i have written about this before. I am using DVDFab to copy a tv series, however, for this particular series the copying process never completes. There are eight discs. For each disc the copying process will stall out at 51%. I will let this go on for over 24 hours and it will increase to 52%. I have tried MakeMKV, but NO luck. With MakeMKV one episode will copy with a faint audio, and the others have no video.
Also, the discs are not scratched or smeared,
Is there a way to copy the discs with DVDFab?
Thank you.
Results 1 to 9 of 9
Are these commercial discs or burned? Do they play in a dvd player?
That could be the drive is not recognizing the layer break properly. Do as davenet suggested and try an different drive.
Have you tried playing the dvds on the pc with VLC? If that doesn't work then, as OldMan64 noted, it is most likely layer break issue. If the drive is more than a few years old it could be going bad. As davexnet said, try a new drive or you could try cleaning the laser lens.
Copying 4k movies to 50 GB blanks using DVDFab-The copy stutters and jumps
By LloydS in forum Authoring (Blu-ray)Replies: 43Last Post: 26th Mar 2024, 06:35 -
Trouble copying discs with DVDFab
By jarod1005 in forum Newbie / General discussionsReplies: 17Last Post: 17th Nov 2022, 23:50 -
Problems copying a DVD with DVDFab
By jarod1005 in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2022, 16:25 -
Hard time copying with DVDFAB
By jarod1005 in forum Newbie / General discussionsReplies: 9Last Post: 6th Jun 2021, 14:54 -
DVDFab Launches Enhanced Product Suite in DVDFab 12
By DVDFab Staff in forum Latest Video NewsReplies: 0Last Post: 13th Oct 2020, 22:11
