I have a question,
I am running WindowsXP Pro, ATI AIW Radeon and I capture to Mpeg2 using that card. When I try to open that Mpeg2 ( after changing the ext to mpg or even mpeg from mpeg2) I get an error claiming that it can not open the file & then TmpgEnc crashes
Any idea why this would happen?
Thanx
I cannot sure since I never need to open mpeg2 in TMPGEnc, but I think it cannot open mpeg2 without a plug-in. Or why else would there be a plug-in for this? Check the Tools section (link is on the menu to the left) and there TMPGEnc MPEG2 Plugin under Video Encoders. Good luck
You need mpeg2 decoder. Go to tools and download the MPEG2Codec under Codecs section.
are you sure , that you have everything installed (codecs), i am running winxp pro . i havent got any problems opening any mpg2 files, im also using the latest tmpgenc .
MVK to MPEG2 - TMPGEnc
By zecaloteiro in forum Video ConversionReplies: 1Last Post: 18th May 2010, 09:32 -
Problems in viewing of trimmed MPEG2 files in Windows 7
By Ollie6431 in forum EditingReplies: 23Last Post: 3rd Mar 2010, 15:11 -
Windows Media Player dont play mpeg2
By mogoyon in forum Software PlayingReplies: 4Last Post: 14th Jan 2009, 14:31 -
MPEG2 file plays in windows media player but not properly in premier cs3
By ibanezfreak in forum EditingReplies: 1Last Post: 20th Oct 2008, 04:42 -
Blocky conversion DV-->Mpeg2 @ 9000Kbps using TMPGEnc 4.0
By kamaleon in forum Video ConversionReplies: 34Last Post: 15th Jul 2007, 18:25
