Hello, I have a multiple RAW MiniDv files and want to joint but create chapters with the date information I have with the file, them QTGMC and H265, I can make qtgmc with hybrid and joint with avidemux BUT the problem is: How create the chapters information? may be the best option is create this in the begging because I have the raw file joint by days.
I have 1 week reading the forum looking for that...
thanks
For the last step (Chapters creation and insertion) you can use clever FFmpeg-GUI.
This is done without reencoding, so there is no loss of quality.
Create your final video (qtgmc + join) and note the exact times where the cut points are (eg.
00:12:01, 00:27:48, 00:59:14 etc).
Then load your video into clever FFmpeg-GUI, click main, click chapters,
(1) Enter the first time at Start Time, the desired chapter title at Title, then click Add (2), repeat everything for all times, when all times are entered, click Create Chapters (3).
You can then edit/change your chapters if desired.
[Attachment 68063 - Click to enlarge]
Then click Activate, Chapters activated will be displayed, click main, click multiplex, select the desired container (mkv, mp4 etc) and click multiplex.
[Attachment 68064 - Click to enlarge]
Done.
You will find your newly created video with chapters in the destination folder. -
Thanks ProWO but clever FFmpeg-GUI dont work in my thinkpad W11, please another options?
Your OS is Windows?
Do you get an error on starting clever FFmpeg-GUI?
Then install Visual C++ Redistributable for Visual Studio 2012 Update 4 first.
https://www.microsoft.com/en-us/download/details.aspx?id=30679
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 02:01 -
H265 To H265 vs H264 to H265
By V1rg0_ in forum Newbie / General discussionsReplies: 4Last Post: 25th Apr 2022, 00:21 -
[FFmpeg+SvtAv1] convert a H264 or H265 1080p file to Av1 720p
By ignace72 in forum Video ConversionReplies: 11Last Post: 29th Mar 2022, 16:16 -
deinterlacing .vob file via QTGMC-still have blending
By clashradio in forum Video ConversionReplies: 2Last Post: 2nd Feb 2021, 20:44 -
Convert to HEVC .h265 to preserve quality and reduce file size.
By GiovannyLira in forum MacReplies: 8Last Post: 13th Dec 2017, 12:43
