I have a series of videos that are same file name start, and sequenced by number, such as:
filename - 1.mp4
filename - 2.mp4
Etc..
When I open #1 file, *all* files are auto-appended, and I cant find a way to disable in Avidemux 2.8.1
I only want to open the one file... BTW, I am calling in a script and running a PY script for encoding...
Any ideas?
Thanks,
Andrew
I ended up doing a file copy to a work directory, encoding from there then deleting the file in my batch script. No biggie, but I cant believe there is no way to disable auto append..
Thanks for the follow up johnny!
Andrew
How to batch resize AND append multiple videos in Avidemux?
By savvyguy in forum Newbie / General discussionsReplies: 6Last Post: 28th Jul 2021, 18:00 -
Command-Line to append all avi found in folder using Avidemux - SOLVED
By Tom4 in forum EditingReplies: 0Last Post: 12th Jul 2021, 09:25 -
PotPlayer: Disable Auto-Play of Next File In Playlist
By jsmusiker in forum Software PlayingReplies: 19Last Post: 24th Mar 2021, 16:56 -
Create video using JPG and append to main video using AviDemux
By vfall in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2019, 12:31 -
Avidemux cant append videos properly
By supercain in forum EditingReplies: 10Last Post: 13th Oct 2018, 20:39
