  1. Hi! I'm trying to swap track position on multiple files at once, I've tried this script:
    for %%a in ("*.mkv") do mkvpropedit "%%a" ^
    --track-order 0:0,0:2,0:1,0:3,0:4
    Which should swap track 2 position with track 1 on all MKV files in the same folder, I say should but actually it doesn't - I am missing something?
  2. --track-order is an option for mkvmerge, not mkvpropedit.
  3. Tried but didn't work... what's the command to not auto-close the command prompt window so I can read what it says? maybe there's some an error it identifies
  4. Originally Posted by RandomNewbe View Post
    pause
    With mkvmerge you need to supply input and output filenames.
    mkvmerge --track-order 0:0,0:2,0:1,0:3,0:4 input.mkv -o output.mkv
    pause
  5. Edit: Okay I found a semi-working script:
    for %%y in (*.mp4) do mkvmerge -o "%%~dpny.mkv" "%%~fy" --track-order 0:0,0:2,0:1,0:3,0:4
    pause
    However for this to work I have to rename all .mkv files to .mp4 because if I specify to process the .mkv files I get an error (since the output would overwrite the input files and the script won't let me do that)
    [Attachment 67776 - Click to enlarge]
    "Error: The name of the destination file "<path>" and of one of the source files is the same. This would case mkvmerge to overwrite one of your source files."
    Is there a way to have to output files slightly renamed so it doesn't cause an overwrite error?
  6. Originally Posted by RandomNewbe View Post
    Add something to the output filename, or specify a sub-folder:
    for %%y in (*.mkv) do mkvmerge  -o "%%~dpny_reordered.mkv" "%%~fy" --track-order 0:0,0:2,0:1,0:3,0:4
    pause
  7. That's perfect ~ thanks a lot <3
