Hi,
I have a problem with losslesscut und the merge command after splitting. Losslesscut splits the parts of a .ts-file correctly and saves them to the working directory, but it stops merging them with the error message:
An error has occurred.
Command was killed with SIGSEGV (Segmentation fault): /snap/losslesscut/109/resources/ffprobe -of json -show_chapters -show_format -show_entries stream -i /home/user/Videos/20221202 1758 - ProSieben - taff-00.00.14.758-00.00.18.239-seg1.ts -hide_banner
I've tried the AppImage-version and the snap-store version of Losslesscut - both deliver the same issue.
If I choose the option just to create seperate files - everything works ok.
The error appears on both versions 3.48.2 and 3.46.2 and has maybe something to do with linux-kernel 6 or with a new system-installation a month ago, because it worked flawlessly months before.
Can anyone please give a hint what this error message means? Thanks.
Hi
Ive used Losslesscut in both windows and ubuntu (appimage) and worked perfectly for my usage, have you tried using avidemux to join the files after losslesscut? open first file and then "append file" as many times as necessary, in the end select export/save and select copy audio/video.
try asking here:
https://github.com/mifi/lossless-cut/issuesI love it when a plan comes together! -
Thank you very much for your answer. I'm sure there are a lot of work-arounds, but they are uncomfortable in the end.
I'll ask the lossless-cut-forum for help. I assume the error has something to do with my system-installation, so I will try it on another linux distribution or will setup a new test environment with my OS.Last edited by helmut12; 4th Dec 2022 at 03:56.
Losslesscut won't work unless I discard audio (ps never mind found the ans)
By videdit in forum EditingReplies: 0Last Post: 3rd Sep 2022, 00:19 -
losslesscut output audio noise
By paqman in forum Video ConversionReplies: 5Last Post: 18th Nov 2021, 21:57 -
Error Playing h.264 mp4 in Chrome and Losslesscut
By Media-Tomb in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2019, 22:41 -
LosslessCut gives input file sound only - no video
By FredVH in forum EditingReplies: 0Last Post: 27th Oct 2019, 19:39 -
LosslessCut.exe install but just got this error message
By CrazyMonkey88 in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2018, 20:24
