  1. just wondering if i am along the right time frame here...
    whether i use panasonic/tmpge or nero to encode a video it takes hours...is there any faster way to encode or is this right...
    just wondering thanks ron
    Feb 2002
    Michigan, U S of A
    Yes. it takes a long time. Try using CBR or CQ. VBR will double your time. Add a filter like noise reduction and it can then triple your total time!
    I did a batch encoding test last night.
    SVCD 480x480, 46min12sec TV show with:
    Constant Quality=2240@100 (note: not 2215 w/CBR)
    Noise Reduction=818,
    Motion Search=very slow
    and it took me 8hrs25. 801,921Kb
    I then did the same video again
    Constant Quality=2240@100,
    Motion Search=slow
    and it took me 2hrs38. 812,397Kb
    They both look good, almost the same. For the time saved the second one looks Great.
    FROM THE ENCODING:
    Start: 5/6/2002 11:40:05 PM
    End: 5/7/2002 12:45:19 PM
    Dealing time: 13:05:13
    E:\The Shield\The Spread\The Spread01.mpg
    Format: MPEG-2 480x480 29.97fps CQ 100, Layer-2 44100Hz 128kbps
    Video: E:\The Shield\The Spread\The Spread.avi
    Audio: E:\The Shield\The Spread\The Spread.avi
    Result: Succeeded
    Dealing time: 08:24:30
    E:\The Shield\The Spread\The Spread02.mpg
    Result: Succeeded
    Dealing time: 02:37:30
    Dell Precision 620
    Dual 800 Xeon
    512 Mb
    Nvidia TNT2 Ultra
    Seven
  3. The Shield is awesome! Wish I can see more of it though, probably worth getting cable just for that ! The Comish is a real bad-ass, in the good sense.
