I've been converting my VHS tapes to digital and have been using Avisynth to do minor color corrections. For the most part it works out OK using ColorYUV(cont_u, cont_v) but sometimes the colors don't look as good as I would like.
Last night I was reading some threads on Overlay, and decided to give it a try. I've never used it before, more or less understand the concept, but not the application. I copied a script from one of Jagabo's posts, edited the settings, and low and behold - like a miracle, everything looked better. I just don't understand why, and really what I'm doing.
Original video:
[Attachment 68054 - Click to enlarge]
Script using Overlay and Greyscale:
org=last
ColorYUV(gamma_y=0,off_u=-35, off_v=20, cont_U=51, cont_v=51)
StackHorizontal(Subtitle(last, "without overlay"), Overlay(org,last,0,0,GreyScale(org).ColorYUV(cont_ y=100, cont_U=0, cont_v=0)).Subtitle("with overlay"))
Resulting video:
[Attachment 68055 - Click to enlarge]
You can ignore the image on the left, that's what it would look like without Overlay, but I was surprised with the image with Overlay that it looked good to me.
Can someone explain to me what's happening? The help file on GreyScale is pretty sparse.
This is mask:
This is color change for originalCode:GreyScale(org).ColorYUV(cont_y=100, cont_U=0, cont_v=0)
Mask is black and white video, no colors, then further whites are more blown (cont_y=100). The way mask works in Overlay, if pixel is more white then you end up with more pasted pixel (from last) instead of original (from org).Code:ColorYUV(gamma_y=0,off_u=-35, off_v=20, cont_U=51, cont_v=51)
So effectively, highlights from your original video are replaced more than darker areas.
If you'd have a videoeditor and doing color corrections, you could tell to change colors in dark areas, midtones or highlights only. In Avisynth you can use Overlay to do that by defining a mask.
I don't understand the 704x480 or 704x576 resolutions!
By Hunk91 in forum RestorationReplies: 8Last Post: 9th Oct 2022, 06:31 -
Openshot - I don't understand that time units in the timeline
By Trith in forum Newbie / General discussionsReplies: 3Last Post: 28th Jan 2022, 06:12 -
MPC-BE controls & etc as overlay, not docked at the bottom of the video?
By hsregsfsdfsasdf in forum Software PlayingReplies: 0Last Post: 8th Nov 2019, 21:39 -
WinDV & file name overlay.
By RogerJay in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 15th May 2019, 09:00 -
I don't understand how to install and properly use h.265 library files
By Artas1984 in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2018, 09:57
