Is there any translation offline program you would recommend?
Results 1 to 19 of 19
Why not just use Google translate and cross check accuracy by doing round trips?
Scott -
The problem is the limited number of lines Google will translate.
I have been doing subtitles for TV series and films for some time, and like most people doing it now I'm using automatic translation as the basis for the final translation.
Using you may require about 10 parts to translate separately, as all translator now seem to work online, charging by each job.
So I would prefer to get a program I can use as much as I want.
Is there such a program? -
Have you looked at the Subtitle Edit auto translate? For it to work properly you have to pay google for an API key
https://www.nikse.dk/subtitleedit/help#translation -
https://www.microsoft.com/en-us/p/offline-translator/9nblggh08s8v?activetab=pivot
verviewtab
Windows 8 and up, Arm, X86, X64, freeIt's not important the problem be solved, only that the blame for the mistake is assigned correctly -
Google will easily translate multiple page documents.
https://translate.google.com/?sl=auto&tl=fr&op=docs
As an experiment, I translated "Pride and Prejudice" from English to French. 267 pages. Took less than two minutes.Last edited by smrpix; 29th Nov 2022 at 13:06.
I tried to translate a subtitles file, in pdf, and the results were terrible. Half of the total dialogue appeared as question marks: ???
...I'm confused. Why would subtitles be in a PDF file format?
It's probably more due to incompatibilities with the PDF format than anything else. Are you sure the PDF isn't protected?
(Hmm. Google Translate's help also states this:
)You can translate documents up to 10 MB in any of these formats: .docx, .pdf, .pptx, .xlsx. PDF files must be 300 pages or less.
To translate more documents or larger documents, learn about the Cloud Translation API.
Important:
Document translation isn’t available on smaller screens or mobile.
You can find text in images and scanned .pdf pages in the output document but they aren’t translated.
If possible, try opening the PDF in something that'll allow you to export it to a different file/document format, and see if Google Translate has the same problem with the exported version.If cameras add ten pounds, why would people want to eat them? -
What is your original source? If your subtitles are heavily formatted or started as xml references to pgs as in many Blu Rays, you shouldn't expect it to work. Translation requires text.
[QUOTE=carlmart;2674539][QUOTE=Ai Haibara;2674482]...I'm confused. Why would subtitles be in a PDF file format?
Important:
Of course they shouldn't. First I tried to use the .txt file I made from the .srt file. But text files can't exceed 5000 characters. So you have to import it as a document, and as you can see the options are limited. No .txt for instance. I couldn't convert the txt file do .docx either, so I tried with pdf.
Translate documents
You can translate documents up to 10 MB in any of these formats: .docx, .pdf, .pptx, .xlsx. PDF files must be 300 pages or less. To translate more documents or larger documents, learn about the Cloud Translation API
How did you do to translate the 267 pages book? -
I downloaded it from Project Gutenberg as a text file. Opened and saved it in Word as a docx. Uploaded that into the Google Translate web page and then downloaded the result.
(Before doing that I tried it with some short .srt files -- saving them as .docx, uploading to Google and translating. It worked fine. But that didn't seem like a heavy enough test to allay your concern about document size.) -
My Word can't save as docx.
I tried another program that made that conversion, but it didn't work. -
Argos translate and librettranslate I’ve used offline. Results aren’t as good as deepl for instance though.
?? If this is true you are using a version that is 19 years old or older. All versions on all platforms since "2007" (which came out in 2006, and the previous version came out in 2003) use docx as their default format.
Well past time to upgrade. Or use Google docs, or libroffice, etc. Many options, almost all of which support docx.
Scott -
Using Office 2011 put me back into the game.
Saving in docx and translating fine. -
It would be too expensive to use such services. Google Translate does the job quite well, getting right about 95% of the right words, not matter the language.
A life saver for my application, which is subtitles translation.
In many cases, like on documentaries, I'm mating it with Subtitle Edit, to convert audio dialogues into text, and then translating.
Depending on the translation importance, I correct the translation errors myself.Last edited by Baldrick; 11th Feb 2024 at 00:32.
Subtitle translation, show lines as done (aegisub)
By UserName351 in forum SubtitleReplies: 0Last Post: 29th Dec 2021, 15:50 -
Bulk translation tool?
By jooj in forum SubtitleReplies: 0Last Post: 1st Nov 2020, 10:36 -
state of the art: automatic subtitle translation
By wandmaler in forum SubtitleReplies: 3Last Post: 30th Oct 2020, 05:45 -
Lost in Translation Re: Transfering Mini DV to PC with no loss
By PC105 in forum Newbie / General discussionsReplies: 20Last Post: 10th May 2019, 15:33 -
Subtitle Edit: How to see original sub for translation but not its timings
By AmirATM in forum SubtitleReplies: 0Last Post: 20th Mar 2019, 04:58
