Results 1 to 24 of 24
    May 2005
    PAL User
    I'm interested in the experiences of people using non-AVISynth deinterlacers such as those in Handbrake, AVIDemux and other GUIs.
    If you have any experiences you'd like to share, I'm keen to hear them.
    Thanks in advance.
  2. BWDIF in ffmpeg (some GUI front ends should make it available) is about the best. Yadif, implemented in many programs falls after that.
  3. I have only tried GUI deinterlacers outside of AVISynth when I was using VirtualDubMod, and Handbrake many years ago. I honestly thought both did a mediocre job of it, and I never went back after using AVISynth ones.
    I don't really have any good suggestions outside of avisynth or vapoursynth, but maybe try the one Jagabo stated. I never tried it before.
  4. The best one in handbrake is EEDI2 , it's similar to avisynth's yadifmod+EEDI2 - ie. slow processing speed but better than yadif or bob in terms of jaggies/ aliasing artifacts .
    Avidemux doesn't have very good ones
    I think some GUI's like staxrip and hybrid offer some avisynth/vapoursynth deinterlacing options and you don't have to touch any backend code or scripts
    Each deinterlacer has various pros/cons and might be better suited (or not) for some situations
    May 2005
    PAL User
    Thanks everyone, for your input.
  6. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Most of them are AviSynth deinterlacers, inside a GUI (or ffmpeg)
  7. You can also try clever FFmpeg-GUI, newest beta (v3.0.5.03), with which you can now choose between two deinterlacers (bwdif, yadif), with all options (with appropriate help).
    May 2005
    PAL User
    @ProWo, thanks for that, but I can't find the deinterlace option in 3.05.03. I do have my glasses on!
  9. Originally Posted by Alwyn View Post
    Load an interlaced video, main, encode videostream, crop/resize/keep resolution, deinterlace.
    With progressive video it's hidden.
    May 2005
    PAL User
    Found it! Thanks! Sorry to be a nuisance: doesn't appear to be an output container option, it encodes as an MKV. The "Multiplex" menu has MP4 or MKV.
  11. Originally Posted by Alwyn View Post
    After encoding remux it with audio and subs to mp4.
    May 2005
    PAL User
    Rojer, thanks.
  13. Video Restorer lordsmurf's Avatar
    selur's Hybrid
  14. AI based deinterlacer perhaps ? (i haven't tried)
    https://www.pixop.com/blog/using-ai-to-deinterlace
  15. AI based deinterlacer perhaps ?
    Too much work for something that could be solved with using a really advanced script called NNEDI3_rpow2
  16. Doesn't nnedi3 count as ai nowadays? (nnedi3 = neural network edge directed interpolation version 3)
  17. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    NNEDI3_rpow2 is not a deinterlacer, but an upscaler for progressive video.
    NNEDI3 is an intra-field only deinterlacer. I use it only for material where I interlace back at the end (discharge of created frame). For real deinterlacing, QTCMG is superior.
  18. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    A neural network is not exactly AI (sort of precursor)
  19. A neural network is not exactly AI (sort of precursor)
    oh, I thought neural networks nowadays also run under ai,... (seems like artificial intelligence, machine learning, deep learning and neural networks all are titled 'ai' nowadays )
  20. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Maybe. I did my PHd on Neural Network implementing "back-propagation" algorithms many year ago. And AI was not involved. Things may have changed today, in the sense that under AI "cover" we also include self learning neural network such as what I mentioned
  21. Video Restorer lordsmurf's Avatar
    Well, I'm impressed.
    The main change is that the term was bastardized, raped, by marketing depts. Everything is "AI" now. Or "cloud". The terms lost their gatekeepers, and now mean almost nothing.
    - "cloud" means online.
    - "AI" means software that generates data, and uses that data to create more data.
    And a few loose terms like "TBC", and it becomes pure technobabble used by lemmings and idiots that want to sound smart about something they know NOTHING about.
    My toaster has AI cloud with TBC?
    Applied lateral synergy, or something. Blah blah blah.
  22. Re. non-AviSynth deinterlacers: Nvidia graphic cards support their own GPU deinterlacing (single rate, double rate).
  23. Banned
    Nov 2022
    Isn't QTGMC NOT a deinterlacer per se - it cannot be ported as a single product or made into, say, a VDub filter - but a script that uses a bunch of other scripts and DLLs, some of which are actual deinterlacers, scalers and noise-reducers? In particular, I believe it uses NNEDI3 in one of its presets. Actually, I think it has started as a wrapper around NNEDI3.
  24. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    No. QTGMC is a deinterlacer, based on old TempGaussMC. It uses many other filters to do at best its (primary) job.
