Results 1 to 12 of 12
    Dec 2022
    Brazil
    When I tried converter webm videos in Uniconvert. Only the audio is converted. There is no video. In preview I can't see the video too. I don't understand what is happening. Someone could help me, please?
  2. Post a mediainfo report (text mode) from your webm file here.
    Dec 2022
    Brazil
    General
    Complete name : D:\PS5\CREATE\Video Clips\RESIDENT EVIL REVELATIONS\test.webm
    Format : WebM
    Format version : Version 4
    File size : 115 MiB
    Duration : 59 s 893 ms
    Overall bit rate : 16.1 Mb/s
    Writing application : mkvmux-1.0.0
    Writing library : mkvmux-1.0.0
    Video
    Format : VP9
    Codec ID : V_VP9
    Width : 1 920 pixels
    Height : 1 088 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 59.940 FPS
    Color space : YUV
    Default : Yes
    Forced : No
    Color range : Limited
    Color primaries : BT.2020
    Transfer characteristics : PQ
    Matrix coefficients : BT.2020 non-constant
    Audio
    Format : Opus
    Codec ID : A_OPUS
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Compression mode : Lossy
    Delay relative to video : -9 ms
    Default : Yes
    Forced : No
    canada
    Upload a short unaltered clip here.
    Dec 2022
    Brazil
    Okay!
    The video is already short.
    It's attached.
  6. I'm a Super Moderator johns0's Avatar
    canada
    Ran it trough vidcoder with no issues,out as h264 mkv.
    Dec 2022
    Brazil
    The video is okay... The problem is when I try to convert or compress the video in Wondershare Uniconvert... I can't see the preview there... And when I try to, Only the audio works with no video.
  8. I'm a Super Moderator johns0's Avatar
    canada
    I wouldn't use wondershare,much better encoders out there.
    Mar 2008
    Seems to be some problem with the index, use MKVtoolnix GUI to remultiplex to an MKV, and use it for your new source.
    Dec 2022
    Brazil
    Yeah... Sure.
    Vidcoder works great. I can share my videos decreasing the size with this program.
    Dec 2022
    Brazil
    Okay. But this is not practical... Should I do this with all videos webm?
    Vidcoder seems cool.
    Thanks anyway!
  12. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    Originally Posted by Lima View Post
    Wondershare
    It's a Chinese crap company selling probably the illegal software [probably all of it is freeware wrapped in shitty GUI from them].
    If you paid for it then cancel your credit card immediately.
    https://www.complaintsboard.com/wondershare-technology-co-b125208
    Do not give this company your credit card because you'll find yourself subscribed to features you never selected and they make it impossible to cancel those subscriptions.
