Hi everyone,
I'm creating a new thread as I didn't find a similar problem.
I've been trying to download a video from CBS (episodes are available to everyone a week after the TV premiere) with the methods extensively described throughout the forum, but now I'm stuck.
Video: https://www.cbs.com/shows/video/OcWFU93eHKOTNkyKx_t0Ip45ImQH3XHB/
Found PSSH:Found License:Code:AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQBOQb6OSxQta5AivsyHJxZiIgT2NXRlU5M2VIS09UTmt5S3hfdDBJcDQ1SW1RSDNYSEI4AQ==Default headers on getwvkeys (I leave them as they are):Code:https://cbsi.live.ott.irdeto.com/widevine/getlicense?CrmId=cbsi&AccountId=cbsi&SubContentType=Default&ContentId=OcWFU93eHKOTNkyKx_t0Ip45ImQH3XHBI get this error:Code:User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:106.0) Gecko/20100101 Firefox/106.0
I wonder whether I found the correct license or if I should change something with the headers or use a proxy? Videos on CBS.com are geo-blocked for me, but I had no problem getting the keys from eg. ctv.ca. Also, I didn't need a VPN to get a PSSH and URL license from CBS.Code:{ "code":400, "error":true, "message": "Failed to get license: 403 Forbidden"}.
If anyone is sure that it is simply impossible to download from CBS, please let me know.
Thanks!
Results 1 to 30 of 399
Your Key
Classic Widevine encryption...don't work for me with getwvkeys (Problem Geoloc)Code:04e41be8e4b142d6b9022becc8727166:ec3f99c0f74bcd88b7012238bbb4b3c6
Huge thanks for the key, cedric8528 - it worked beautifully, but I ran into another problem. Everything merged correctly, but the mpd link downloaded only the last 5 minutes of the episode (I tried to use aria2c as well, same result).
I used this link:Console output returns the "HTTP Error 405: Method Not Allowed":Code:https://pubads.g.doubleclick.net/ondemand/dash/content/2497752/vid/OcWFU93eHKOTNkyKx_t0Ip45ImQH3XHB/GRQ/streams/1e925186-0da5-4dbe-8db5-30a1afeeae9d/manifest.mpd?CMCD=ot%3Dm%2Csf%3Dd%2Csid%3D%227d028140-6f80-4ebc-ba2b-cd5284dcc1b9%22%2Csu
Do you perhaps know what the problem is?Code:ytdlp.exe --allow-u -N 8 -f bv,ba "https://pubads.g.doubleclick.net/ondemand/dash/content/2497752/vid/OcWFU93eHKOTNkyKx_t0Ip45ImQH3XHB/TUL/streams/e0f7ba3f-e014-40d6-be86-5d224f25db43/manifest.mpd?CMCD=ot%3Dm%2Csf%3Dd%2Csid%3D%2257b94880-c640-4ae7-9152-b0c23d353f56%22%2Csu" WARNING: You have asked for UNPLAYABLE formats to be listed/downloaded. This is a developer option intended for debugging. If you experience any issues while using this option, DO NOT open a bug report [generic] manifest: Requesting header WARNING: [generic] Could not send HEAD request to https://pubads.g.doubleclick.net/ondemand/dash/content/2497752/vid/OcWFU93eHKOTNkyKx_t0Ip45ImQH3XHB/TUL/streams/e0f7ba3f-e014-40d6-be86-5d224f25db43/manifest.mpd?CMCD=ot%3Dm%2Csf%3Dd%2Csid%3D%2257b94880-c640-4ae7-9152-b0c23d353f56%22%2Csu: HTTP Error 405: Method Not Allowed [generic] manifest: Downloading webpage WARNING: [generic] Falling back on generic information extractor. [generic] manifest: Extracting information [info] manifest: Downloading 2 format(s): 3-43, 6-43 [dashsegments] Total fragments: 47 [download] Destination: manifest [manifest].mp4 WARNING: The download speed shown is only of one thread. This is a known issue and patches are welcome [download] 100% of 145.75MiB in 00:05 [dashsegments] Total fragments: 47 [download] Destination: manifest [manifest].m4a WARNING: The download speed shown is only of one thread. This is a known issue and patches are welcome [download] 100% of 4.20MiB in 00:03 -
LuckyBold
maybe you need to use in header request a parameter authorization: Bearer eyJhbGciOiJIUzI1NiIsImt...etc. but it's hard to figure it out.I wonder whether I found the correct license or if I should change something with the headers or use a proxy?Last edited by mister_ nex; 4th Dec 2022 at 15:05.
Downloads ok with N_M3U8DL-RE, put your keys in keys.txt
[Attachment 67985 - Click to enlarge]
If your on Winx64 you need this version
https://github.com/nilaoda/N_m3u8DL-RE/releases/download/v0.1.3-beta/N_m3u8DL-RE_Beta_...4_20221202.zip
If not, other versions are available here:
n_m3u8dl-re.exe --help
Description:
N_m3u8DL-RE (Beta version) 20221117
Usage:
n_m3u8dl-re <input> [options]
Arguments:
<input> Input Url or File
Options:
--tmp-dir <tmp-dir> Set temporary file directory
--save-dir <save-dir> Set output directory
--save-name <save-name> Set output filename
--base-url <base-url> Set BaseURL
--thread-count <number> Set download thread count [default: 8]
--download-retry-count <number> The number of retries when download segment error [default: 3]
--auto-select Automatically selects the best tracks of all types [default: False]
--skip-merge Skip segments merge [default: False]
--skip-download Skip download [default: False]
--check-segments-count Check if the actual number of segments downloaded matches the expected
number [default: True]
--binary-merge Binary merge [default: False]
--del-after-done Delete temporary files when done [default: True]
--no-date-info Date information is not written during muxing [default: False]
--write-meta-json Write meta json after parsed [default: False]
--append-url-params Add Params of input Url to segments, useful for some websites, such as
kakao.com [default: False]
-mt, --concurrent-download Concurrently download the selected audio, video and subtitles [default:
False]
-H, --header <header> Pass custom header(s) to server, Example:
-H "Cookie: mycookie" -H "User-Agent: iOS"
--sub-only Select only subtitle tracks [default: False]
--sub-format <SRT|VTT> Subtitle output format [default: SRT]
--auto-subtitle-fix Automatically fix subtitles [default: True]
--ffmpeg-binary-path <PATH> Full path to the ffmpeg binary, like C:\Tools\ffmpeg.exe
--log-level <DEBUG|ERROR|INFO|OFF|WARN> Set log level [default: INFO]
--ui-language <en-US|zh-CN|zh-TW> Set UI language
--urlprocessor-args <urlprocessor-args> Give these arguments to the URL Processors.
--key <key> Pass decryption key(s) to mp4decrypt/shaka-packager. format:
--key KID1:KEY1 --key KID2:KEY2
--key-text-file <key-text-file> Set the kid-key file, the program will search the KEY with KID from the
file.(Very large file are not recommended)
--decryption-binary-path <PATH> Full path to the tool used for MP4 decryption, like C:\Tools\mp4decrypt.exe
--use-shaka-packager Use shaka-packager instead of mp4decrypt to decrypt [default: False]
--mp4-real-time-decryption Decrypt MP4 segments in real time [default: False]
-M, --mux-after-done <OPTIONS> When all works is done, try to mux the downloaded streams. Use "--morehelp
mux-after-done" for more details
--custom-hls-method <METHOD> Set HLS encryption method
(AES_128|AES_128_ECB|CENC|CHACHA20|NONE|SAMPLE_AES |SAMPLE_AES_CTR|UNKNOWN)
--custom-hls-key <FILE|HEX|BASE64> Set the HLS decryption key. Can be file, HEX or Base64
--custom-hls-iv <FILE|HEX|BASE64> Set the HLS decryption iv. Can be file, HEX or Base64
--use-system-proxy Use system default proxy [default: True]
--custom-proxy <URL> Set web request proxy, like http://127.0.0.1:8888
--live-perform-as-vod Download live streams as vod [default: False]
--live-real-time-merge Real-time merge into file when recording live [default: False]
--live-keep-segments Keep segments when recording a live (liveRealTimeMerge enabled) [default:
True]
--live-wait-time <SEC> Manually set the live playlist refresh interval
--mux-import <OPTIONS> When MuxAfterDone enabled, allow to import local media files. Use
"--morehelp mux-import" for more details
-sv, --select-video <OPTIONS> Select video streams by regular expressions. Use "--morehelp select-video"
for more details
-sa, --select-audio <OPTIONS> Select audio streams by regular expressions. Use "--morehelp select-audio"
for more details
-ss, --select-subtitle <OPTIONS> Select subtitle streams by regular expressions. Use "--morehelp
select-subtitle" for more details
--morehelp <OPTION> Set more help info about one option
--version Show version information
-?, -h, --help Show help and usage informationLast edited by codehound; 4th Dec 2022 at 16:01.
I'm also trying to get a CBS video. Details as follows.
PSSH:Code:https://www.cbs.com/shows/video/awqTtK519IFI0KSlpuBATzwlgVQ1zK2_/
License url:Code:AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQfJkbAcX3TfGvluqYchVkwCIgYXdxVHRLNTE5SUZJMEtTbHB1QkFUendsZ1ZRMXpLMl84AQ==
I'm using a working US proxy with cdrm-project.com using the default headers but get the response:Code:https://cbsi.live.ott.irdeto.com/widevine/getlicense?CrmId=cbsi&AccountId=cbsi&SubContentType=Default&ContentId=awqTtK519IFI0KSlpuBATzwlgVQ1zK2_
I've tried adding bits to the headers such as referer & authorization but then get a different error.Code:Error 405: {"code":100102,"message":"Method 'GET' not allowed for 'http://cbsi.live.ott.irdeto.com/widevine/getlicense?CrmId=cbsi&AccountId=cbsi&SubContentType=Default&ContentId=awqTtK519IFI0KSlpuBATzwlgVQ1zK2_'."}
I'd like to know if it's possible to get the keys with cdrm-project.com or WKS-KEYS.
Thanks -
Thanks ampersand, the keys worked. I tried to do this myself with WKS-KEYS but got "unable to parse license - check protobufs"
I need a Vpn usa to watch CBS video....and I need to keep it connected to get the keys.
Otherwise I have the same message as you.
I hope you have valid L3 cdm... -
Thanks cedric. The cdm is valid. You were right, I needed a VPN for WKS-KEYS as well. I also needed to weed out the unnecessary headers.
Thats not a bad generalization to be fair. Although many sites require literally none at all. Others only need just the 'token(s)' or unique variable value(s) passing.
I, too, am having trouble downloading from CBS.com! I used to be able to download full episodes for years but it seems they have changed something. The only thing I can download now are ads. The video itself won't download. Does anyone have any help. Here's an example video:
https://www.cbs.com/shows/video/_QAhutdiEnHMoi8Mk1fWYjzkWxlHRhen/ -
To add, I am trying to download using TubeDigger. I don't know how to do all the other stuff. I am used to just pasting the url and it downloads, lol.
hello how can i download this video who can help me please thank you https://www.cbs.com/shows/video/Pr4JJMRfk1Y4h_JMYXTCmKaPYysxe2W0/
You can download it with N_m3u8DL-RE and the good key to decrypt your video.
Code:N_m3u8DL-RE.exe --key 49e952b339dd41e1991300813b2c21f0:745c8d61e7124f002dab6178b4777c16 "https://pubads.g.doubleclick.net/ondemand/dash/content/2497752/vid/Pr4JJMRfk1Y4h_JMYXTCmKaPYysxe2W0/CBF/streams/9a423b60-6417-4b99-92b7-6a0e4a683ec6/manifest.mpd?CMCD=ot%3Dm%2Csf%3Dd%2Csid%3D%22acc15bb4-6a8f-46d8-b185-876858e802e0%22%2Csu" -M format=mp4
[Attachment 68582 - Click to enlarge]
some readings
https://forum.videohelp.com/threads/404994-Decryption-and-the-Temple-of-Doom
your file
https://www.transfernow.net/dl/20230107mIJzW8PYLast edited by cedric8528; 8th Jan 2023 at 00:50.
I installed mpd detector extension in chrome but I still couldn't download this video, do you have a step-by-step tutorial or a video for me, thank you
Can someone download this video for me? Please and thank you in advance! I'd be very appreciative.
https://www.cbs.com/shows/video/jpG4V4FpQJb4DaYKP_GAtVIrAAy02hK9/ -
Can someone please download this episode for me?
https://www.cbs.com/shows/video/SYDh2O6U_6nZrdg9_Yw1GFNqMd2Ncdax/ -
your mpd (done removed Ads)
Code:https://gofile.io/d/t70ZhP
Code:N_m3u8DL-RE -M format=mkv --key 1d6d4b51887847f1b80fe3ff1d4f56c1:6fe85b143804e393f06e29b5855cc1d2 "PATH your cbs.mpd" --save-name video
Thank you so very much. I'm so sad I can no longer use Tubedigger to download from CBS. It used to work so easily. Now, all I get are ads.
So, again, thank you.
Hey I have a very similar problem, can you please look into this as well ? :
https://forum.videohelp.com/threads/409715-Not-getting-headers-from-this-Licence -
I realize I am totally pushing my luck but if anyone could download these two episodes for me, I would be very grateful. If not, I totally understand.
https://www.cbs.com/shows/video/uh1DxbCCKUlTa9ywjGmzWpPE9J6SaRQM/
https://www.cbs.com/shows/video/m3yPIc50D6G58uR0Xctb1Ob60BhNiM7K/
Could someone help me download a CBS News video?
By GDev in forum Video Streaming DownloadingReplies: 7Last Post: 29th May 2025, 01:58 -
Download subtitles from CBS.com video streams
By BobbyGee2003 in forum SubtitleReplies: 1Last Post: 28th Apr 2020, 07:02 -
Portable DLer for CBS?
By KermitJ in forum Video Streaming DownloadingReplies: 22Last Post: 1st Feb 2020, 13:18 -
CBS Grammy Download
By ghostrewel in forum Video Streaming DownloadingReplies: 8Last Post: 14th Feb 2019, 23:02 -
RTMP and CBS
By RBCC in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Mar 2018, 09:21
