Can you help me, please? http://https://www.cbs.com/shows/video/CgMsr6BNflJJsgyeNH4v8OjKbH7328yB/
Results 331 to 360 of 412
--S52 EPISODE 91: The Young and the Restless - 2/14/2025 --manifest: https://vod-gcs-cedexis.cbsaavideo.com/intl_vms/2025/02/03/2406228547699/3096460_cenc_dash/stream.mpd --key 1816136f3c6c40228bc2b1bbb767ec74:76e6ee5ca8904a337dbc92bb26b8de89
Hi everyone,
Could someone download this video for me? For some reason none of the VPN/Proxy settings work for me on the CBS stream. Thank you in advance!
https://www.cbs.com/shows/video/zhTqmFrzLaOTLTGqp9rzotWrqe93lJjg/ -
N_m3u8DL-RE "https://vod-gcs-cedexis.cbsaavideo.com/intl_vms/2025/03/04/2412470851570/3146529_cenc_dash/stream.mpd" --key 535386285c4646c09e4dbbca42cb7344:49e2df5e3ee1db2c134834acb8af4297 --save-dir "media\cbs_com" --save-name "Ringo_Friends_at_The_Ryman" -M format=mkv
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Please help me grab https://www.cbs.com/shows/ringo-friends-at-the-ryman/ in the best quality minus the DRM. I'll use N_m3u8DL-RE for this. Thank you.
We all bleed blue from the inside.... -
Thank you!
Okay, I'm probably a complete idiot... but it seems to make no sense.
With the code you generously gave me, I downloaded it smoothly with the "N_m3u8DL-RE" software, which is really great, no VPN needed. I asked how to get this code. (The proper link+key).
You posted a link to the "Devine" downloader forum thread and a link to a CBS modification. WTF?
I downloaded and installed "Devine". And I have spent hours reading the posts in the forum thread where there is not a single word about how to create a command line for the "N_m3u8DL-RE" downloader.
It is also not clear what command lines Devine works with. Exactly where should the modified CBS file "__init__.py" be copied? (There are 10 locations in the Devine directory where the file "__init__.py" is listed.)
I saw that the BBC iPlayer modification also exists. Does it work without VPN? -
hi, when pepe give you a N_m3u8DL-RE command, that means it need a custom script written by himself. you know not everything can directly public here on the forum. he link you to devine and CBS because we all use that code/endpoint, if you know python and can write custom script certainly you can get that N_m3u8DL-RE command by yourself or you will use devine to download or just ask other people to give you the N_m3u8DL-RE command. and yes devine download need vpn for cbs/BBC iPlayer, if you only want mpd+key, you still need modify some code from devine service like that __init__.py to print mpd and keys, and skip download. then you can turn off vpn start downloading.
Can you help me, please? https://www.cbs.com/shows/video/jiOkGj1pCmonWVsF2uTNVVP51qB4_7JB/
Code:N_m3u8DL-RE.exe "https://vod-gcs-cedexis.cbsaavideo.com/intl_vms/2025/03/25/2416699971637/3170422_cenc_precon_dash/stream.mpd" --select-video best --select-audio lang=en:for=best --select-subtitle all -mt -M format=mkv:muxer=mkvmerge --save-name "The.Young.And.The.Restless.S52E121.1080p.CBS.WEB-DL.AAC2.0.H.264" --key 23eda32454314c95a62efd8873d4e0d3:97ef6fa168f86b4ef31d0072e3f5b9c1
Please, can anyone give me the download command for this
Code:https://www.cbs.com/shows/video/aYzHXh9R_WaBHWREtpEPghdVK10PMn89/
How ever you want to run it, but that would be mine:
Code:N_m3u8DL-RE "https://vod-gcs-cedexis.cbsaavideo.com/intl_vms/2025/04/05/2419578947548/3206940_cenc_precon_dash/stream.mpd" --key 8c69528160274e4dbc2ffc514d369d41:91390df7a870d14c0e1059589bd35d05 -mt -M format=mkv:muxer=mkvmerge --save-name "nameoffile"
Could someone please download these two clips for me? I would greatly appreciate it. Thank you to anyone who can help!
https://www.cbs.com/shows/video/Eky_3sLx3fv_XCNX3qpydqrio_VEW7K_/
https://www.cbs.com/shows/video/uKSFyjW2WPw5cT4bPFMRyEnGaWenJ4BM/ -
can you download by yourself with mpd and key?
Code:--S52 EPISODE 131: 4/15/2025 --manifest: https://vod-gcs-cedexis.cbsaavideo.com/intl_vms/2025/04/07/2419867203699/3196941_cenc_dash/stream.mpd --key 80c6157b3ac445f89f673478b4318568:5c7dd3a0230485d6f72d916eeb615d07 --S52 EPISODE 134: The Young and the Restless - 04/18/2025 --manifest: https://vod-gcs-cedexis.cbsaavideo.com/intl_vms/2025/04/07/2419867203702/3201379_cenc_dash/stream.mpd --key c7226b7ae79c461eb7f759873729cf2e:8ab29ff8fe0c131562f9485fd7f47d88
^^^ No, I don't know how to do that.
Hope someone else can help. If not, I understand! -
Hey Y'all... Could someone help me out here? I've tried everything I know how to do and I can not download these two videos. Could someone with more knowledge of this sort of thing do that and post links for me in whatever x 720? I was really appreciate it.
Thanks heaps...
Edit: It really helps if you post the links too!
https://www.cbs.com/shows/video/G1XzSMF8UjXX070qrpEARYDCgDjlj_KH/
https://www.cbs.com/shows/video/kDN46t1nzyvCejJjf_WY2oBwsLyRLkNZ/Last edited by Axel Slingerland; 26th Apr 2025 at 05:29.
I admit to being a Rookie, and prone to Rookie Mistakes -
Downloaded with Devine
https://www.swisstransfer.com/d/ebbee02e-a25b-4bc5-842c-79e1757570afCode:devine dl -q 720 CBS link
With N_m3u8DL-RE
Code:N_m3u8DL-RE "https://dai.google.com/ondemand/dash/content/2497752/vid/G1XzSMF8UjXX070qrpEARYDCgDjlj_KH/GRQ/streams/77a3184d-5542-4aca-834b-ac34aa223b8c/manifest.mpd?CMCD=ot%3Dm%2Csf%3Dd%2Csid%3D%2292e5f938-0bc4-47a6-89f2-85aba8ff227e%22%2Csu" --key 01b8343747ce4986bc814c3b4ccb916b:bd66ec11560b8ac25c3d7a5fb1dbab40 -M format=mkv
Code:N_m3u8DL-RE "https://vod-gcs-cedexis.cbsaavideo.com/intl_vms/2025/01/24/2404021315769/3171059_cenc_dash/stream.mpd?CMCD=ot%3Dm%2Csf%3Dd%2Csid%3D%22c2e8a51d-9c0c-4fdc-8a60-944f1232b1fc%22%2Csu" --key 613d3879522e4bec8a6c11ed8cf7712d:7f92f79fadbbdbfbf887421d1ed49c6a -M format=mkv
Thank you very much!
Where can I find Devine? If it's that simple to use, that might be just what I need. I was scatter brained enough before, but due to a bad round of covid, heart problems, and a whole bunch of other things in 2023, learning new things is very difficult for me.I admit to being a Rookie, and prone to Rookie Mistakes -
thread for Devine
https://forum.videohelp.com/threads/414154-Devine-Modular-Movie-TV-and-Music-Archival-Software
you will find a good guide here to install easily Devine on Windows
https://forum.videohelp.com/threads/416617-Semi-automated-guide-to-install-stabbedbybr...fork-of-Devine -
It figures... I've tried that before, and it was like reading a language I don't speak, because I didn't understand a word of it.
Thanks a lot though... I appreciate it. And thank you again for downloading the videos! I appreciate it very much.
Hi all,
I'm trying to capture the mpd link using DevTools/plug-ins in Chrome, but I can only detect the mpd for the ad stream and not the actual video.
Playing with ad blockers didn’t help. Has anyone got a way to get the real mpd for the main video?
I am trying to get the keys from license url ""https://cbsi.live.ott.irdeto.com/widevine/getlicense?..." using the PSSH and headers with token but the request always ends up in an error 403 (forbidden for URL). Tried both with US VPN and without. Can anyone help?
Could someone help me download a CBS News video?
By GDev in forum Video Streaming DownloadingReplies: 7Last Post: 29th May 2025, 01:58 -
Download subtitles from CBS.com video streams
By BobbyGee2003 in forum SubtitleReplies: 1Last Post: 28th Apr 2020, 07:02 -
Portable DLer for CBS?
By KermitJ in forum Video Streaming DownloadingReplies: 22Last Post: 1st Feb 2020, 13:18 -
CBS Grammy Download
By ghostrewel in forum Video Streaming DownloadingReplies: 8Last Post: 14th Feb 2019, 23:02 -
RTMP and CBS
By RBCC in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Mar 2018, 09:21
