In After Effects is it somehow possible getting Target File Size. Like say I have a 50 minute 1080p video. How can I make this say EXACTLY 900mb ? The bitrate settings dont make exact file size possibly
The definition of bitrate is:
Hence if follows thatCode:bitrate = stream size / running time
The file size is the sum of all the streams and a little overhead for the container. If you can't do the math use a bitrate calculator.Code:stream size = bitrate * running time
Also for most encoders 2pass encoding is needed to hit a specific file size
users currently on my ignore list: deadrats, Stears555, marcorocchini -
But as far as I am aware in After Effects there is no way to normally enter a custom bitrate like there is in most programs
Use a bitrate calculator to get the bitrate that will deliver the size you want.
Generate color LUT from DVD for HD target file?
By Oripot in forum RestorationReplies: 7Last Post: 5th Aug 2021, 16:57 -
using masks to target specific colors
By Betelman in forum RestorationReplies: 55Last Post: 29th May 2020, 22:23 -
Derive target bitrate from target quality by analyzing source video
By CryGuy in forum Newbie / General discussionsReplies: 6Last Post: 22nd Aug 2019, 14:07 -
After Effects warning: Reading past end of file
By koberulz in forum Newbie / General discussionsReplies: 4Last Post: 15th Jan 2019, 15:32 -
sound effects and video effects used in japan tv shows
By rocco123 in forum EditingReplies: 0Last Post: 30th Oct 2018, 10:16
