I already had one recommendation from a forum member 1 year ago but I switched from Chrome and Firefox and seems I've lost this bookmark.
Open to any recommendations, I don't need it right now but I know they're really hard to find so might as well start looking for them on eBay.
Also if anyone has rack VHS recommendations I'm open but as far as I know it's better to make a custom one later.
Thank you!
Don't lose your nights, they're half your life.
Rack mount pizza box size TBC's are for professional formats, They don't work well with consumer formats like VHS, Some half rack mount and smaller devices from Snell & Wilcox, Grass Valley and Ensemble Designs handle VHS better than the big brothers. Also rack mount VHS VCRs are for SP speed only, you will need a consumer VCR to handle slow speed tapes.
Any half rack Snell & Wilcox starts with TBS, Grass Valley starts with CVR (former Snell & Wilcox), Ensemble Designs BrigheEye 75, this is just the ones I'm aware of, Avoid any Black Magic analog to SDI converter, SDI to USB interfaces from Black Magic are the best for connecting your device to the computer.
it depends on if your targeting SD only or old school traditional HD
you can't mix things much outside those two parameters in one device
most of this stuff is getting hard to find even used
this might help
If CVR900 is the equivalent of TBS800 add it to the list of recommendation, I know the TBS800 VHS capture is solid, Actually better than the Pinnacle USB-500 and since it has line TBC it makes it slightly better than the BE75, I posted samples here two years ago and last year when I added the TBS800.
Is a full frame TBC necessary if I'm not getting dropped frames?
By nightowl3090 in forum CapturingReplies: 16Last Post: 4th Oct 2022, 19:02 -
Good deal on thrift store TBC-1000 find?
By ryangarfield in forum CapturingReplies: 1Last Post: 16th Feb 2022, 13:34 -
Good audio cable recommendations?
By Master Tape in forum CapturingReplies: 7Last Post: 4th Jun 2019, 17:57 -
Is a full frame TBC necessary or VCR's builtin TBC enough?
By DNICE_ONE in forum CapturingReplies: 37Last Post: 22nd Dec 2018, 16:03 -
good TBC by roland videomixer
By 280634157 in forum CapturingReplies: 12Last Post: 26th Apr 2018, 13:59
