Results 1 to 13 of 13
  1. Hi, I've noticed that some videos on Tubi have a '4K Ready' logo next to them (such as World Cup replays). These videos also have standard 1080p 60 fps versions, as well as lower frame rate feeds (30 fps).
    My question basically is how to find the higher res/quality URLs, because they typically default to 1080p, 30 fps or worse on my laptop (admittedly, it's not 4K capable). I did notice that shortly after a match concludes, when the replay stream first drops, the highest quality option is 1080p at 60 fps, but it appears that they process it and upload a lower frame rate 30 fps version a little while later, at which point I can't seem to find the 60 fps feed any more.
    I have saved a few URLs with the 60 fps content, and am still able to download them, which to me suggests that certain HQ URLs are merely being hidden from some machines or IP addresses. Is anyone able to access the 4K streams at all? If yes, could you please post some master m3u8s for the Round of 16 matches? I can post the main URLs for them, if that helps. I'll settle for 1080p 60 fps streams, as well.
    Here is an example of the France v Poland stream.
    https://tubitv.com/movies/687920/france-vs-poland?start=true
    In developer mode, I currently see this master m3u8 with the following response content.
    #EXTM3U
    #EXT-X-MEDIA:TYPE=AUDIO,URI="uj8a2rnp.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9jbG91ZGZyb250LTIyd2MudHViaS52aWRlbyIsImNvdW50cnkiOiJVUyIsImRldmljZV9pZCI6ImZjZjIxODUzLTQxNTAtNDA2OC1iNWI1LTRlNDZmZjM5Y2UyOSIsImV4cCI6MTY3MDQzMzMwMCwicGxhdGZvcm0iOiJXRUIiLCJ1c2VyX2lkIjo1NTQxMzkyMX0.AfiEvCMxQAQrCQgdBQ-NzCpDqPWv8rWamPgJ2aDr2cA&manifest=true",GROUP-ID="default-audio-group",LANGUAGE="en",NAME="stream_0",AUTOSELECT=YES,CHANNELS="2"
    #EXT-X-STREAM-INF:BANDWIDTH=1062627,AVERAGE-BANDWIDTH=970220,CODECS="avc1.4d401f,mp4a.40.2",RESOLUTION=640x360,AUDIO="default-audio-group"
    q51kp21d.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9jbG91ZGZyb250LTIyd2MudHViaS52aWRlbyIsImNvdW50cnkiOiJVUyIsImRldmljZV9pZCI6ImZjZjIxODUzLTQxNTAtNDA2OC1iNWI1LTRlNDZmZjM5Y2UyOSIsImV4cCI6MTY3MDQzMzMwMCwicGxhdGZvcm0iOiJXRUIiLCJ1c2VyX2lkIjo1NTQxMzkyMX0.AfiEvCMxQAQrCQgdBQ-NzCpDqPWv8rWamPgJ2aDr2cA&manifest=true
    #EXT-X-STREAM-INF:BANDWIDTH=2389819,AVERAGE-BANDWIDTH=2107007,CODECS="avc1.4d4029,mp4a.40.2",RESOLUTION=854x480,AUDIO="default-audio-group"
    y6q0hzgr.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9jbG91ZGZyb250LTIyd2MudHViaS52aWRlbyIsImNvdW50cnkiOiJVUyIsImRldmljZV9pZCI6ImZjZjIxODUzLTQxNTAtNDA2OC1iNWI1LTRlNDZmZjM5Y2UyOSIsImV4cCI6MTY3MDQzMzMwMCwicGxhdGZvcm0iOiJXRUIiLCJ1c2VyX2lkIjo1NTQxMzkyMX0.AfiEvCMxQAQrCQgdBQ-NzCpDqPWv8rWamPgJ2aDr2cA&manifest=true
    #EXT-X-STREAM-INF:BANDWIDTH=3687617,AVERAGE-BANDWIDTH=3087907,CODECS="avc1.640029,mp4a.40.2",RESOLUTION=1024x576,AUDIO="default-audio-group"
    c8wgwcl6.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9jbG91ZGZyb250LTIyd2MudHViaS52aWRlbyIsImNvdW50cnkiOiJVUyIsImRldmljZV9pZCI6ImZjZjIxODUzLTQxNTAtNDA2OC1iNWI1LTRlNDZmZjM5Y2UyOSIsImV4cCI6MTY3MDQzMzMwMCwicGxhdGZvcm0iOiJXRUIiLCJ1c2VyX2lkIjo1NTQxMzkyMX0.AfiEvCMxQAQrCQgdBQ-NzCpDqPWv8rWamPgJ2aDr2cA&manifest=true
    #EXT-X-STREAM-INF:BANDWIDTH=5037040,AVERAGE-BANDWIDTH=4121629,CODECS="avc1.640029,mp4a.40.2",RESOLUTION=1280x720,AUDIO="default-audio-group"
    wi33jn1i.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9jbG91ZGZyb250LTIyd2MudHViaS52aWRlbyIsImNvdW50cnkiOiJVUyIsImRldmljZV9pZCI6ImZjZjIxODUzLTQxNTAtNDA2OC1iNWI1LTRlNDZmZjM5Y2UyOSIsImV4cCI6MTY3MDQzMzMwMCwicGxhdGZvcm0iOiJXRUIiLCJ1c2VyX2lkIjo1NTQxMzkyMX0.AfiEvCMxQAQrCQgdBQ-NzCpDqPWv8rWamPgJ2aDr2cA&manifest=true
    #EXT-X-STREAM-INF:BANDWIDTH=7800510,AVERAGE-BANDWIDTH=6928460,CODECS="avc1.64002a,mp4a.40.2",RESOLUTION=1920x1080,AUDIO="default-audio-group"
    226b6hxg.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9jbG91ZGZyb250LTIyd2MudHViaS52aWRlbyIsImNvdW50cnkiOiJVUyIsImRldmljZV9pZCI6ImZjZjIxODUzLTQxNTAtNDA2OC1iNWI1LTRlNDZmZjM5Y2UyOSIsImV4cCI6MTY3MDQzMzMwMCwicGxhdGZvcm0iOiJXRUIiLCJ1c2VyX2lkIjo1NTQxMzkyMX0.AfiEvCMxQAQrCQgdBQ-NzCpDqPWv8rWamPgJ2aDr2cA&manifest=true
    The 1080p stream referenced at the bottom is 60 fps for now, but it will eventually be replaced by a 30 fps version, and I think the master m3u8 will also be replaced by a new one. For completeness, here is the video stream URL and corresponding audio for the highest quality feed being served to me.
    I'd like to know if anyone is able to view the 4K stream for this example.
    Thank you.
  2. Originally Posted by somnambulist View Post
    #EXTM3U
    Thank you.
    try something like this ?
    curl 'https://tubitv.com/oz/videos/687920/content?limit_resolutions=h265_2160p&video_resourc es=hlsv6_widevine_nonclearlead&video_resources=hls v6_playready_psshv0&video_resources=hlsv6_fairplay &video_resources=hlsv3' --compressed
    {"id":"687920","type":"se","title":"France vs. Poland","tags":[],"year":0,"description":"World Cup 2022 France vs. Poland","publisher_id":"aea550055d4faa50dbac8480856e5db0","import_id":"fifa_tubitv","ratings":[{"system":"tvpg","value":"TV-MA","code":"TV-MA","descriptors":[]}],"actors":[],"directors":[],"availability_duration":14447950,"images":{"posterarts":["https://canvas.tubitv.com/834f5e35-f59a-4ed0-bb01-f3650b372eae/cQYzCX?w=408&h=583"]},"has_subtitle":true,"is_cdc":false,"imdb_id":null,"partner_id":null,"lang":"English","country":"","policy_match":true,"updated_at":"2022-12-04T17:22:18.823Z","awards":{"items":[]},"video_resources":[{"manifest":{"url":"https://manifest.production-public.tubi.io/03cb4076-d8af-4bfd-9098-db9869d48ad8/5lw8of7mrh.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true","duration":6659},"type":"hlsv6_widevine_nonclearlead","license_server":{"url":"https://license.adrise.tv/challenge?platform=web&type=widevine_nonclearlead&external_id=AA8D9BE31CA3337C0499D102EB7FDDFE&drm_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJhbmFsb2dfb3V0IjoiY2dtc19yZXF1aXJlZCIsImV4cCI6MTY3MDQzODQwMCwiaGRjcCI6InYxIiwicHJfc2VjdXJpdHlfbGV2ZWwiOjIwMDAsInd2X3NlY3VyaXR5X2xldmVsIjoxfQ.TibT1cEGDYIClZZtfIU8FNq8sb3zFnF7MzG06iT6wsM","auth_header_key":"customData","auth_header_value":"","hdcp_version":"hdcp_v1"},"titan_version":"","codec":"VIDEO_CODEC_H265","resolution":"VIDEO_RESOLUTION_2160P"},{"manifest":{"url":"https://manifest.production-public.tubi.io/03cb4076-d8af-4bfd-9098-db9869d48ad8/h3d0mfv4y2.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true","duration":6659},"type":"hlsv6_playready_psshv0","license_server":{"url":"https://license.adrise.tv/challenge?platform=web&type=playready_psshv0&external_id=AA8D9BE31CA3337C0499D102EB7FDDFE&drm_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJhbmFsb2dfb3V0IjoiY2dtc19yZXF1aXJlZCIsImV4cCI6MTY3MDQzODQwMCwiaGRjcCI6InYxIiwicHJfc2VjdXJpdHlfbGV2ZWwiOjIwMDAsInd2X3NlY3VyaXR5X2xldmVsIjoxfQ.TibT1cEGDYIClZZtfIU8FNq8sb3zFnF7MzG06iT6wsM","auth_header_key":"customData","auth_header_value":"","hdcp_version":"hdcp_v1"},"titan_version":"","codec":"VIDEO_CODEC_H265","resolution":"VIDEO_RESOLUTION_2160P"},{"manifest":{"url":"https://manifest.production-public.tubi.io/03cb4076-d8af-4bfd-9098-db9869d48ad8/wutqzfn3mu.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true","duration":6659},"type":"hlsv6_fairplay","license_server":{"url":"https://license.adrise.tv/challenge?platform=web&type=fairplay&external_id=AA8D9BE31CA3337C0499D102EB7FDDFE&drm_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJhbmFsb2dfb3V0IjoiY2dtc19yZXF1aXJlZCIsImV4cCI6MTY3MDQzODQwMCwiaGRjcCI6InYxIiwicHJfc2VjdXJpdHlfbGV2ZWwiOjIwMDAsInd2X3NlY3VyaXR5X2xldmVsIjoxfQ.TibT1cEGDYIClZZtfIU8FNq8sb3zFnF7MzG06iT6wsM","auth_header_key":"customData","auth_header_value":"","hdcp_version":"hdcp_v1"},"titan_version":"","codec":"VIDEO_CODEC_H265","resolution":"VIDEO_RESOLUTION_2160P"},{"manifest":{"url":"https://manifest.production-public.tubi.io/03cb4076-d8af-4bfd-9098-db9869d48ad8/pbexixre8r.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true","duration":6659},"type":"hlsv6_widevine_nonclearlead","license_server":{"url":"https://license.adrise.tv/challenge?platform=web&type=widevine_nonclearlead&external_id=AA8D9BE31CA3337C0499D102EB7FDDFE&drm_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJhbmFsb2dfb3V0IjoiZW5hYmxlZCIsImV4cCI6MTY3MDQzODQwMCwiaGRjcCI6ImRpc2FibGVkIiwicHJfc2VjdXJpdHlfbGV2ZWwiOjIwMDAsInd2X3NlY3VyaXR5X2xldmVsIjoxfQ.ZteH-4WdNbKayOVFoqAxVE_PZOn2AEC3AjGHcRCROU0","auth_header_key":"customData","auth_header_value":"","hdcp_version":"hdcp_disabled"},"titan_version":"","codec":"VIDEO_CODEC_H265","resolution":"VIDEO_RESOLUTION_576P"},{"manifest":{"url":"https://manifest.production-public.tubi.io/03cb4076-d8af-4bfd-9098-db9869d48ad8/tg2trdhwf4.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true","duration":6659},"type":"hlsv6_playready_psshv0","license_server":{"url":"https://license.adrise.tv/challenge?platform=web&type=playready_psshv0&external_id=AA8D9BE31CA3337C0499D102EB7FDDFE&drm_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJhbmFsb2dfb3V0IjoiZW5hYmxlZCIsImV4cCI6MTY3MDQzODQwMCwiaGRjcCI6ImRpc2FibGVkIiwicHJfc2VjdXJpdHlfbGV2ZWwiOjIwMDAsInd2X3NlY3VyaXR5X2xldmVsIjoxfQ.ZteH-4WdNbKayOVFoqAxVE_PZOn2AEC3AjGHcRCROU0","auth_header_key":"customData","auth_header_value":"","hdcp_version":"hdcp_disabled"},"titan_version":"","codec":"VIDEO_CODEC_H265","resolution":"VIDEO_RESOLUTION_576P"},{"manifest":{"url":"https://manifest.production-public.tubi.io/03cb4076-d8af-4bfd-9098-db9869d48ad8/xb3rr9k7va.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true","duration":6659},"type":"hlsv6_fairplay","license_server":{"url":"https://license.adrise.tv/challenge?platform=web&type=fairplay&external_id=AA8D9BE31CA3337C0499D102EB7FDDFE&drm_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJhbmFsb2dfb3V0IjoiZW5hYmxlZCIsImV4cCI6MTY3MDQzODQwMCwiaGRjcCI6ImRpc2FibGVkIiwicHJfc2VjdXJpdHlfbGV2ZWwiOjIwMDAsInd2X3NlY3VyaXR5X2xldmVsIjoxfQ.ZteH-4WdNbKayOVFoqAxVE_PZOn2AEC3AjGHcRCROU0","auth_header_key":"customData","auth_header_value":"","hdcp_version":"hdcp_disabled"},"titan_version":"","codec":"VIDEO_CODEC_H265","resolution":"VIDEO_RESOLUTION_576P"}],"rt_fields":null,"imdb_fields":null,"posterarts":["http://canvas-bridge.tubitv.com/ih64sSipwDitFAbxioSJZ-YoFlE=/400x574/smart/img.adrise.tv/360396d9-d6c1-4a70-bba5-199ae156be0b.jpg"],"thumbnails":["http://canvas-bridge.tubitv.com/VWcJi3ylLJoZ93Pyu_3mkWtx5xw=/0x244:1125x869/640x360/smart/img.adrise.tv/8b188d0f-8895-4e59-9af6-7df490dbfdf2.jpg"],"hero_images":["http://canvas-bridge.tubitv.com/spv26aYbmCrcWEF5YhPD49SCtw4=/0x356:1125x773/1920x676/smart/img.adrise.tv/bc47b226-4c70-4f9e-8845-2bae4ff3acc8.jpg"],"landscape_images":["http://canvas-bridge.tubitv.com/DcWxv8oGRaAsEpvPJGxlWFECTmE=/448x252/smart/img.adrise.tv/325fa329-7508-4d30-983f-e850b65d7514.jpg"],"backgrounds":["http://canvas-bridge.tubitv.com/icp371DjZ_OjRMNw93l7_oJzkTI=/1920x1080/smart/img.adrise.tv/6ee4e67f-e7eb-4e82-9a42-b0bdbd14a8b4.jpg"],"gn_fields":null,"detailed_type":"sports_event","needs_login":true,"subtitles":[{"lang":"English","url":"http://s.adrise.tv/c7521101-b8df-4df4-a6c4-7cd98930d374.srt"}],"has_trailer":false,"canonical_id":"","version_id":"","video_preview_url":"","video_renditions":["4K_READY"],"valid_duration":45,"duration":6659,"credit_cuepoints":{"postlude":6658,"prelogue":0,"intro_start":0,"intro_end":0,"recap_start":0,"recap_end":0,"earlycredits_start":0,"earlycredits_end":0},"url":"","monetization":{"cue_points":[0,2978]},"availability_starts":null,"availability_ends":"2023-05-20T23:59:59.000Z","trailers":[],"air_datetime":"2022-12-04T15:00:00.000Z","league":{"type":"tournament","name":"FIFA World Cup 2022","round":"Round of 16","season":"2022"},"teams":[{"id":511,"name":"France","type":"home","seed":1,"group":"Group D"},{"id":525,"name":"Poland","type":"away","seed":2,"group":"Group C"}]}
    #EXTM3U
    #EXT-X-MEDIA:TYPE=AUDIO,URI="02sg8u1e.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true",GROUP-ID="default-audio-group",LANGUAGE="en",NAME="stream_0",AUTOSELECT=YES,CHANNELS="2"
    #EXT-X-STREAM-INF:BANDWIDTH=1035113,AVERAGE-BANDWIDTH=917011,CODECS="hvc1.1.6.L90.B0,mp4a.40.2",RESOLUTION=640x360,FRAME-RATE=59.960,VIDEO-RANGE=SDR,AUDIO="default-audio-group"
    ak8fp1vj.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true
    #EXT-X-STREAM-INF:BANDWIDTH=1903880,AVERAGE-BANDWIDTH=1646358,CODECS="hvc1.1.6.L93.B0,mp4a.40.2",RESOLUTION=854x480,FRAME-RATE=59.960,VIDEO-RANGE=SDR,AUDIO="default-audio-group"
    u7afaxww.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true
    #EXT-X-STREAM-INF:BANDWIDTH=2948754,AVERAGE-BANDWIDTH=2498758,CODECS="hvc1.1.6.L120.B0,mp4a.40.2",RESOLUTION=1024x576,FRAME-RATE=59.960,VIDEO-RANGE=SDR,AUDIO="default-audio-group"
    cx7xx37v.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true
    #EXT-X-STREAM-INF:BANDWIDTH=3673864,AVERAGE-BANDWIDTH=3113415,CODECS="hvc1.1.6.L120.B0,mp4a.40.2",RESOLUTION=1280x720,FRAME-RATE=59.960,VIDEO-RANGE=SDR,AUDIO="default-audio-group"
    4ci3y44u.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true
    #EXT-X-STREAM-INF:BANDWIDTH=4826449,AVERAGE-BANDWIDTH=4132712,CODECS="hvc1.1.6.L123.B0,mp4a.40.2",RESOLUTION=1920x1080,FRAME-RATE=59.960,VIDEO-RANGE=SDR,AUDIO="default-audio-group"
    67w5iaxa.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true
    #EXT-X-STREAM-INF:BANDWIDTH=10122501,AVERAGE-BANDWIDTH=8207267,CODECS="hvc1.1.6.L153.B0,mp4a.40.2",RESOLUTION=3840x2160,FRAME-RATE=59.920,VIDEO-RANGE=SDR,AUDIO="default-audio-group"
    aevnygz8.m3u8?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9ha2FtYWktMjJ3Yy50dWJpLnZpZGVvIiwiY291bnRyeSI6IlVTIiwiZGV2aWNlX2lkIjoiMTgzOTNmZDctNWMxMy00YjdkLTg1ZGEtMmZlOTFiZjlmYjYzIiwiZXhwIjoxNjcwNDM4NDAwLCJwbGF0Zm9ybSI6IldFQiIsInVzZXJfaWQiOjB9.EScXPVwjd4BigS3G-6zIIhyjClDW5e8BX4cWza_uTqU&manifest=true
  3. try something like this ?
    #EXTM3U
    That's brilliant! Thank you. Your URL had extraneous spaces in the curl command, so I'm reposting it below.
    curl 'https://tubitv.com/oz/videos/687920/content?limit_resolutions=h265_2160p&video_resources=hlsv6_widevine_nonclearlead&video_resources=hlsv6_playready_psshv0&video_resources=hlsv6_fairplay&video_resources=hlsv3' --compressed
    Now I just need to find the 1080P @ 60 fps stream, heh.
  4. Originally Posted by somnambulist View Post
    #EXTM3U
    just use the dash manfiest and keys
    https://manifest.production-public.tubi.io/b15b76fc-01ba-4a8c-86a1-55d2246fa495/q5io19662w.mpd?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9jbG91ZGZyb250LTIyd2MudHViaS52aWRlbyIsImNvdW50cnkiOiJVUyIsImRldmljZV9pZCI6IjIwNjg3MDk0LWFiZjMtNDgxZS04YWIwLTIxNGJhZjUwYjY4OSIsImV4cCI6MTY3MDQ0MDUwMCwicGxhdGZvcm0iOiJXRUIiLCJ1c2VyX2lkIjowfQ.rZdYzQtxtqo0Em4brkLqWYu3Mn1qt0_dQdvsvQuL4qs&manifest=true
    ['28d73bd5581a4a978c71ff5b68fb12ad:e442fe3f3333f2dde2c5f5dd923cd524']
  5. just use the dash manfiest and keys
    Sorry, n00b question: how were you able to find the MPD file? I'm in the USA, and the only working method I've been able to come up with is to go into the browser's developer mode and find various m3u8s. I certainly don't see any .mpd file on my end, so any pointers would be much appreciated. Also, what is the tool you're using to download the MP4; is it youtube-dl?
    I have the decryption part sorted out for now, I think; just need to hone my methods for identifying all available streams, especially the best quality ones.
    Thanks again for all your help.
  6. Originally Posted by somnambulist View Post
    Sorry, n00b question: Also, what is the tool you're using to download the MP4.
    Its N_M3U8DL-RE
    https://github.com/nilaoda/N_m3u8DL-RE/releases/download/v0.1.3-beta/N_m3u8DL-RE_Beta_...4_20221202.zip
  7. Originally Posted by somnambulist View Post
    curl 'https://tubitv.com/oz/videos/687920/content?limit_resolutions=h265_2160p&video_resources=dash_widevine_nonclearlead&video_resources=dash' --compressed
    {"id":"687920","type":"se","title":"France vs. Poland","tags":[],"year":0,"description":"World Cup 2022 France vs. Poland","publisher_id":"aea550055d4faa50dbac8480856e5db0","import_id":"fifa_tubitv","ratings":[{"system":"tvpg","value":"TV-MA","code":"TV-MA","descriptors":[]}],"actors":[],"directors":[],"availability_duration":14430557,"images":{"posterarts":["https://canvas.tubitv.com/834f5e35-f59a-4ed0-bb01-f3650b372eae/cQYzCX?w=408&h=583"]},"has_subtitle":true,"is_cdc":false,"imdb_id":null,"partner_id":null,"lang":"English","country":"","policy_match":true,"updated_at":"2022-12-04T18:50:25.055Z","awards":{"items":[]},"video_resources":[{"manifest":{"url":"https://manifest.production-public.tubi.io/b15b76fc-01ba-4a8c-86a1-55d2246fa495/q5io19662w.mpd?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9jbG91ZGZyb250LTIyd2MudHViaS52aWRlbyIsImNvdW50cnkiOiJVUyIsImRldmljZV9pZCI6IjZhNDA3MzhkLTc5ZTYtNDE0ZC05ZWE4LTM5MDZhMmUxZTgwNiIsImV4cCI6MTY3MDQ1NTgwMCwicGxhdGZvcm0iOiJXRUIiLCJ1c2VyX2lkIjowfQ.Qm0hhMgraNmudssvzAlw7pn21dut3JkUpL2TCFryo5Q&manifest=true","duration":6296},"type":"dash_widevine_nonclearlead","license_server":{"url":"https://license.adrise.tv/challenge?platform=web&type=widevine_nonclearlead&external_id=EA19D818D5815FBF1DC00C6481A14BB2&drm_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJhbmFsb2dfb3V0IjoiY2dtc19yZXF1aXJlZCIsImV4cCI6MTY3MDQ1NTgwMCwiaGRjcCI6InYxIiwicHJfc2VjdXJpdHlfbGV2ZWwiOjIwMDAsInd2X3NlY3VyaXR5X2xldmVsIjoxfQ.DVwEEAikt5o9zqBeMebWUoTBahLiDtsQLNg9eQzY1sI","auth_header_key":"customData","auth_header_value":"","hdcp_version":"hdcp_v1"},"titan_version":"","codec":"VIDEO_CODEC_H265","resolution":"VIDEO_RESOLUTION_2160P"},{"manifest":{"url":"https://manifest.production-public.tubi.io/b15b76fc-01ba-4a8c-86a1-55d2246fa495/pxmlqy7pbt.mpd?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjZG5fcHJlZml4IjoiaHR0cHM6Ly9jbG91ZGZyb250LTIyd2MudHViaS52aWRlbyIsImNvdW50cnkiOiJVUyIsImRldmljZV9pZCI6IjZhNDA3MzhkLTc5ZTYtNDE0ZC05ZWE4LTM5MDZhMmUxZTgwNiIsImV4cCI6MTY3MDQ1NTgwMCwicGxhdGZvcm0iOiJXRUIiLCJ1c2VyX2lkIjowfQ.Qm0hhMgraNmudssvzAlw7pn21dut3JkUpL2TCFryo5Q&manifest=true","duration":6296},"type":"dash_widevine_nonclearlead","license_server":{"url":"https://license.adrise.tv/challenge?platform=web&type=widevine_nonclearlead&external_id=EA19D818D5815FBF1DC00C6481A14BB2&drm_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJhbmFsb2dfb3V0IjoiZW5hYmxlZCIsImV4cCI6MTY3MDQ1NTgwMCwiaGRjcCI6ImRpc2FibGVkIiwicHJfc2VjdXJpdHlfbGV2ZWwiOjIwMDAsInd2X3NlY3VyaXR5X2xldmVsIjoxfQ.vngPpK8XrZ4d42fsBD1o2Cd9S6ED9MvT6UmA_Jjp3ww","auth_header_key":"customData","auth_header_value":"","hdcp_version":"hdcp_disabled"},"titan_version":"","codec":"VIDEO_CODEC_H265","resolution":"VIDEO_RESOLUTION_576P"}],"rt_fields":null,"imdb_fields":null,"posterarts":["http://canvas-bridge.tubitv.com/ih64sSipwDitFAbxioSJZ-YoFlE=/400x574/smart/img.adrise.tv/360396d9-d6c1-4a70-bba5-199ae156be0b.jpg"],"thumbnails":["http://canvas-bridge.tubitv.com/VWcJi3ylLJoZ93Pyu_3mkWtx5xw=/0x244:1125x869/640x360/smart/img.adrise.tv/8b188d0f-8895-4e59-9af6-7df490dbfdf2.jpg"],"hero_images":["http://canvas-bridge.tubitv.com/spv26aYbmCrcWEF5YhPD49SCtw4=/0x356:1125x773/1920x676/smart/img.adrise.tv/bc47b226-4c70-4f9e-8845-2bae4ff3acc8.jpg"],"landscape_images":["http://canvas-bridge.tubitv.com/DcWxv8oGRaAsEpvPJGxlWFECTmE=/448x252/smart/img.adrise.tv/325fa329-7508-4d30-983f-e850b65d7514.jpg"],"backgrounds":["http://canvas-bridge.tubitv.com/icp371DjZ_OjRMNw93l7_oJzkTI=/1920x1080/smart/img.adrise.tv/6ee4e67f-e7eb-4e82-9a42-b0bdbd14a8b4.jpg"],"gn_fields":null,"detailed_type":"sports_event","needs_login":true,"subtitles":[{"lang":"English","url":"http://s.adrise.tv/646e9098-3645-4e58-a44c-e5c76f61ed75.srt"}],"has_trailer":false,"canonical_id":"","version_id":"","video_preview_url":"","video_renditions":["4K_READY"],"valid_duration":7200,"duration":6296,"credit_cuepoints":{"postlude":6295,"prelogue":0,"intro_start":0,"intro_end":0,"recap_start":0,"recap_end":0,"earlycredits_start":0,"earlycredits_end":0},"url":"","monetization":{"cue_points":[0,2908]},"availability_starts":null,"availability_ends":"2023-05-20T23:59:59.000Z","trailers":[],"air_datetime":"2022-12-04T15:00:00.000Z","league":{"type":"tournament","name":"FIFA World Cup 2022","round":"Round of 16","season":"2022"},"teams":[{"id":511,"name":"France","type":"home","seed":1,"group":"Group D"},{"id":525,"name":"Poland","type":"away","seed":2,"group":"Group C"}]}
  8. Nice, thanks! I'm on Ubuntu though not Arch, so I may have to play around inside my WinXp VM to see if I can get it running in there for now (although getting it working directly in Linux might be ideal).
    Neat-o, thanks again! I've learnt a lot today.
  9. Originally Posted by somnambulist View Post
    download the linux-x64 binary from the releases page, (extract it) and copy it to /usr/local/bin/ on ubuntu or just use it in that folder
  10. Does anyone know if there is a way to do this with TV shows?
    I tried "limit_resolutions=h264_1080p" but it only ever gives me the standard 720P for any show
    It would be nice if there was some hidden 1080p like some sites do when they normally only offer 720P.
  11. Banned
    Oct 2022
    hhhhhhhhhhh
    its not the same for other sites , depends on what site you try on
  12. Originally Posted by RedPenguin View Post
    Since Tubi is a free streaming service, it likely maxes out at 720p for the majority of content. I think some special sporting events like the World Cup were an exception. Alas, I haven't found anything beyond 720p for the majority of movies and TV shows. I've had to lean heavily on the rendering capabilities of my plasma TV to make this content look good.
  13. curious, given the majority of the site is 720p on a browser/desktop level, like on some other streaming services, has anyone tried to intercept TubiTV app on either an android-tv/mobile device to see if it offers higher quality like 1080?
