Morning all,
Not posted in a while as not been able to do any video capturing.
Now able to.
I'm using a Video-2-PC device to import my old 8mm videos and the original software isn't great but you get Virtual Dub with it as well and this is better.
My problem is. When I used a while ago, I had to set up all the settings in in Video, Audio, sections each new time I used it.
I would like to be able to load it up and either have the settings already set OR have like a profile to load to save time.
The settings take a while to do.
Is there such a way to do this?Settings.
Device → select EM28284 USB video device (DirectShow).
Video → Video Source → Video Composite.
Audio → RAW Capture Format → PCM 48000Hz Stereo 16 bit → OK.
Audio → select Line (EM28284 USB Audio).
Video → Capture Filter → Video Decoder → Video Standard → PAL_I → tick VCR input.
Video → Set Custom Format → Frame Size 352x288 (slow PC) or 720x576 → Data Format YUY2 → OK.
Video → Compression → YUY2 (uncompressed or slow PC) or X264VFW (dual core 2.8GHz+ box for live capture).
Video → Capture Pin → Frame Rate 25.000 → Apply → OK. (if you're in the UK, capturing PAL video).
(make sure Audio → Enable Audio Playback isn't enabled, otherwise you'll drop frames)
OR
Can you recommend a FREE (times are hard) bit of software to use?
OR
Can Vegas Pro 17 import (I've not found a way yet.
Thanks in advance for any help you can give me.
Results 1 to 1 of 1
This blessed plot, this earth, this realm, this England.
Save capture settings Virtualdub 1.9?
By hpcampr in forum Capturing and VCRReplies: 4Last Post: 7th Feb 2022, 15:40 -
Best settings using Virtual Dub to correct dark VHS capture
By DMS in forum RestorationReplies: 69Last Post: 6th Oct 2021, 05:30 -
XMediaRecode - How to save settings as custom presets?
By Highlander71 in forum Video ConversionReplies: 5Last Post: 20th Nov 2020, 07:10 -
How could you upscale SD to HD in Virtual Dub?
By nicksilverstein in forum Newbie / General discussionsReplies: 3Last Post: 24th Feb 2019, 04:19 -
Virtual dub does not display my video
By Hodar in forum Newbie / General discussionsReplies: 10Last Post: 26th Aug 2018, 03:55
