Hello everybody.
I do a work for convert videos now.
I try to take about 5000 bitrate for 720p grain video, I default to use 1.0 aq strength for all movies, but when I see it, have some grain is freeze (can't moving). And I try to find about this problem and maybe it's bitrate not enough.
So have anyone can tell me for what enough bitrate for 720p videos? (can up to 17000 bitrate that I allow)
I use x264 very slow preset: me=umh - subme=11 - bframes 16.
All I need to know is how many bitrate for 720p aq-strength 1.0 to have a perfect 720p videos quality of movies?
Very hope some pro encoder can support for me. Many thanks.
Not a pro encoder, but here are my two cents:
a. What is the average quantizer that your rencoding results in? (it's shown in the statistics at the end of the encoding) Depending on the content an average bit rate of 5000 might be way more or far less than needed.
b. assuming you are using 1pass encoding, better switch to crf encoding.
c. 16 bframes makes no sense for normal movies (see the statistic what really gets used)
d. if your source is grainy, and you want to preserve the grain, you should use '--tune grain'
- grain (psy tuning):
--aq-strength 0.5 --no-dct-decimate
--deadzone-inter 6 --deadzone-intra 6
--deblock -2:-2 --ipratio 1.1
If you do not want/need to preserve the grain using x264s noise reduction ('--nr XXX') option might be helpful. (notice that '--tune grain' lowers aq-strength)
Cu Selurusers currently on my ignore list: deadrats, Stears555 -
How can I convert a Dolby True HD into DTS with 24-bits
By dionys in forum AudioReplies: 2Last Post: 19th Dec 2021, 22:42 -
Does anyone know a very easy way to convert Dolby True HD to FLAC?
By Talhah in forum AudioReplies: 4Last Post: 15th Jul 2021, 11:10 -
AC3 core, or downconverting Dolby True HD?
By bagmand in forum AudioReplies: 6Last Post: 7th Jun 2020, 01:24 -
Best Software For A True one to one Rip
By Johnnysh in forum DVD RippingReplies: 6Last Post: 7th Jun 2020, 00:45 -
Will we ever see true master quality video?
By lingyi in forum Newbie / General discussionsReplies: 8Last Post: 24th Jun 2018, 15:54
