i have taken a screenshot on my cellphone.
ffprobe tells me the image format is jpeg and the pixel format is mjpeg. i want to convert the image to tiff. however ffmpeg complains that the pixel format is deprecated.
what is the problem?
cellphone is huawei p30 lite. ffmpeg is on termux. on the cellphone. ffmpeg is no more than 2 months old.
ffprobe output is atteched
ffmpeg output is attached
ty
no problem if it works, or if the conversion is done correctly - it's usually just a warning message
most jpeg images are stored as full range YUV as Rec601, but most decoders output RGB. FFmpeg outputs the actual pixel format
Is just that yuvj420p ("j" formats) used to indicate full range YUV (also yuvj422p, yuvj444p for 422 sampling, and no subsampling); but they might be changing to another method to denote "full range YUV" in the future -
What is the usage case / reason for converting to TIFF ? The log says it's being converted to yuv420p - but some programs might not be expecting that or compatible be with that (yuv420p TIFF; most expect RGB) . If it's libavcodec/ffmpeg based, it shouldn't be a problem, I'm referring to other programs
convert 564
By grabyea in forum Video Streaming DownloadingReplies: 4Last Post: 3rd Aug 2022, 07:09 -
Stitching TIFF images back together?
By jedi55 in forum Video ConversionReplies: 14Last Post: 7th Mar 2021, 14:58 -
Batch Script for FFMPEG TIFF Conversion
By Jolly Green in forum ProgrammingReplies: 5Last Post: 30th Sep 2020, 14:11 -
Can't convert .tiff's to lossless video [color problem]
By eobardthawne in forum Video ConversionReplies: 6Last Post: 8th Oct 2019, 12:39 -
Windows 10 tiff file not recognized when created by PANA LINK program
By bevills1 in forum ComputerReplies: 3Last Post: 15th May 2018, 15:42
