Results 1 to 12 of 12
  1. Is there any way to remove a foreign voice-over translation from a video?
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    With questions like this one, one should automatically post a complete MediaInfo file report so we know what we are dealing with. Very few mind readers these days!
  3. If it's something like the voice-over like in some eastern European countries: forget it.
  4. Here's a sample
  5. Member Cornucopia's Avatar
    You would have better luck finding the original.
  6. It is not available anywhere.
    Feb 2006
    what's the name of the movie ??
  8. What is the title & year of the movie?
  9. @alex: he linked to the imdb page which states: First Encounter 1997
  10. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Here is the MediaInfo report - just one sound track and very poor quality. However is my attempt using Audacity Vocal remover in Effects section. Enjoy!
    General
    Unique ID                                : 172661072126054569509141159796185032705 (0x81E5501A75EC4FAB803431A3FDA0E801)
    Complete name                            : C:\Users\netmask\Downloads\7.mkv
    Format                                   : Matroska
    Format version                           : Version 4
    File size                                : 5.91 MiB
    Duration                                 : 36 s 800 ms
    Overall bit rate                         : 1 347 kb/s
    Encoded date                             : UTC 2010-02-22 21:41:31
    Writing application                      : mkvmerge v5.9.0 ('On The Loose') built on Dec  9 2012 15:37:01
    Writing library                          : libebml v1.3.0 + libmatroska v1.4.0
    Video
    Format                                   : MPEG-4 Visual
    Format profile                           : Advanced Simple@L5
    Format settings                          : BVOP2
    Format settings, BVOP                    : 2
    Format settings, QPel                    : No
    Format settings, GMC                     : No warppoints
    Format settings, Matrix                  : Default (H.263)
    Codec ID                                 : V_MS/VFW/FOURCC / XVID
    Codec ID/Hint                            : XviD
    Bit rate                                 : 1 192 kb/s
    Width                                    : 480 pixels
    Height                                   : 368 pixels
    Display aspect ratio                     : 4:3
    Frame rate mode                          : Constant
    Frame rate                               : 25.000 FPS
    Bits/(Pixel*Frame)                       : 0.270
    Stream size                              : 5.23 MiB (89%)
    Writing library                          : XviD 1.2.1 (UTC 2008-12-04)
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : MPEG Audio
    Format version                           : Version 1
    Format profile                           : Layer 3
    Format settings                          : Joint stereo / MS Stereo
    Muxing mode                              : Header stripping
    Codec ID                                 : A_MPEG/L3
    Codec ID/Hint                            : MP3
    Bit rate mode                            : Constant
    Bit rate                                 : 128 kb/s
    Sampling rate                            : 48.0 kHz
    Delay relative to video                  : 8 ms
    Stream size                              : 575 KiB (10%)
    Default                                  : Yes
    Forced                                   : No
    ReportBy                                 : MediaInfoLib - v22.06
    CreatedOn                                : UTC 2022-12-10 01:36:41
