hi, I've recorded this movie and I already knew that it had bad quality, anyway I'd never imagined such that bad.
the video looks like it randomly changes from deinterlaced to not deinterlaced or bad deinterlaced.
before even start to crop and think about if to remove the logo or not,
I'd like to have some hints from you on about how to treat it, how to fix those artifacts.
the video looks like progressive to me, but I've tried
and the result is always very badCode:QTGMC(Preset="Slower", InputType=N) #N=1 or 2 or 3
so then I tried
this works much better and it seems it does not affect so much to the frames that do not seem interlaced.Code:QTGMC(Preset="Slow").SelectEven()
what do you think? Do I continue to use
on this video, or maybe I can use some different commands or approach?
and what about the frame 44? can I somehow remove that "half logo" remnant?
20 min sample:
https://www.dropbox.com/s/ckdvkm3r4z4dgzf/Il%20cacciatore%20di%20squali%20-%2020m%20sample.mkv?dl=0
current script
https://www.dropbox.com/s/j1170hrsg77lp0p/Il%20cacciatore%20di%20squali%20-%20cut_trac...D.mkv.avs?dl=0
mask:
https://www.dropbox.com/sh/fp4qsng7eslrg0g/AABIZUGK8QTOjtATjoBnQqhMa?dl=0
script:
Code:LoadPlugin("C:\Users\\\util\MeGUI-2913-64\tools\lsmash\LSMASHSource.dll") V=LWLibavVideoSource("C:\Users\\\DVB-T\TS cut\MKV\Il cacciatore di squali - cut_track1_[und].mkv") # SAR 12:11 V=V.AssumeFPS(25) V=V.QTGMC(Preset="Slow").SelectEven() V=V.crop(22, 4, -14, 0) #InpaintLoc(Loc="596,484,-28,-44") # logo borders #InpaintLoc(Loc="576,464,-8,-24") # +20px #InpaintDelogo(mask="C:\Users\\\\DVB-T\TS cut\.mask\mask.bmp", Automask=1, Loc="576,464,-8,-24", Analyze=2) #InpaintDelogo(mask="C:\Users\\\\DVB-T\TS cut\.mask\mask.bmp", Loc="576,464,-8,-24", Analyze=2, Mode="Deblend") A=Trim(V,0,44) # logo still visible on frame 44 B=Trim(V,45,0).InpaintDelogo(mask="C:\Users\\\\DVB-T\TS cut\.mask\mask.bmp", Loc="576,464,-8,-24", Analyze=2, Mode="Deblend") F=A++B Return F#.SelectRangeEvery(800,20) Prefetch(7)
Results 1 to 14 of 14
The video is progressive but switches occasionally between in-phase (the two fields come from the same progressive frame) and out-of-phase (the two fields come from adjacent progressive frames, but the missing fields are in the adjacent video frames). You can fix that with TFM() (part of the TIVTC package). That will leave you with occasional duplicate frames -- about every 77 frames, but I saw segments of 60 to 86 frames between duplicates. That can be fixed pretty well with TDecimate(Cycle=77, CycleR=1) (remove 1 duplicate out of every 77 frames). That leaves you with an odd frame rate of 49.351 though. And there are small comb artifacts left ins some frames. Those can be blurred away with vInverse().
Probably not worth the effort.
Additionally, you got some scenes with multiple halos,..
- SpotLess/KillerSpot and similar can help with the dirt (especially in the intro)
- MCTemoralDenoise, mClean and other filters can help in some scenes, but are way to strong for other scenes.
Unless you plan to do a scene-by-scene filtering, or want to play around to learn some filters, I would recommend to look for an alternative source.users currently on my ignore list: deadrats, Stears555, marcorocchini -
there's no better sources out there..
well.. a dvd exist in a collection called The_Grindhouse_Experience:_Volume_2
https://www.grindhousedatabase.com/index.php/The_Grindhouse_Experience:_Volume_2
but I have no access on it, so I have to use this DVB-T for the moment.
I only want a not too much complicated series of commands that can produce a better result compared to the already existing rip,
which has logo and it's resized.
existing rip, 20 min sample:
https://www.dropbox.com/s/j0t3gbwth6hiqf1/Il%20cacciatore%20di%20squali%20-%20rete4%20...ample.mkv?dl=0Last edited by maudit; 7th Dec 2022 at 15:25.
QTGMC(Preset="Fast").SelectEven().SpotLess().mClea n() might look better on most scenes, but will kill quite a lot of details in others.but I have no access on it, so I have to use this DVB-T for the moment.
which has logo and duplicated frames.
=> unless you plan on filtering scene-by-scene you will always lose quite a bit with such a source.users currently on my ignore list: deadrats, Stears555, marcorocchini -
Oops, the frame rate is ~25, not ~50. LWlibavVideoSource() was doubling the frame rate.
ok, I now see that the problematic part start from the frame 0 to the frame 10902 only
so I think I can filter scene-by-scene.,.
at 1st, I now try split them.
edit: no wait, nevermind,,, it's too long to do...
and SpotLess is not a command it says-
jesus!
Code:A=Trim(V,0,89) B=Trim(V,90,179) C=Trim(V,180,258) D=Trim(V,259,357) E=Trim(V,358,469) F=Trim(V,470,583) G=Trim(V,584,726) H=Trim(V,727,859) I=Trim(V,860,989) L=Trim(V,990,1107)
maybe I can split the movie in 2, applying a filter for the first 10902 frames only-.Last edited by maudit; 7th Dec 2022 at 09:08.
LoadPlugin("C:\Users\antip\Desktop\util\MeGUI-2913-64\tools\lsmash\LSMASHSource.dll") V=LWLibavVideoSource("C:\Users\antip\Desktop\Il cacciatore di squali (G. Castellari, 1979)\DVB-T\TS cut\MKV\Il cacciatore di squali - cut_track1_[und].mkv") # SAR 12:11 V=V.AssumeFPS(25) V=V.crop(24, 4, -12, 0) #V=V.InpaintLoc(Loc="594,484,-30,-44") # logo borders #V=V.InpaintLoc(Loc="574,464,-10,-24") # +20px #V=V.InpaintDelogo(mask="C:\Users\antip\Desktop\Il cacciatore di squali (G. Castellari, 1979)\DVB-T\TS cut\.mask\mask.bmp", Automask=1, Loc="574,464,-10,-24", Analyze=2) #V=V.InpaintDelogo(mask="C:\Users\antip\Desktop\Il cacciatore di squali (G. Castellari, 1979)\DVB-T\TS cut\.mask\mask.bmp", Loc="574,464,-10,-24", Analyze=2, Mode="Deblend") A=Trim(V,0,43) B=Trim(V,44,44).InpaintDelogo(mask="C:\Users\antip\Desktop\Il cacciatore di squali (G. Castellari, 1979)\DVB-T\TS cut\.mask\mask.bmp", Loc="576,464,-8,-24", Analyze=2, Mode="Inpaint") C=Trim(V,45,10902).InpaintDelogo(mask="C:\Users\antip\Desktop\Il cacciatore di squali (G. Castellari, 1979)\DVB-T\TS cut\.mask\mask.bmp", Loc="576,464,-8,-24", Analyze=2, Mode="Deblend") D=Trim(V,10903,0).InpaintDelogo(mask="C:\Users\antip\Desktop\Il cacciatore di squali (G. Castellari, 1979)\DVB-T\TS cut\.mask\mask.bmp", Loc="576,464,-8,-24", Analyze=2, Mode="Deblend") ABC=A++B++C ABC=ABC.QTGMC(Preset="Slow").SelectEven() D=D.QTGMC(Preset="Slower", InputType=2, ProgSADMask=0.0) F=ABC++D Return F#.SelectRangeEvery(800,20) Prefetch(7)
.SpotLess() # not recognized as a command.
.mClean() # it seems to me, it removes a lot of details.
isn't QTGMC(Preset="Slow").SelectEven() enough?
or better TFM().etc.., I still have to understand..
I'm going with the script above, if no other hints..
modified crop.
mask files updated..Last edited by maudit; 7th Dec 2022 at 14:13.
From this page (a good resource whenever you run into a missing AviSynth filter):
http://avisynth.nl/index.php/External_filters
you can find a link to Spotless:
https://forum.doom9.org/showthread.php?t=181777
Regarding TFM vs QTGMC, use whichever looks better to you. Generally, TFM causes essentially no damage. But your video is in such poor condition you may prefer the extra cleanup performed by QTGMC. -
I think I'm gonna remove the inpaintdelogo parts, in many scene changes there's a lot of logo artifacts I didn't notice before.
https://www.dropbox.com/sh/optv73qw1a0wn84/AAB72PM7oUjaLTQAncDHv_ypa?dl=0
ah no,, wait.nvm. those issues can be fixed by moving QTGMC before the inpaint..
i'm gonna rewrite the script.
done:
i think this will works good enoguh.
if it can be written more synthetically, I accept suggestions.
Code:LoadPlugin("C:\Users\antip\Desktop\util\MeGUI-2913-64\tools\lsmash\LSMASHSource.dll") V=LWLibavVideoSource("C:\Users\antip\Desktop\Il cacciatore di squali (G. Castellari, 1979)\DVB-T\TS cut\MKV\Il cacciatore di squali - cut_track1_[und].mkv") # SAR 12:11 V=V.AssumeFPS(25) V=V.crop(24, 4, -12, 0) #V=V.InpaintLoc(Loc="594,484,-30,-44") # logo borders #V=V.InpaintLoc(Loc="574,464,-10,-24") # +20px #V=V.InpaintDelogo(mask="C:\Users\antip\Desktop\Il cacciatore di squali (G. Castellari, 1979)\DVB-T\TS cut\.mask\mask.bmp", Automask=1, Loc="574,464,-10,-24", Analyze=2) #V=V.InpaintDelogo(mask="C:\Users\antip\Desktop\Il cacciatore di squali (G. Castellari, 1979)\DVB-T\TS cut\.mask\mask.bmp", Loc="574,464,-10,-24", Analyze=2, Mode="Deblend") A=Trim(V,0,10902).QTGMC(Preset="Slow").SelectEven() B=Trim(V,10903,0).QTGMC(Preset="Slower", InputType=2, ProgSADMask=0.0) AB=A+B X=Trim(AB,0,43) Y=Trim(AB,44,44).InpaintDelogo(mask="C:\Users\antip\Desktop\Il cacciatore di squali (G. Castellari, 1979)\DVB-T\TS cut\.mask\mask.bmp", Loc="576,464,-8,-24", Analyze=2, Mode="Inpaint") Z=Trim(AB,45,0).InpaintDelogo(mask="C:\Users\antip\Desktop\Il cacciatore di squali (G. Castellari, 1979)\DVB-T\TS cut\.mask\mask.bmp", Loc="576,464,-8,-24", Analyze=2, Mode="Deblend") XYZ=X++Y++Z Return XYZ Prefetch(7)Last edited by maudit; 7th Dec 2022 at 20:46.
Hi !
There is a 360p version of the movie on a very famous and popular video sharing website... -
Comb artifacts in progressive source?
By embis2003 in forum RestorationReplies: 80Last Post: 25th Feb 2024, 14:27 -
(NSFW) What's causing these video artifacts and how do i fix them?
By overhyped in forum Newbie / General discussionsReplies: 9Last Post: 31st Aug 2022, 11:33 -
Fix artifacts
By girod2033 in forum Video ConversionReplies: 2Last Post: 25th Oct 2021, 09:39 -
Best way to fix these interlacing artifacts from progressive source?
By sebastiaaan in forum RestorationReplies: 13Last Post: 9th Jul 2021, 21:35 -
Help: Intensity Pro 4k - Interlaced Source = Motion Artifacts
By videobackup in forum Capturing and VCRReplies: 10Last Post: 30th Mar 2020, 23:05
