  1. Hi anyone,
    What program for creating customizable DVD menu without presets do you recommend?
    I've used DVDStyler until now but the buttons aren't up to much
  2. Member Skiller's Avatar
    Oct 2013
    Germany
    Without presets you say.
    Well then it's up to your image editing skills. More professional authoring softwares let you design anything you want because you do it outside the authoring software with something like Photoshop or Gimp.
  3. DECEASED
    Jun 2009
    Heaven
    Originally Posted by Donnje View Post
    Hi anyone,
    I stopped authoring DVD-Video ages ago, but I still recommend DVD-lab Pro.
    You can feed the program with your own assets, and also edit the navigation commands.
    "Programmers are human-shaped machines that transform alcohol into bugs."
  4. Thanks everyone
  5. Member DB83's Avatar
    Jul 2007
    There is no reason why you can not use DVDStyler to create a custom menu.
    With this example you do need to create images to represent your buttons and let these replace the images on the original preset. Navigation button text also edited.
    Here is the result:
  6. Originally Posted by DB83 View Post
    Here is the result:
    I didn't know you could put custom buttons
