. I was in despair for most part until I discovered that when I switched the input driver to "Audio/video interleave input driver (internal)", it can convert the video just fine without trouble. I once heard that the "Caching Input Driver" is the source of the trouble in Virtuqaldub2 in regards to that error I mentioned. I never thought that was the case until I tested it out and it worked. I also discovered options that I could use to help with my problem. .
I still am going to try to use other computers to use with Vritualdub2 but what input driver is better for Virtualdub2 on Windows XP?
Results 1 to 1 of 1
Distorted capture video input in VirtualDub2, OBS works fine
By NotLikeThis8 in forum Newbie / General discussionsReplies: 12Last Post: 24th Mar 2022, 05:34 -
Windows 10 small problem need assistant with driver on capture
By xenon1 in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2020, 21:10 -
Virtualdub2 and FFmpeg: How do I convert this code to Virtualdub2?
By Guernsey in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2020, 04:25 -
How to I nstall the FFMPEG input driver in VirtualDub?
By Avagadro1 in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2020, 00:26 -
Failed driver update, now can't boot Windows 7 on NVME SSD (0x0000007B)
By abolibibelot in forum ComputerReplies: 21Last Post: 14th Nov 2019, 13:42
