I have Win10 and the Program Any Video Converter.
Does anybody use this Video Converter Program?
After I Import a Video into the Program I select the Video Format I want to Convert it to.
Then I go through all the settings.
When I come to the Video settings I see Bit Rate and a Drop Down list.
The Lowest Bit Rate in the list is 512 but is this telling me it will be Encoded with a Video Bit Rate of 512,000 Bits Per Second?
"512" = 512kbps = 512,000 bits per second. So what's your question?
Scott -
I ask because it just says Video Bit Rate right before the Drop Down list.
It does not say kbps anyplace even in the Drop Down list.
So when I see the 512 in the Drop Down list I did not know if it was telling me it will be Encoded at just Five Hundred and Twelve Bits Per Secound.
Or if it is Five Hundred and Twelve Thousand Bits Per Second? -
Mediainfo will only tell what is written in the metada, which can be true or false. A "bitrate analyzer" is needed to check the real bitrate of the video.Install Mediainfo and open one of your videos in it. It will tell you everything you need to know about your file, including the bitrate.
Any Video Converter
By jarod1005 in forum Newbie / General discussionsReplies: 2Last Post: 16th Feb 2022, 09:00 -
Syncing Audio and Video with Any Video Converter Ultimate Version 7.07
By sancarloscylist in forum Video ConversionReplies: 2Last Post: 8th Jan 2021, 17:26 -
video converter any video converter has basic settings video bit rate as -1
By jraju in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2020, 11:15 -
Any video converter not showing true video size
By amethystlover in forum DVD RippingReplies: 2Last Post: 19th Dec 2019, 06:07 -
Help with video conversion - Handbrake / AVC (Any Video Converter)
By higenbs1 in forum Video ConversionReplies: 9Last Post: 1st Mar 2018, 16:13
