    Apr 2003
    michigan,usa
    i have a dash cam, model 70mai Dash Cam A400. It captures in 3 minute intervals, which produces a lot of files. The files are in .mp4 format. I would like to covert all those files into 1 big .avi format video.
    Can someone suggest how to do this? I tried Virtualdub and ran into problems.
  2. What problems did you encounter with VirtualDub? Did you try VirtualDub2? It should have worked.
    Apr 2003
    michigan,usa
    I tried virtualdub2. It worked!! The audio was choppy/broken up, though
  4. Can you provide two or three consecutive files that show that problem when concatenated by VirtualDub2?
  5. Another GUI program you can try is AviDemux. Also clever-FFmpeg-GUI. FFmpeg should be able to deal with the files too -- but it's a command line program.
